#15 | |
Drives: Asphalt FRS
Can't be. I have been running BP 93 since new. I have not had crickets in over two years.
#16 | |
#17 | |
Drives: '13 Ultramarine
No offence taken. If I ever get around to picking up a tuner/tunes, or the ability to data log by some other means, I'd be very interested to see what it shows. It's definitely not the placebo effect...the difference is audible. To such a degree, that I put up with the crickets to run 94. Damn crickets...
#18 |
Drives: 14' FRS 6MT; 16' WRX 6MT
Holy shit, Cottage Grove!? Where do you get gas and where can I find it?
Anyway, the crickets are definitely intermittent for me and aren't really that loud even with the window opened at a drive through it's usually going in and out. Maybe the crickets don't have anything to do with fuel quality but this was only something I noticed once I put in 93. Not a causation but to me felt like some sort of correlation. I don't have the balls to go back and put in 91 Octane just to see if the crickets will disappear but I'd be willing to drive to find some ethanol-free 93 Octane. Any tips on winter driving this car bro? Last winter scared the shit out of me and I don't know what to expect with this car. |
#19 | |
Drives: Asphalt FRS
I always get my 93 at BP. I have driven the car through two winters now. Its not the greatest, but I managed. Do you have winter tires? That's a must. And I am going to try sand bags this year to see if that will help.
#20 |
Drives: 2013 Asphalt FR-S
Air temperature rises as it is compressed. The FA20 has 12.5:1 compression ratio, which is very high. This leads to the need for fuels that can withstand higher compression/temperature before self-igniting. Our engines are designed to work with high octane gas.
I really don't think $2-3 extra every full tank can do that much of a damage to anyone's bank account. Take care of your car, buy her expensive things ![]() Just my 2 cents. If you don't like it, throw it right back, I'll use it to buy more premium gas for my car. Dramatic exit:
You can never repeat the past, but you can always be inspired by it.
#21 | |
Drives: BRZ Pearl White
Seriously, at 1,000 metres elevation you cannot get more power from this engine by using 94 until you supercharge it. |
#22 | |
The engine is designed for 93 but at sea level air pressure. Only at seal level with 93 will it produce 200 bhp. The higher you are the less it matters. |
#23 |
I think this a great question. We would probably be able to figure this out relatively inexpensively. I think if we were to dyno a car on 91octane and make 3 passes on it and use a fixed standard such as the SAE correction or Standard correction etc we would have a quality baseline. Then we have the same car and make sure there is no more 91 remaining in it and do what you need to do to get 93 or a 93 mix and run the car on the SAME dyno and with the same correctional factor SAE or Standard etc. and we should have some high quality data (accurate)
#24 | |
Drives: 2010 WRX (sold) 2013 brz
| How to run E85 on stock 86 BRZ FRS with OFT tune | steve99 | Software Tuning | 741 | 06-27-2022 05:06 PM |
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 02:01 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 01:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 12:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 12:50 AM |
