Old 08-20-2014, 09:35 PM   #15
PSJohnDoe
US market TRD lowering springs and front/rear sway bar kit. If you were asking about wheel spec, my post was the one with the picture attached.
PSJohnDoe is offline   Reply With Quote
Old 08-20-2014, 09:38 PM   #16
wparsons
wparsons's Avatar
Originally Posted by impossible View Post
Wot about 215/45/17 will there be any problem as i haven't made up my mind for further modification yet.
I wouldn't run a 215 on an 8" wheel personally, but running a narrower tire will never give you clearance issues.
Figure out what your end goal is, and spend the money once. Might mean driving with the stock wheels/tires for a few months, but it's a lot better than having to do the same thing multiple times.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
impossible (08-20-2014)
Old 08-20-2014, 10:24 PM   #17
PSJohnDoe
I agree completely, make sure your modification is helping you to meet a goal. For me I wanted lighter wheels, maintain stock feel, add a bit of rubber and clear my brake calipers without spacers. The brakes were to add thermal capacity for long canyon runs.
Old 08-20-2014, 10:37 PM   #18
impossible
Just wondering if i didn't do any setup of camber can i put the tires directly with 17x8 ET 45 mm and 225/45/17 on the stock spec no wheel rubbing or side effect? because i head people said although 225 will give u slightly faster lap time in reality daily driving there are no big difference?
impossible is offline   Reply With Quote
Old 08-21-2014, 04:24 AM   #19
PSJohnDoe
Tirerack.com recommends 235/40-17s with 17x8 on twins. They recommend 225/45-17 on 17x7.5. This makes sense since each half inch on the wheels adds approximately 12mm (keep in mind the wheel widths are not always exact). Running stock width tires on wheels that are around 15% wider doesn't make a lot of sense.
What are you going for when you change out the wheels? It may be better to get advice on how to accomplish your goal than whether or not a setup will be functional.
The Following User Says Thank You to PSJohnDoe For This Useful Post:
impossible (08-21-2014)
Old 08-21-2014, 07:06 AM   #20
impossible
I would like to get the best on lap times and handling. so i guess 225/25/17 will be the best for me??
Old 08-21-2014, 08:06 AM   #21
wparsons
wparsons's Avatar
No offense intended, but is your driving really at a level where 10mm difference in tire is going to make the biggest difference in lap times?
If you're really concerned about lap times, get 225/45/17 Hankook RS3's and be done with it. They're not as good of an all around tire, but will be much faster than the Pilot Super Sports.
You'll also need a lot more negative camber than stock to use those tires effectively though.
Unless you're actually racing and every tenth really matters, don't worry about lap times in the slightest.
How much track time will it see? What kind of track use?
I would suggest nice light 17x7's with 215/45/17's on them.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
impossible (08-21-2014), Jond63 (08-22-2014)
Old 08-21-2014, 08:43 AM   #22
DarkSunrise
DarkSunrise's Avatar
Get the 17x8 wheels. Probably the most versatile size for this car if you're near stock power. You can run anything from 215-235 width tires with no issues.
My current track setup is 215/45/17 tires on 17x8 wheels. Looks slightly stretched, but functionally works well. Feels very similar to stock, just more feedback, turn-in, and grip -- mostly due to the tires, not sizing btw.
I'm mounting 235/40/17 tires next.
2022 BRZ Build
2013 FR-S Build
Old 08-21-2014, 09:37 AM   #23
impossible
Really appreciate your advice. For me I will only go to track twice a month and the others time will be daily drive. Tenth seconds not really a big issue for me. Which I guess the pss 225/45/17 17x8 et45mm will do well with the job right? Cheers man
Old 08-21-2014, 10:15 AM   #24
wparsons
wparsons's Avatar
Yep, that'll work.
flickr
Old 08-21-2014, 09:14 PM   #25
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I'd go with 215/45-17 tires on lightweight 17x8 wheels if its mostly a daily driver. The one thing that kind of annoyed me with it being my daily driver was the 17x8 +36mm offset track wheel set having WAY TOO MUCH grip with only 215/45-17 Kumho XS installed. Handling limits were so extreme that it just was not even as enjoyable to drive as it was stock, unless it was wet. Went with a 205/45-17 Max Performance category tire (actually just a little wider than the stock tread width too!) and 17x7.5 +40mm offset wheel setup and Boy Howdy...that is just perfect daily driver setup for me! More grip than stock (dry and especially wet - and especially in high speed cornering) but low speeds are just as fun and even more tossable. The better acceleration/deceleration from the .3" shorter diameter tire really improves the responsiveness and the small drop in CG height seems to add a little more stability.
Seriously, yall need to try a 205/45-17 Max Performance tires on lightweight 17x7.5 wheels....feel like shackles are taken off the car and it's agility is cranked up to 11 (thanks to reduced weight, smaller diameter, and lower CG!). Only thing that would make it even better is dropping 10lbs unsprung weight a corner with an AP racing Sprint brake kit...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 08-23-2014, 12:57 PM   #26
Volo
Drives: 2017 BRZ PP
Originally Posted by Vracer111 View Post
...Went with a 205/45-17 Max Performance category tire (actually just a little wider than the stock tread width too!) and 17x7.5 +40mm offset wheel setup...
No offense but are you sure that you got your numbers right? I am not a tire expert but I know that 205 is less than 215 and that means that your tire width is 8.1" instead of the 8.5" of width that the stock tires have. If you have experienced performance, it could be due to lighter tires, but I am pretty sure you have less rubber on the road than before.
Volo is offline   Reply With Quote
Old 08-23-2014, 01:21 PM   #27
Vracer111
Vracer111's Avatar
Yes, the 205/45-17 Kumho Ecsta LE Sport has a tread width of 7.7" whereas the stock 215/45-17 Michelin Primacy HP has a tread width of 7.5". Tire section width is 8.1" and 8.4" respectively, but section width has little to do with anything other than wheel fitment and responsiveness - and the 205/45-17 Ecsta LE on a lighweight 7.5" width wheel is much more agile/responsive than the stock wheel/tire setup. Both tires weigh about the same, ~20lbs, but the smaller diameter, wider tread, and stickier compound of the 205/45-17 is what gives it a noticeable acceleration and performance advantage - at the expense of top speed (yeah...like I'm really concerned about top speed in my daily driver...LOL.)
Old 08-23-2014, 02:24 PM   #28
Volo
Drives: 2017 BRZ PP
Interesting. I was just looking at section width and neglecting the difference between section width and tread width. Thanks for the lesson.
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 12:31 AM
Desired Wheel Size, Width, Offset - OPINIONS CSG David Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 05-21-2014 12:02 AM
WTB (SoCal) 17" (width and offset can vary) wheels jonbonazza Wheels and Tires 0 02-28-2014 08:43 PM
Best Offset/Width for autocross? kuhlka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-19-2014 03:14 PM
235/40/18 on 8.5 rim width, all around. recommended offset? terenshu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-05-2013 10:27 AM
