Old 07-04-2014, 01:52 PM   #15
jshum
jshum's Avatar
Drives: Scion - FRS
Hi, I also have the same problem with the negative camber. I achieved -1.5 camber in the front and ever since my steering wheel is tilted a little bit to the left when I drive straight. I also had them 0 out the toe and it is still affecting. Will this be an issue on tire wears or handling? I am tracking my car this following weekend. Should I be worried or something? As far as I can tell, it feels great except the steering wheel part. Thank!
Zero out your toe, or run a tiny bit of toe-in (1/16"), but max your camber.
You'll like how it feels.
jshum is offline   Reply With Quote
Old 07-04-2014, 02:26 PM   #16
Your steering wheel should be straight. Either the thrust angle is off, or the steering rack is off, but it should be straight.
I can't tell which it is without an alignment printout or numbers, but either way, the shop should not have let you leave without a straight steering wheel (unless you have uneven tire wear).
Old 07-04-2014, 02:52 PM   #17
jshum
jshum's Avatar
Drives: Scion - FRS
I did not print out the sheet. Here is what I remember:
Front camber
-1.5 left -1.4 right
front toe
0 out in the mid
(-0.01 left 0.09 right) I think...
Rear camber
-0.9 left -1.2 right
Rear Toe
I forgot the exact number, but it is very close to 0
Basically, I had them to align everything to factory spec except front camber.
Sorry, I am not sure if this will help.
Old 07-04-2014, 09:26 PM   #18
Front camber
front toe
0 out in the mid
Rear camber
Rear Toe
Check tire pressures, and swap your left and right side tires (front left to right right, and rear left to rear right).
If it still pulls, you need an alignment. Have the original shop warranty that alignment, because numbers are like that are unacceptable in my book.
Old 07-05-2014, 11:20 AM   #19
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
My guy had the same problem. Our cars don't have an exact center mark so they have to do it by feel. He put it back on the rack and readjusted everything a 2nd time.
Just FYI on home camber adjustments - I "thought" I had mine maxed (used a jack, whiteline bolts on max setting) - I wasn't even close based on the initial reading at the align shop. It's so much better now that's it was done right.
More info in the alignment thread: http://www.ft86club.com/forums/showthread.php?t=25001
Khyron686 is offline   Reply With Quote
Old 07-05-2014, 08:07 PM   #20
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I got a LongAcre camber gauge so I could set my camber myself. Then I just take it to the alignment shop and tell them to zero the toe. Keeps guesswork and variables to a minimum.
Old 07-07-2014, 10:27 AM   #21
ZionsWrath
Thanks
ZionsWrath's Avatar
Go to a shop that does alignments for track cars. They will talk to you before hand and ask what you want specifically. It may cost more but it's better than having to spend time and money doing it twice.
My crash bolts they were able to get -1.3. I don't know much about alignment so I let them do what they want with the toe. They put -0.05 in front and 0.04 in rear. Maybe next time i'll try 0 all around see how I like that but I have no complaints with my current alignment.
alignment, help please?, oem crash bolts, suspension noob
Crash bolts alignment change ABQautoxer Tracking / Autocross / HPDE / Drifting 39 03-24-2014 05:45 PM
Front Camber Bolts / Alignment Question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-17-2013 04:31 AM
Cheapest Crash bolts FReSh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 08-14-2013 11:12 AM
Best alignment after installing crash bolts Brzer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-20-2012 06:24 PM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 12:29 AM
