Old 08-05-2014, 07:37 PM   #15
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Anyone tried the Parts shop max ones?
http://www.partsshopmax.com/page.php?59
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 08-05-2014, 07:42 PM   #16
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Well thanks for saving me spending some extra money and from getting that package
themajesticone is offline   Reply With Quote
Old 08-05-2014, 08:39 PM   #17
mike the snake
Have you had any catastrophic SPC Lower Control Arm failures?
The failed part you've posted here is clearly not a LCA, a completely different part, and I can't completely discount using SPC Lower Control Arms just because a different part of theirs might have failed.
I can understand as a seller, you might decide to not carry a brand because of failures, but have you had the actual SPC LCA fail catastrophically?
We recommend the SPL.
Stock will not fail, but it also has no camber adjustment.
SPL part next to a failed SPC part on one of our sponsored driver's cars.
Old 08-05-2014, 09:43 PM   #18
We have full access to the SPC line, and will sell if it someone insists, but we cannot recommend it. Given SPC's history of failures, we can't, in good faith, say that it's a top quality product. Google SPC upper ball joint failures on the S2000, Toe arm failures on the Z, camber arm failures for the G35, and tension arm failures on the 240SX.
Old 08-05-2014, 09:45 PM   #19
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
@CSG Mike
You know your stuff and I sure as hell am not trying to discredit you, but you said that the SPC LCA are $400. They are normally sold individually at around $100 each. On top of that, you failed to mention which version of the SPC control arms you were referring to. Yes the older style did have failures when the were sold for the WRX (I think). The newer ones are pretty much slotted OEM arms. It seems as though you were just bashing.
I have had my set for about 10,000 miles with no issues. I've autoX a few times and routinely run the mountain roads without issue....sooooo....ya.
Old 08-05-2014, 09:56 PM   #20
Originally Posted by boredom.is.me View Post
@CSG Mike
I'm not a sales person; I apologize for getting the prices wrong. It doesn't change the fact that SPC failures are widespread, even among street driven cars, or that they're normally sold as single pieces.
I've seen a LOT of SPC parts fail over the years, and will not recommend them.
Go to your local race alignment shop, and ask them for their recommendation on FRS/BRZ LCAs.
husker741 (08-05-2014)
Old 08-05-2014, 10:10 PM   #21
dp1
driving smoother faster
Drives: Sold
Also, isn't there a negative camber limit with SPC LCA? I went with SPL LCA to get -2.5 rear camber for track and to avoid potential SPC issues.
dp1 is offline   Reply With Quote
Old 08-05-2014, 10:13 PM   #22
TjAlmeida
SPL and do not look back. Amazing quality and light weight as well!
TjAlmeida is offline   Reply With Quote
Old 08-05-2014, 10:52 PM   #23
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Thanks for all the info. I decided to go with Cusco ones, since SPL couldnt be found shipped to Canada for less then 800, something I couldn't justify... Hopefully they are a bit better than SPC and Buddy Clubs, if not, my fault because you guys did provide alot of good info !
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 08-06-2014, 12:09 AM   #24
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I'd say SPL too seeing how you're only dropping the car about an inch and they make great products
If you were going lower, I'd recommend Stance LCAs. Reason being is because they lower the mounting point by 20mm which allows you to retain some of the travel you normally lose when lowering the car, AND they use aurora ends, which absolutely awesome quality. Expensive, yes. But worth it
TylerLieberman is offline   Reply With Quote
Old 09-09-2015, 09:05 PM   #25
tracerit
Drives: '13 SSM BRZ Limited 6MT
Bumping an old thread but the question is relevant. Aside from quality, are there any noticeable performance improvements going with a $540 SPL LCA compared to a $210 SPC LCA? I really just need the camber adjustment for my daily driver.
tracerit is offline   Reply With Quote
Old 09-09-2015, 09:21 PM   #26
Nope.
Sounds like SPC will be right for you
kodyo (09-09-2015), tracerit (09-09-2015)
Old 09-09-2015, 09:59 PM   #27
Calum
That Guy
Drives: 2013 asphalt FRS MT
How much camber adjustment do you need?
I'm running 12mm camber bolts in my inner lower control arm holes. I got half of a degree from each of them, which was perfect for me. The camber from the factory was a degree different from side to side. The bolts evened things out, leaving me at 1.5 degs.
The Following User Says Thank You to Calum For This Useful Post:
Old 09-09-2015, 11:15 PM   #28
tracerit
I'm at - 1.9 left and - 2.5 right for the rear. I was hoping to get them both to - 1.5 but even just bringing the right to - 1.9 or - 2.0 to match the left would be okay as that's still within spec.
Are these the bolts you're referring to?
http://www.ft86club.com/forums/showthread.php?t=33415
DME Lower Control Arms and DME Toe Arms - Review FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-24-2015 11:53 AM
Lower Control Arms DriftEightSix AUSTRALIA 18 05-03-2014 10:56 PM
PSM Lower Control Arms Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-26-2014 02:04 PM
Wtb: lower control arms natesparxxx Brakes, Suspension, Chassis 3 04-07-2014 07:29 PM
WTB: SPC LCA (Lower Control Arms) AG3NT_5CARFAC3 Want-To-Buy Requests 9 02-19-2014 01:30 PM
