CANADA Canada
Old 08-09-2014, 11:24 AM   #15
caloriemate
Drives: Silver FR-S
Where's a good place to get a helmet in the GTA?
caloriemate is offline   Reply With Quote
Old 08-09-2014, 12:05 PM   #16
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
You'll need a 2005 or 2010 SA or M helmet
I got mine at Royal Distributing, but only got a M helmet because I'm a cheap ass
Edit: HJC CL-16
drewbot is offline   Reply With Quote
Old 08-09-2014, 12:07 PM   #17
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Like drewbot I just have an M2010 rated helmet. You only really need SA if you'll be in a car with a roll cage.
Any motorcycle shop will do
ToyoburuBRZ is offline   Reply With Quote
Old 08-09-2014, 02:19 PM   #18
wparsons
wparsons's Avatar
Originally Posted by n0thing View Post
That's great because given the stock power of our cars, I believe the "small" track is more appropriate.
100% agreed. I've driven the big track (not in my FRS), and found that with a lower hp car it's almost too long of a track.
I got mine at JRP, it was about $300 + taxes for an SA2010 (HJC AR10 II).
This! I bought an SA helmet just so my options are open (including rides in caged cars), but you can get an M helmet MUCH cheaper than SA. Mostly because motorcycle shops sell a lot more M helmets than specialty shops sell SA helmets.
flickr
Old 08-09-2014, 02:54 PM   #19
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Just sent the money
pushrod is offline   Reply With Quote
Old 08-09-2014, 08:26 PM   #20
caloriemate
Drives: Silver FR-S
Edit: HJC CL-16
Thanks - I was hoping I wouldn't have to spend another $400 just for a helmet
Old 08-10-2014, 09:53 PM   #21
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
@wparsons @brzr
How did bone stock twins hold up in the newbie's group? I'm assuming the sessions were short enough that there brake fade and fluid boiling wasn't going on? (Maybe by the afternoon with people getting faster, it could be?)
Just want to plan in advance if I need to be putting in RBF600 for the day, and also to make it back to Oakville safely the same night
Old 08-10-2014, 10:54 PM   #22
wparsons
wparsons's Avatar
All depends on how good of a driver you are on the track. On the old DDT, I could only get a few laps in without serious pad fade on the stock pads but sticky tires.
Typically you'll get pad fade before you boil the fluid with stock brake parts.
If you're running the stock tires, it won't be as bad, but if you're running stickier tires you'll want better pads/fluid to be safe.
All that said, if it's your first time ever on a track you might not have any issues even with all stock brake parts.
flickr
Old 08-10-2014, 11:37 PM   #23
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Yeah, that's why I was asking about bone stock twins
I've never driven THIS car on a road course (mostly karts actually), only a rackety MX-5 of days past
All in all, should be fun to wear out these Primacy's and OE pads
Old 08-11-2014, 03:01 PM   #24
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so long as you drive within your car's lowered limits
understand that your tires and brakes won't hold out for too long and regularly pull off for everything too cool and you shouldn't have problems.
when I first got the car I stayed out at MIR for 8 laps before realizing that I've probably should have pitted a lap or two before...
Old 08-11-2014, 03:19 PM   #25
Peschi
I sent my money yesterday and do not see my name (or anyone else's) where the confirmed names are to be posted.
Should I expect some sort of confirmation?
Peschi is offline   Reply With Quote
Old 08-11-2014, 03:44 PM   #26
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Give it a bit of time, it is a mere human being doing the entry
Last time with SPDA it took a couple days for them to post everything
Also, they will send emails through whatever email you used for PayPal (or that's what they did last time, at least)
Old 08-11-2014, 03:52 PM   #27
wparsons
wparsons's Avatar
Yep, the registration process is manual so it'll take a couple days.
Stock tires and brakes *should* be fine on the DDT, especially if you're running at beginner group speeds. The sessions are 15 minutes, so not too long.
If you do need to pull off, either stay on the track at cool down speeds (and stay off the brakes as much as possible), or pull right off and run circles around the skidpad area to keep air moving. Pulling off and stopping with hot brakes can make things much worse.
flickr
Old 08-11-2014, 04:04 PM   #28
Peschi
Thanks!
This is will be a first time track event for myself, will this be a point to pass and will they have cones for the apexes?
beginner friendly atts lapping day on may 24 brzr CANADA 54 05-26-2014 05:07 PM
May 18th Sunday Mosport new DDT lapping event 12-5pm, #4 Touge.ca event of 2014! Touge.ca CANADA 0 05-01-2014 11:17 PM
DDT lapping Sunday April 20. Mosport. Trac Toy CANADA 14 04-24-2014 08:01 AM
April 20th Sunday Mosport new DDT lapping event 12-5pm, #1 Touge.ca event of 2014! Touge.ca CANADA 0 04-05-2014 06:00 PM
Mosport DDT Lapping this Saturday - only 65 dollars! 7thgear CANADA 33 08-20-2012 05:49 PM
