Old 06-22-2014, 08:17 PM   #15
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Actually, i got to my laptop back at the hotel. Check your email... you now have a revised map
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
dejxx (06-23-2014), mkivsoopra (06-22-2014), Vroomin86 (06-01-2015)
Old 06-23-2014, 09:05 AM   #16
dejxx
dejxx's Avatar
Drives: FT-86
Thanks a lot Shiv!!! all fixed here! i went and tight the bolts just in case, but the new map fixed right away! Amazing customer support!!! sorry to bother you on your vacations with the wife!!! Take care and thanks again!!!
dejxx is offline   Reply With Quote
Old 06-24-2014, 03:18 PM   #17
dejxx
dejxx's Avatar
Drives: FT-86
So... Shiv, i got the CEL Error again, even after reflashing with the map you sent me, and tightening the bolts. Problem is.. Im in the middle of the road, and i have a 1.000km trip ahead of me. So right now im reflashing again with the same map. Please advice on what should i do!!! Do i need to reflash everytime, or should i just go to diagnostics and erase the code? (Same as before). Thanks
Old 06-24-2014, 03:31 PM   #18
victorb
Drives: Black 86
I think there's a leak somewhere
victorb is offline   Reply With Quote
Old 06-24-2014, 04:03 PM   #19
J_kennington
Drives: 2013 asphalt scion FRS
Just erase the code until you get wherever you are going...there's no need to reflash when you can just erase the code.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-24-2014, 04:37 PM   #20
Shiv@Openflash
Drives: 2013 FRS
No need to keep reflashing the ecu. As other said, you can just clear the code. But are you sure you are seeing the P0420 and not something else?
Old 06-24-2014, 07:23 PM   #21
dejxx
dejxx's Avatar
Drives: FT-86
When i go to clear error code, P0420 pop ups. Just stopped for today, and no CEL yet after the reflash i did on the road. If it pops again ill clear it, and will check for leaks again.
Dumb question, but is it possible that the fuel (98 RON, but it has 20% alcohol...) ita the one causing this?
Old 06-24-2014, 07:27 PM   #22
Shiv@Openflash
Drives: 2013 FRS
The P0420 code is disabled in the ROM file I sent you. So if you are still getting it, it's likely you didn't load the file correctly
P0420 should have nothing to do with fuel formations or exhaust leaks.
Old 06-25-2014, 02:34 PM   #23
dejxx
dejxx's Avatar
Drives: FT-86
Mmmm im a noob with this stuff... Heheheh
I deleted the file from the OFT then uploaded the one you sent me. Close everything, pluggued into car, tunning, selected the file (it has a * next to it) and write it. Anything i did wrong? CEL did come back this morning, cleared it, drove 600km and didnt got it again... So far. Hhhehe
Old 06-25-2014, 06:58 PM   #24
steve99
If it the pO420 cat efficiency code again then you have not flashed the correct file or shiv stuffed up , highly unlikely .
Try erasing all the tune files from oft then just load the one shiv sent you, might be worth changing the file name on the one shiv sent you so you definitly know you loaded and flashed correct file
If you loaded correct file that pO420 code cannot come up
Old 06-25-2014, 07:11 PM   #25
Malt
Drives: 2015 WRX
The * just tells you what map slot was flashed to the car previously, not which map. If you change maps around it will still show the old slot flashed with that *.
Malt is offline   Reply With Quote
Old 06-25-2014, 07:55 PM   #26
dejxx
dejxx's Avatar
Drives: FT-86
OK thanks for the advice guys! ill reload the map onto the OFT tomorrow and flash the car again just to be sure. Lets hope that fixes it!
Old 06-25-2014, 08:03 PM   #27
fast_dude
Drives: 2014 Scion FRS
wrong thread.
2014 Scion FRS- Kw2 suspension, Openflash headers, Openflash tablet, Invidia N1 exhaust, Invidia Overpipe, Nameless catted front pipe, TRD intake, Enkei RPF1s with Hankook RS3 tires, carbon fibre front lip, TRD knockoff spolier, SPC lower control arms.
fast_dude is offline   Reply With Quote
