Old 12-24-2014, 09:17 AM   #15
CoupedUpSubie
Drives: 2013 BRZ Limited
Originally Posted by Reaper View Post
Nope. And wrx guys are swapping our parts into their cars. Max hp on a di only wrx is 400hp without our PI. Starter is on the wrong side, exhaust is on the wrong side, turbo won't fit in the factory location, ecm/wiring harness doesn't swap over because of the canbus, intake manifold won't work...the list goes on.
http://www.ft86club.com/forums/showthread.php?t=79549
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 12-24-2014, 09:29 AM   #16
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I'd rather just buy a turbo kit and build up the motor a bit.
It could be done for about 15k-ish depending on how extensive the build is and how much of it you are capable of doing yourself:
Turbokit: $5,000 ish
Clutch: $700 ish
Full Exhaust: $1,000 ish
Oil Cooler: $700 ish
Injectors: $500 ish
Boost, Oil Temp, Wideband: $1,000 ish
Tuning: $1,500
Pistons: $600 ish
Rods: $800 ish
Head Gaskets: $400 ish
Valve Springs: $250 ish
Head Studs: $300 ish
DSS 600hp Axles: $1,000
Fuel Pump: $150 ish
Total for all of that runs $13,950 and I aimed high on quite a few items. Some of that can also be aruged whether or not you'd even need it, I suppose.
I would just run a 2871R with the supporting mods on stock internals and shoot for around 300whp and call it a day.
TylerLieberman is offline   Reply With Quote
The Following 3 Users Say Thank You to TylerLieberman For This Useful Post:
AVodka14 (12-24-2014), GT86_PRAGUE (12-30-2014), Reaper (12-24-2014)
Old 12-24-2014, 10:03 AM   #17
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Originally Posted by CoupedUpSubie View Post
Yeah they had to rebuild the factory turbo kit to make a factory turbo motor fit. They even posted the intercooler and turbo didn't fit. Also the fa20dit will not make as much power as a turbo fa20. The di simply will not flow enough fuel. FullBlown is making an intake manifold to convert a fa20dit back into a fa20 to make more power.
Old 12-25-2014, 03:55 AM   #18
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I thought they were using a FA20 fueling system for a PI/DI hybrid system on the WRX, is that including their new manifold?
Old 12-25-2014, 06:29 AM   #19
10Stars
Drives: 14 Subaru BRZ Limited WRB
Thumbs up
Interesting I had no idea.
I always wondered why the FA20DIT made so much more torque than the FA20.
10Stars is offline   Reply With Quote
Old 12-25-2014, 09:51 AM   #20
Dipstik-sportech
Dipstik-sportech's Avatar
You couldn't figure out why a turbod version of an engine made more torque than its naturally aspirated cousin?! Really!?
The Following 3 Users Say Thank You to Dipstik-sportech For This Useful Post:
D_Thissen (04-07-2016), pushrod (08-07-2017), wparsons (03-09-2015)
Old 12-25-2014, 10:02 AM   #21
10Stars
Sorry I should have been more specific.
I meant when the FA20na has forced induction(turbocharged) vs FA20dit
Old 12-25-2014, 10:06 AM   #22
Dipstik-sportech
I meant when the FA20na has forced induction vs FA20dit
Not sure where you're getting that info either but OK.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Koa (12-29-2014)
Old 12-25-2014, 10:41 AM   #23
10Stars
I mean I could totally be wrong but I seem to recall stock Fa20dit's making solid torque numbers on a dyno even in stock form?
I'd love to hear your opinion on it though since you have one hell of a brz
The Following User Says Thank You to 10Stars For This Useful Post:
Dipstik-sportech (12-25-2014)
Old 12-25-2014, 11:36 AM   #24
Dipstik-sportech
The fa20dit is rated at 258ftlbs at the crank stock. The last fa20 turbo fbm did on a stock exhaust made 266ftlbs at the tire, so that's over 300 at the crank.
Old 12-25-2014, 05:17 PM   #25
10Stars
Good to know, thanks man.
Old 12-25-2014, 06:40 PM   #26
Dipstik-sportech
Sorry I come off as a **** most times lol
The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post:
10Stars (12-25-2014), D_Thissen (03-19-2015)
Old 12-26-2014, 07:29 AM   #27
s2d4
s2d4's Avatar
This reads more as adding PI to a much larger DI system than FA20 to begin with. It may end up being a better system than the fa20 because of this.
I definitely would have much preferred a much bigger DI system, especially when E85 is much better with DI. The majority of 86 owners wants less than 400, this would've been perfect as no need for fuel pump+ bigger PI injectors for just about everyone but the "big" turbo straight line guys.
The Following User Says Thank You to s2d4 For This Useful Post:
cdrazic93 (12-27-2014)
Old 12-26-2014, 09:56 AM   #28
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Originally Posted by horrorbiz View Post
It won't fit. The turbo would be too low.
How do we know this?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
FA20 or 4U-GSE ??? WesFRS Engine, Exhaust, Transmission 2 04-25-2013 04:17 AM
VM vs FA20 CAi speedtrip Engine, Exhaust, Transmission 0 02-05-2013 12:34 PM
4UGSE/FA20 engine or swap? jordydiaz Scion FR-S / Toyota 86 GT86 General Forum 15 04-04-2012 06:00 PM
HKS s/c FA20?? Rome Scion FR-S / Toyota 86 GT86 General Forum 6 04-04-2012 12:13 PM
