Old 08-26-2014, 03:53 PM   #15
ShadowTS
Drives: Toyota GT86 SWP
Revv the car for a second at a stop with the clutch depressed, and compare the smells, they are probably the same
ShadowTS is offline   Reply With Quote
Old 08-26-2014, 04:16 PM   #16
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
My car does this often. I take an on ramp that goes up a long and steep hill to get into San Francisco. My car smells a little funny almost everyday. My car just creeped over 10k miles.
GotBRZ1691 is offline   Reply With Quote
Old 08-26-2014, 05:52 PM   #17
kodyo
Drives: Scion FR-S
My car did this for the first 10k miles. I'm at 25k now and haven't smelt it in a while.
kodyo is offline   Reply With Quote
Old 08-26-2014, 05:59 PM   #18
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
For the first 10k miles, after spirited driving, mine smelled like burning rubber, but not exactly, not quite an oil smell either. Not the clutch since I have a AT and not brakes as they have a unique smell of their own. I'm told it may have been a substance called Cosmoline, that is sprayed on the car as a rust inhibitor that is burning off. I haven't notices it an several months so I guess my car is not new anymore.
BirdTRD is offline   Reply With Quote
Old 08-28-2014, 07:12 AM   #19
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
Sometimes I also got this unique smell after some spirited drive.
I am not sure whether this is clutch, brakes, tires or from the engine.
The smell is a bit light and as far as I remember nothing like clutch burnt smell.
gzpermadi is offline   Reply With Quote
Old 08-28-2014, 03:36 PM   #20
Used to get a weird smell every once in a while for no apparent reason. After I did the sound tube delete never smelt it again. Coincidence, maybe, but the timing was spot on.
Old 08-29-2014, 01:47 PM   #21
Jakecrow
Drives: '13 FR-S Raven Black
Have not had a chance to check the cam plate yet, but you're right the smell (if it happens) is the same when I do this.
Jakecrow is offline   Reply With Quote
Old 08-29-2014, 02:35 PM   #22
wbradley
Sarcastic SOB
wbradley's Avatar
I got a weird smell the other day after eating a can of Silverado beef chilli for lunch. Opened the windows and it went away.
The Following 5 Users Say Thank You to wbradley For This Useful Post:
BirdTRD (08-29-2014), JB86'd (08-29-2014), Luis_GT (08-29-2014), sklimo (08-29-2014), Tcoat (08-29-2014)
Old 08-29-2014, 02:44 PM   #23
I get a similar odour but use a different brand of chili! Wonder if there is a higher grade that will prevent the problem????? I found that you do have to open both windows though and be VERY sure to turn the A/C recirculate off or it just sticks around!
Wonder if there is a TSB out on this yet as sooo many people are likely having this same issue.
Old 08-29-2014, 02:46 PM   #24
wbradley
Sarcastic SOB
wbradley's Avatar
Had the recirc on and the power window override set to lock recently when my wife threatened divorce!!
The Following 2 Users Say Thank You to wbradley For This Useful Post:
Old 08-29-2014, 02:51 PM   #25
You sir are a brave, BRAVE man and I bow to you!
Old 08-29-2014, 03:53 PM   #26
johnnyfast11
Drives: none yet
30k miles sounds like clutch slipping. engine rotation at 7k is really fast with your tires gripping the ground resulting in more force needing to turn your drivetrain at higher rotational speed.
at 30k miles i'd upgrade the clutch. unless you got 400hp and you're burning tires. =D
if not then its cam plate. cam plate is easy $100 fix/upgrade.
johnnyfast11 is offline   Reply With Quote
Old 09-07-2014, 03:26 PM   #27
J-Money
J-Money's Avatar
Drives: GT-86
im at 20,000 Miles.. when i race it and rev high, it has a hot smell or a slight burning smell.
I used to do the same in my 98 Civic with 190,000miles. everytime i run up the RPMS it releases the same hot/ burn smell
J-Money is offline   Reply With Quote
high revving NA engine chuy21 Engine, Exhaust, Transmission 30 09-14-2014 07:33 AM
Slow Revving / Acceleration after TSB 0040-13 Hardway Issues | Warranty | Recalls / TSB 9 08-25-2014 10:14 AM
is it ok to drive without high revving? lionbacker54 BRZ First-Gen (2012+) — General Topics 48 08-07-2013 01:36 PM
Engine noise free revving or under load heeltoe86 Issues | Warranty | Recalls / TSB 4 04-29-2013 12:58 AM
Slow revving? Manual car. SprayedBigCube Engine, Exhaust, Transmission 40 07-10-2012 04:13 PM
