Old 07-03-2014, 12:26 PM   #15
xxscaxx
Drives: 2013 SWP BRZ
if you want something a little cleaner looking for the flex fuel sensor, you should put it on the abs lines like I did.
just used some line clamps with rubber to protect the lines, and some bolts/nuts to hold it in place.
Not saying your spot isn't good, I like how you made a bracket to hold it instead of drilling into the panel. If you keep it there you should round out the top of that bracket and paint it black so its a little less noticeable
xxscaxx is offline   Reply With Quote
Old 07-08-2014, 11:12 AM   #16
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Good spot man !! Very clean look, We are grinding and painting all of our brackets as we speak. Going for a very clean factory look, will update at the end of the week
No Limit Motorsport is offline   Reply With Quote
Old 07-08-2014, 12:46 PM   #17
Dezoris
Dezoris's Avatar
Are camber plates are installed wrong or on the wrong side?
Toekneehair's BRZ Full Blown Turbo build toekneehair Member's Car Journals 26 01-22-2014 04:08 PM
No Limit Motorsport LeeMaster User/Vendor/Sponsor Reviews, Feedback, Comments 6 05-17-2013 12:16 AM
Whitefrs's Full Blown Stage 1 base kit build whitefrs Member's Car Journals 9 03-28-2013 03:22 PM
