#15 |
Drives: Asphalt FR-S
What's the advantage of a 2 inlet/1 outlet versus 1/1 system?
#16 | |||
Drives: 2013 Subaru BRZ
http://www.mishimoto.com/mishimoto-catch-cans.html Additionally, check with your favorite vendors for the best available pricing for this catch can. Quote:
The dual port can will function with systems utilizing a single CCV/PCV line and a single outlet to the intake. The three port can is intended for vehicles with two CCV lines. |
#17 |
Hey guys,
These new catch cans are now available for purchase! Check out the information below. Click any of the links to be redirected to our product page. ![]() Mishimoto Compact Baffled Oil Catch Can Product Specs
Tech Specs ![]() Images ![]() ![]() ![]() ![]() ![]() Catch Can Servicing Video [ame]http://youtu.be/K116LhLVap4[/ame] Product Build Log http://engineering.mishimoto.com/?cat=124 2-Port: Link 3-Port: Link Feel free to follow up with any questions! Thanks |
#18 |
We have had numerous requests for some form of a drain system which would allow the catch can to remain in place while fluid was removed. After some R&D, we now have an awesome addition to this catch can in the form of a drain valve kit! Check out the details below.
![]() Mishimoto Compact Baffled Oil Catch Can Petcock Drain Kit Product Specs
Tech Specs ![]() Images ![]() ![]() Feel free to follow-up with any questions or comments! Thanks -John |
#19 |
Mishi just getting better and better as a company.. been rocking your guys' rad on my bugeye rex for going on just south of a decade... nothing but performance. That's what I'm talkin about
#20 |
#21 |
Drives:
pic of my install:
![]() Changed up the install because of my Beatrush tower bar install. Flanges on tower bar ends would not allow for the use of the Mishimoto bracket...
#22 |
#23 |
Legend
Drives: BRZ Limited
How is this oil catch can under boosted applications?
#24 |
Our catch can is a sealed unit and will hold-up just fine on a boosted vehicle. We use this exact catch can in a variety of direct-fit kits for factory turbocharged vehicles such as the WRX/STi, EcoBoost Mustang, BMW N54, etc. Some boosted folks prefer to place a check-valve in-line with the PCV line to prevent any boost from reaching the crankcase, this would be the only potential modification for such an application.
Let me know if I can answer any additional questions! Thanks for the interest! -John |
#25 |
Drives: 2017 STi WRB
Sorry for bringing this thread back from the dead, I just got my mishi direct fit can for the brz, are the fittings supposed to be flush with the can when installed? I was turning them on and they were getting super tight so I left them a few threads off and I have a noise coming from the can. I didn't want to break the fittings buy cranking them further in. Should I just man up and turn them all the way in? Lol
#26 | |
Drives: 2015 Brz Blue Series
#27 | |
I tightened the fittings all the way in, seems OK. The small end of the hose should be for the pcv valve and the bigger end goes onto the catch can fitting. Also if anyone can answer, I still have a rattle type noise coming from the catch can area. I thought it was the baffle so I put some tape on it and the noise is still there. I noticed the bronze filter makes a rattle when I tap on it with my finger because its fairly loose inside it's fitting. Is this normal? Maybe this is the rattle/flutter noise I'm hearing? |
#28 | |
Drives: white-out FR-S
| Mishimoto Build Thread: BRZ/FR-S Silicone Induction Hose | Mishimoto | Engine, Exhaust, Transmission | 23 | 11-29-2018 11:35 AM |
| Mishimoto Build Thread: BRZ/FR-S Performance Cold-Air Intake | Mishimoto | Engine, Exhaust, Transmission | 90 | 12-03-2016 06:22 PM |
| FS:WA- ADD W1 REd Baffled Universal Aluminum Catch can | glamcem | Engine, Exhaust, Bolt-Ons | 0 | 07-05-2014 07:15 PM |
| mishimoto oil catch can mounting | jonbonazza | Engine, Exhaust, Transmission | 3 | 03-30-2014 02:13 PM |
| Win a Mishimoto Oil Catch Can! | Mishimoto | Announcements, Contests, Giveaways | 68 | 10-23-2013 05:27 PM |
