Old 07-27-2014, 12:38 PM   #15
steve99
Drives: FT86
Originally Posted by ScionFR-S View Post
Hey Steve here is the new 2.01 map stage 1 93 octane
Hope this one is okay also :/ I have an afe intake btw
http://www.datazap.me/u/mikemac/v201...t?log=0&data=1
THANKS SO MUCH AGAIN!
Looks ok AFR at higher RPM ok, does not appear to be any knock problems but you rearly need to ditch the vvt intake and exhaust parameters your logging and replace them with "Knock Correction FBKC" and FLKC. You can change these on tablet. their is a youtube tutorial on that.
FBKC = feed back knock control (coarse correction)
FLKC = fine learning knock control.
Your fuel trims LTFT are high, that will be as a result of the aftermarket intake upsetting MAF scaling. Car will probably drive a bit smoother if you did MAF scaling as trims are running around 10% and its best if they are less than or 5 % it will also keep the upper end AFR's closer to what the tuner set in the maps.
The link in my signature will give you the info, but it will take a bit of learning and reading on your part if you want to do MAF scaling. Its not absolutely necessary though.
Old 07-27-2014, 02:12 PM   #16
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Okay I'll definitely give this a shot !
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 07-27-2014, 02:12 PM   #17
ScionFR-S
ScionFR-S's Avatar
Originally Posted by Shiv@Openflash View Post
@steve99, it's great that you are so willing to help others. It's a great little community we have here thanks to people like you (and td-d, etc,.). Hats off to you mate!
Hey shiv anyway you are able to do the maf scaling or does the oft user do this on his/her own ? Will the non beta version possibly fix this ??
Old 07-27-2014, 02:16 PM   #18
steve99
Drives: FT86
Maf scaling for aftermarket intakes is different for each car, the Openflash guys could do it for you as part of a custom E-Tune think they are $200
Old 07-27-2014, 03:00 PM   #19
ScionFR-S
ScionFR-S's Avatar
Oh okay... U think it's dangerous to keep running this tune though? I have no idea how to custom tune even with the tutorial lol kinda scared to lol so I may either leave this tune or flash back to the other tune you told me that looked good the 1.59V
Old 07-27-2014, 03:18 PM   #20
steve99
Drives: FT86
The other tune you logged was running ltft higher than 10% ,it should be ok it just not ideal, the intake is the issue not the tune you might as well run the v2.01 tune
Old 07-27-2014, 03:53 PM   #21
ScionFR-S
ScionFR-S's Avatar
Okay I may in the future get the Perrin CAI or maybe one that has better MAF readings not sure which ones are better than others
Old 07-27-2014, 05:21 PM   #22
Kodename47
Kodename47's Avatar
Drives: UK GT86
Or just correct the MAF scale. It really isn't hard to do, or time consuming. There's a good thread on what to do a few below this. Hell, if you log the right stuff, I'll even do it for you.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-27-2014, 05:57 PM   #23
Malt
Drives: 2015 WRX
Might be worthwhile for @Shiv@Openflash to change the default channels that are logged. VVT Intake and Exhaust are not as important as FLKC and FBKC. Getting both of those set to default might make it simpler for end users to provide feedback without having to provide directions on how to change the default channels that are logged.
Malt is offline   Reply With Quote
Old 07-27-2014, 08:13 PM   #24
ScionFR-S
ScionFR-S's Avatar
Totally agree!! Anyway this can be an option somehow or make it a default in the ofm
My SWP BRZ...there are many like it, but this one is mine mobybrz Member's Car Journals 1 02-16-2013 02:54 AM
GOT MINE! xanth123 Scion FR-S / Toyota 86 GT86 General Forum 7 02-01-2013 11:20 PM
Not mine, but now it is (aka, another "got mine" thread) brianbot5000 Northwest 2 07-01-2012 01:50 PM
Got Mine, Now Get Yours (One Available in GA) dorkymork BRZ First-Gen (2012+) — General Topics 7 06-17-2012 02:29 PM
It's Mine! ant08 Scion FR-S / Toyota 86 GT86 General Forum 8 05-30-2012 10:09 PM
