| Mid-Atlantic DC, DE, MD, VA, WV |
#15 |
Drives: 2013 Whiteout FR-S
07/09/2014 07/23/2014 08/06/2014 The location for the next is posted in a semi-professional way below!* Meet location: Revolution Bar and Restuarant. (Formerly known as Fast Eddies) Address: 9687 Fairfax Boulevard, Fairfax, VA 22030. Time: 7:00PM We usually get there a little before 7 traffic dependent and walk in weather dependent.
#16 |
Ask for Marcus Ahmed or Matt or pretty much anyone over there that should be able to help you out with a quick run thru of the car
| The Following User Says Thank You to kanundrum For This Useful Post: | IloveBaldEagles (07-23-2014) |
#17 |
Drives: Gray.
Marcus here. I look forward to meeting you on Wednesday! (?today)
#18 | |
Ultimate Member
Drives: 2014 Satin White BRZ
I still need to come out to one of these meets, But I have class on Wednesdays
![]() Maybe I'll just skip a day ![]() Quote:
#19 |
Drives: 2013 Asphalt FR-S (DD), 05 EVO V///
Basically just check for leaks, rust, make sure suspension components are in tact. Compression/leak down test if you're up for it. I have a compression tester I can lend if needed.
#20 |
Drives: Scion FR-S in Whiteout
| The Following User Says Thank You to discretion For This Useful Post: | IloveBaldEagles (07-24-2014) |
#21 |
Drives: Gray.
Always man. Look forward to meeting you!
| Any good stereo installers in NY area that have worked on the frs? | mikeg7827 | NY / NJ / CT / PA | 18 | 09-09-2013 11:07 PM |
| KEG LYPH MAFYA Flip Key - WORKED | Lverasky | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 09-05-2013 06:53 AM |
| Car wouldn't start, and then nothing changed and it worked fine...wtf | Spicer66 | Issues | Warranty | Recalls / TSB | 10 | 12-22-2012 11:25 AM |
| Track Video: BRZ Passes worked Miata, unable to be passed by prepped s2000 | gmookher | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 11-06-2012 02:01 PM |
