| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
NASA SpecE30 Racer
Buy one under warranty, and then you don't have to worry about any of that stuff. If it has it, then take it to the dealer to fix it. That is the advantage of owning a 2013 over a 2001. The BRZ Limited definitely sounds like the way to go for you. I do miss the comfort access, bluetooth, and navigation that the S2000 doesn't have. I made the move because the S2000 has been around for quite a while now and the aftermarket has found solutions for all the issues and the cost of entry / cost of replacement should I wreck mine on track is lower.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#16 | |
Drives: 04' 400whp S2000, 01' DD S2000
Overall you do not see any issues with snagging a 2013 over a new 2015/2014? I've negotiated 25.6k on a new '14 BRZ limited however can get a '13 with <10k for 23K asking so I'll go ahead and assume <22K Winter is coming after all
2001 - Honda S2000 (Daily Driver)
2004 - Honda S2000 (400WHP widebody project car) |
#17 |
BOXER FR
Drives: WRB BRZ Limited
i never owned an S2000 but I would advise you to not to buy the BRZ for it's "features". Navigation sucks, heated seats sucks, it`s loud, etc... If I`m honest, the S2000 is a better driving experience. If I were you, I would keep the S2000 to do your fun stuff with, and get an another nice comfy car. I can only afford one car that is kind of a middle ground of everything, but if I already had an S2000, it`s a no brainer for me.
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
#18 | |
Genesis feels sloppy in comparison Mustang GT is all power no finesse Miata is less power + better handling but I'd like to avoid another soft top. And this puts me in the same dilemma I'm in now The navigation doesn't bother me 100% as much because I know with cars like this selling the navigation to FRS owners who didn't pick one up won't be all that bad (so I'd imagine). I'm one of those twisted individuals that took a RWD sports car out in the middle of New Hampshire's worst snow storms... And loved it
#19 |
BOXER FR
forget what I said. you have two S2000s lol.
#20 |
Yea one has reached the point of no return... Stuck with it now
#21 |
BOXER FR
what about the new wrx or an evo mr?
#22 |
I HATE HATE HATE the wrx/sti platform... (I know I'm weird). Also I've driven a evo X and it simply has too much road presence to be considered a driver's car, albeit an unbelievable performer.
#23 |
So elite I'm 1338
Drives: WRB Subaru BRZ
Don't sugar coat it, we're all adults here. We can handle it. Tell us how you really feel. ![]() I have not driven the s2000, but if you're looking for an affordable RWD coupe the twins in my opinion are your best option. (perhaps the only option?)
-Jack Burton |
#24 | |
Now I just have to find out if it's worth buying a NEW BRZ limited or just find a used one for a few grand less
#25 | |
Drives: '14 WRB BRZ 6MT Limited
Here's a quick list off the top of my head of the most common issues with this platform: - Condensation in tail lights (Fairly common - heard rumors, these are no longer being replaced under warranty, after market fixes exist) - Oil leak from cam plate on rear of engine on manual cars (not common - aftermarket fix, can be done in driveway) - RPM drop and shudder (common prior to MY2014ish - fixed at dealer under TSB. Not to be confused with RPM drops at idle with AC on, this is a pretty common Subaru thing). - Crickets from high pressure fuel pump (common to all model years - three versions of the HPFP exist, none fix the crickets for sure, does not effect driveability, can only be heard at idle). - DI Seal failure (Possibly due to gaps left in transient fuel tables, not very common, occurs mostly in tracked or tuned cars. Apparently newer ECU revisions fix this issue. Has been quiet for a long time - since MY2013ish). - Axle failures (all examples I read about were on significantly lowered cars, fixed with aftermarket axles.) - Notchy transmissions / gear grinds (unclear how common it is, some people complain of notchy shifting or difficulty getting into 2nd when cold. Some transmissions have been replaced, sometimes fixed with better transmission fluid. Drive the car you intend to buy before you buy it, just to make sure things shift well. I think notchy transmissions are very common to budget sports cars). - Usual pops and rattles in the interior - its a budget sports car, you get what you pay for. - Issues connecting to Bluetooth (really hit or miss. I guess if you have a lot of contacts on your phone, it overwhelms the connection process and won't connect. Options exist to not transfer contacts and then issues are rare). Regarding track use - the car can be driven straight onto the track if you don't intend to go 100% and are ready to replace fluids immediately afterward. Otherwise, the usual for just about any car is needed (e.g. brake pads, fluid, good oils, and tires). The exception is for those tracking regularly in hot climates - an oil cooler is considered pretty mandatory. Several options are routinely used (OEM sandwhich cooler under oil filter, Jackson Racing external cooler). All in all, the BRZ/FRS is a great little sports car ripe for an owner who cars about the experience of driving and learning to drive better. The added bonus is decent fuel economy (6spd manual, I get about 30mpg on my commute and routinely over 30 on highway trips). The car is relatively comfortable for long trips or the commute, the speakers suck but can be tweaked to sound ok. Bluetooth means you don't even need to use the Nav (instructions from your phone read over speakers). In the end, coming from an S2k, you'll likely be underwhelmed (maybe even frustrated) by the engine but the trade off is a car more usable every day that can still go to the track whenever you want. And remember, you can fit four wheels and a jack in the car with the rear seat down - very useful. BTW, regarding new vs. used - depending on how you're buying, if you're financing and get a really low interest rate (< 2.00%) over 5 years, the savings of used over new approach negligible and you have the added benefit of being the only owner of the car. My advice is to find a car you can REALLY test drive. You'll really know if you'll like it once you push it a bit. |
#26 |
Drives: 2013 Subaru BRZ, 1991 BMW 318is
If you can find a used one I say let someone else take the initial depreciation hit. I picked mine up with 2k miles, saved 5k and ended up with a practically new car with a full warranty. Win win.
#27 | |
Overall probing the ft86 forum was enough to tell this is a good community to join on top of everything else
#28 | ||
Just doing research
Drives: 03 Acura CLS 6MT
Manchester Subaru usually has some decent pricing, and a few forum member from MA have bought from up there. Not much left down here for choice of colors on the 2014's unless you want silver or silver
| New to me daily driver.. 95 M3. | Dave-ROR | Other Vehicles & General Automotive Discussions | 58 | 07-17-2014 02:05 AM |
| STi to BRZ? Who Else Made The Switch? | Haole-Pino | BRZ First-Gen (2012+) — General Topics | 78 | 11-01-2013 06:02 PM |
| Need daily driver tire advice | bear89103 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-26-2013 01:15 PM |
| BRZ as daily driver? | Pakjk89 | BRZ First-Gen (2012+) — General Topics | 80 | 03-22-2012 09:50 AM |
