Old 07-09-2014, 09:58 PM   #15
504
504's Avatar
Drives: 2014 86 GTS
Originally Posted by Dezoris View Post
I keep saying this but there is a manufacturing variance in these transmissions. What works well in some transmissions does not work well in others. Unfortunately you won't get a straight answer.
If your trans is very resistant to shift 1st to 2nd to 3rd and you are in a colder area Pentosin is a VERY good option to test. If you are getting notchiness when warm or problems with 4-5 or 6th it probably won't do anything.
Also we're forgetting the biggest variable of them all; the driver. The "performance" of the oil is all feel and opinion of the user and after dumping 100 bucks and a couple hours of time replacing fluid with something name brand, its easy to let placebo effect skew opinion on how well the oil is actually working. I think the quoted bit in bold is a fair assumption as peoples results have been fairly consistent with that statement
504 is offline   Reply With Quote
The Following User Says Thank You to 504 For This Useful Post:
Dezoris (07-09-2014)
Pentosin MTF2 Calum Engine, Exhaust, Transmission 10 12-09-2014 07:43 PM
Pentosin MT and Redline UOA After Track Supercharged Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 45 10-01-2013 12:02 AM
FS: Zeta air tube, hks drop in, & Pentosin chappys4life Mid-Atlantic 14 05-24-2013 12:58 PM
Pentosin mtf2 and approaching hot climate bdanisi Engine, Exhaust, Transmission 1 04-20-2013 10:48 AM
Looking for Pentosin MTF-2 in Ontario? wtout86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-26-2012 07:07 PM
