#15 | |
FBKC = feed back knock control (coarse correction) FLKC = fine learning knock control. Your fuel trims LTFT are high, that will be as a result of the aftermarket intake upsetting MAF scaling. Car will probably drive a bit smoother if you did MAF scaling as trims are running around 10% and its best if they are less than or 5 % it will also keep the upper end AFR's closer to what the tuner set in the maps. The link in my signature will give you the info, but it will take a bit of learning and reading on your part if you want to do MAF scaling. Its not absolutely necessary though. |
#16 | |
Drives: Raven Scion FR-S
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#17 | |
#18 |
Maf scaling for aftermarket intakes is different for each car, the Openflash guys could do it for you as part of a custom E-Tune think they are $200
#19 |
Oh okay... U think it's dangerous to keep running this tune though? I have no idea how to custom tune even with the tutorial lol kinda scared to lol so I may either leave this tune or flash back to the other tune you told me that looked good the 1.59V
#20 | |
The other tune you logged was running ltft higher than 10% ,it should be ok it just not ideal, the intake is the issue not the tune you might as well run the v2.01 tune |
#21 |
Okay I may in the future get the Perrin CAI or maybe one that has better MAF readings not sure which ones are better than others
#22 |
Drives: UK GT86
Or just correct the MAF scale. It really isn't hard to do, or time consuming. There's a good thread on what to do a few below this. Hell, if you log the right stuff, I'll even do it for you.
.: Stealth 86 :.
#23 |
Drives: 2015 WRX
Might be worthwhile for @Shiv@Openflash to change the default channels that are logged. VVT Intake and Exhaust are not as important as FLKC and FBKC. Getting both of those set to default might make it simpler for end users to provide feedback without having to provide directions on how to change the default channels that are logged.
#24 | |
| My SWP BRZ...there are many like it, but this one is mine | mobybrz | Member's Car Journals | 1 | 02-16-2013 02:54 AM |
| GOT MINE! | xanth123 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-01-2013 11:20 PM |
| Not mine, but now it is (aka, another "got mine" thread) | brianbot5000 | Northwest | 2 | 07-01-2012 01:50 PM |
| Got Mine, Now Get Yours (One Available in GA) | dorkymork | BRZ First-Gen (2012+) — General Topics | 7 | 06-17-2012 02:29 PM |
| It's Mine! | ant08 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-30-2012 10:09 PM |
