Old 07-07-2014, 11:52 AM   #15
Purdue FR-S
Boiler Up!
Purdue FR-S's Avatar
Drives: 2018 BRZ tS
Just out of curiosity, is there any correlation between changing trans fluid and having these noises? Are all incidents with stock fluid?
Purdue FR-S is offline   Reply With Quote
Old 07-07-2014, 12:05 PM   #16
Roarke
Drives: Subaru Brz 2014
Im using stock oil..
Roarke is offline   Reply With Quote
Old 07-07-2014, 02:56 PM   #17
sero901
sero901's Avatar
Drives: 2014 Scion FRS
Are the replacement transmissions the same as stock or is there an updated one going back in?
sero901 is offline   Reply With Quote
Old 07-07-2014, 03:51 PM   #18
Model Citizen
Lacking brains
Drives: frz
My noise went away after changing transmission fluid to motul.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 07-07-2014, 04:19 PM   #19
nelsmar
Ive been down this road as well. I hadn't used 3rd to 4th let alone 4th very much at all for the first 10k miles of my car. 5k miles in I noticed 4th crunching and it started to get pretty bad by 7k or so. The dealer noted it and around 5 or 7k miles. I had the dealer mark me having issues multiple times with the car being completely stock. Eventually I switched to motul and it was noticeably better. It took a few hundred miles before it felt better and then a few thousand miles later I had switched back to OEM fluid to see how it felt and it instantly felt horrible. It took a while for Toyota to agree to warranty it. The at first said it was normal even though it did it at every single shift (100% of the time!!!) at 3,800+RPM. This is below highway speeds! They said to just shift below that. After the dealer talked to the regional service head he got them to agree to replace it. The new transmission had grinds from 0 miles on the first test drive. I put Motul in it immediately after and it seems to be getting better. My girlfriends car has the same issue but going into third gear. We swapped in Motul and the issue got significantly better within 100-200 miles. She had ~ 3,500 miles on the car at the time.
Just as the OP I have never had transmission issues before. Even on my S2000 that I thoroughly abused I sold it at nearly 80,000 miles with the OEM clutch (people commonly replaced them at 40-60k) and it felt brand new. I am extremely easy on my transmissions and clutches.
On this topic I was told that Toyota has put a halt on transmission replacements at this time and is further investigating the issue. I was told I received one of the last transmissions.
My flickr - Canibeat
Local magazine scout
Old 08-02-2014, 04:34 PM   #20
Trmx2
Trmx2's Avatar
Drives: 2014 Raven FR-S 6spd
Originally Posted by NissanGuy View Post
Forgive me for OT, but: That door rattle kills me. Do you remember what they did?
Wow, sorry for not seeing all these posts. I went back twice for the door rattle, mine STILL does it a little bit. I told them however to go ahead and stick sound dampening tape underneath the window controls, and around the door speaker assembly. It is MUCH better now, it will only rattle if you have obnoxious bass blasting. So it's much, much more tolerable now. I can actually listen to music and crank it and it's fine.
Trmx2 is offline   Reply With Quote
Old 08-02-2014, 04:40 PM   #21
Trmx2
Trmx2's Avatar
Originally Posted by Pcharliep04 View Post
can you post paper from toyota as far as receipt describing the details ??
Unfortunately no, they didn't give me a detailed paper. I could give you the service paper the tech gave to me? It doesn't state much other than the labor codes and such.
I had stock fluid in mine, and still do with the new transmission, I will be replacing the oil very soon though. Most likely Motul.
I think it was the same as stock, I still get the 1st gear "clunk" which I think is actually normal. Also, 1st-2nd gear is a bit harder to get into when the transmission is cold, needs some love....lol but so far have not had any issues.
Oh wow, I did not know this. Crossing my fingers that this transmission doesn't give me issues later on.....thanks for the input!
Old 08-02-2014, 06:12 PM   #22
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
my 2015 BRZ at 800 miles does has the snapping noise...with heavy load (4k-5k) shifting up hill. i was wondering what heck was that. i had been driving stick for 15 years!
Speed2th is offline   Reply With Quote
Old 08-04-2014, 06:06 PM   #23
captainzib
Oompa Loompa of Science
Drives: Scion FR-S
You know what really grinds my gears?
When I shift from 3rd at high rpms into 6th. WTF is going on?
About 21k miles right now.
captainzib is offline   Reply With Quote
Old 08-04-2014, 07:29 PM   #24
orangeblue
Drives: Whiteout
Originally Posted by Trmx2 View Post
I know I feel the same way, I love the car but feel that their R+D was not thought out enough and they skimped a bit on some parts to limit cost. A few people I know have had this problem, it's slightly different to the problem people were having with 1st-2nd gear being difficult and clunky. This noise is a rather loud "crunch" reminds me of when your knees and joints crack and crunch.
The only mod I have that is relatively transmission related is the Perrin Shifter Bushing. The dealership did NOT complain about that part and said it had nothing to do with the transmission issue. So that may be music to some peoples ears who have that concern.
As for the transmission, I live in South Florida and went to Weston Toyota and have had bad luck with them until I filed a complaint. Since filing the complaint they have fixed every issue I've had including the speaker rattle from the doors when you listen to anything with any Bass in it.
Good luck! My advice is to take it in! If they cover it under warranty then you get a brand new transmission!!!
I had mine replaced last summer by Deerfield Toyota. If you don't like driving out to Weston, you might give them a try.
I had crunching from 3-4 and 5-4. Stock fluid and and replacement fluid made no difference.
orangeblue is offline   Reply With Quote
Old 08-05-2014, 09:03 PM   #25
Skidrcn
Drives: 2013 Hot Lava FRS
I'm at 14k miles on my car and just went to the dealer because 3-4 and 5-6 are crunching. They told me it is more common now and that my new trans will be here in 2-3 days. So needless to say I am happy that it is getting fixed!
Skidrcn is offline   Reply With Quote
The Following User Says Thank You to Skidrcn For This Useful Post:
captainzib (08-05-2014)
Old 08-07-2014, 08:36 PM   #26
ChirpnGrind
Drives: 2022 Halo GR86
Problem is, they replace it with the same crap transmission so you get to go through this all over again-- right around the time your warranty expires.
ChirpnGrind is offline   Reply With Quote
Old 08-08-2014, 09:27 AM   #27
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Originally Posted by WNDSRFR View Post
I got a new transmission because of a fifth gear grind.(Syncro)
I've had the new one for a few months now and no problems at all. It is much smoother through all the gears than the first one. It doesn't even clunk going into first.
This has concerned me for a while. It's my first stick and I wasn't sure if the clunk going from N to 1 was normal. Should I be concerned? This transmission just sounds noisy as hell.
Frishkorn is offline   Reply With Quote
WTB TRANSMISSION boostedfrs Want-To-Buy Requests 17 07-24-2014 07:46 PM
6 Speed Manual Transmission 11k Miles JoeDrifter Transmission and Driveline 10 05-24-2014 02:15 AM
Transmission just doesn't feel right (since day 1 bought with 83 miles) GhostShield Issues | Warranty | Recalls / TSB 90 04-15-2014 07:51 PM
Transmission? Pplater AUSTRALIA 1 06-05-2012 07:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
