Old 06-25-2014, 11:16 PM   #15
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by BadBRZ View Post
You can register it at my place in texas ;-P
Old 06-26-2014, 02:04 AM   #16
SPCorBUST
SPCorBUST's Avatar
Thank you sir, but its not an AGP kit, just the turbo. i'll have updates on my build as it progress' dyno is tomorrow..
SPCorBUST is offline   Reply With Quote
Old 06-27-2014, 04:42 AM   #17
SPCorBUST
SPCorBUST's Avatar
Thought I had the injectors sorted, but I guess not. Seems like I fubarred the install on the passenger side, as there is a vacuum leak sound coming from there. I'm gonna pull them again and take a look, but any hints as to what I should be looking at? I figure the top is fine since its not leaking fuel, but maybe those rubber seals at the bottom weren't working properly due to install error, deterioration, some other reason, or all of the above. Truth be told, I'm a total noob at injectors, this was my first go at it.
Old 06-27-2014, 04:46 AM   #18
SPCorBUST
SPCorBUST's Avatar
Funny thing, I was getting P0171 (IIRC) for lean condition and I thought it was just the 2/3 91 and 1/3 E85 I was burning through (E85 was remnants from my FlexFuel tune, leftover that I hadn't burned off before I put the 91 in) so I thought it was fine. 6 gallons later its still lean, so I try the MAF cleaning but that didn't work. Pretty convinced its a vac leak at the injector bottom, but hoping for input from some of the gurus!
Old 06-27-2014, 05:00 AM   #19
BadBRZ
Drives: Subaru
i can't help you on this, but i wish you the best of luck mate.
Have you checked out dezoris' install video?
BadBRZ is offline   Reply With Quote
Old 06-27-2014, 02:16 PM   #20
andrew20195
Drives: 2013 Subaru BRZ
Assuming you didn't pull the manifold to change injectors, the only thing it could be is the injector grommets. A vacuum leak would definitely cause a lean condition at all times. If you have the means to do real time datalogging, you can spray a can of brake cleaner in the suspected leak area and watch the A/F Correction. If there's a leak, it will decrease (due to the richer mixture)
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
SPCorBUST (06-29-2014)
Old 06-27-2014, 05:34 PM   #21
SPCorBUST
SPCorBUST's Avatar
Yeah, I did not pull the manifold, just the rail. It's a noticeable sound, I've never had a leak there before it's interesting, annoying and troubling all at once. I was planning on purchasing those rubber grommets from the dealer today.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
Old 06-27-2014, 11:36 PM   #22
SmsAlSuwaidi
Boosted
Might be the vacuum lines, do you have them zip tied?
Old 06-27-2014, 11:38 PM   #23
SPCorBUST
SPCorBUST's Avatar
Yep. Went through and did several checks. Ordered the grommets and o rings, should be here next week Wed or Thu. Pulling them tonight to have another look.
Old 06-29-2014, 12:13 AM   #24
SPCorBUST
SPCorBUST's Avatar
Pulled them, it looks like its the injector grommets that are bungled.
Old 06-30-2014, 09:41 AM   #25
BadBRZ
Drives: Subaru
GOOD TO KNOW
Old 07-09-2014, 11:54 AM   #26
SPCorBUST
SPCorBUST's Avatar
Just an update in case anyone else comes across the issue, from the fuel rail side moving down into the manifold, the large rubber grommet that sits at the middle step solved all of my issues. The injector now seats properly and I do not have the myriad number of codes associated with the vacuum leak and subsequent leaning on that side.
Stock fuel injector o-ring material? CaptainSlow Engine, Exhaust, Transmission 0 05-21-2014 10:48 AM
Greddy Intake System / 5 in Stock / Free Overnight Shipping / Order Now!! rickspecd Engine, Exhaust, Bolt-Ons 11 07-12-2013 11:50 AM
Pre-Order A Beautiful Invidia N1 Exhaust! Magnaflow In Stock! Special Price Inside! KronosPerformance Engine, Exhaust, Bolt-Ons 45 09-16-2012 12:54 PM
Estimated delivery based upon order date vs. order at dealership? bloomy116 BRZ First-Gen (2012+) — General Topics 3 04-05-2012 11:51 PM
