Old 06-11-2014, 01:50 AM   #15
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Nice one Tye! Yup I was able to install mine without removing the airbox. I found that there was enough space behind the airbox to work on it.
I also got the optional soft spring for the Turbosmart BOV. I noticed that the stock spring was kinda stiff, and would stay closed at cruising speeds (10-50 kpa of vacuum). I figured this would increase fuel consumption, since the ECU will be in closed loop, and with more air going into the engine because the valve is closed, it will have to pump more fuel to maintain 14.7 stoich. With the softer spring, the valve opens at 20 kpa of vacuum
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
Tye300 (06-11-2014)
Old 06-11-2014, 02:19 AM   #16
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
What's the part number for the spring rob?
Tye300 is offline   Reply With Quote
Old 06-11-2014, 03:24 AM   #17
HRTROB
HRTROB's Avatar
Drives: Toyota 86
The part number is TS-0203-3001 "Kompact Blue Blow Off Valve Extra Soft Spring". Got mine from Amazon
Old 06-11-2014, 03:49 AM   #18
Tye300
Tye300's Avatar
Thanks bro!
Old 06-11-2014, 11:20 AM   #19
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
i really like the sound of it. if you dont mind me asking, how much was it?
It's as tight as it can be! It still does that! For some reason I cannot get the damn screws to stay put!
Originally Posted by xxscaxx View Post
sounds good - now tighten up your damn airbox cover lol
my box does the same thing!
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 06-11-2014, 12:39 PM   #20
Tye300
Tye300's Avatar
Got it for $130
The Following User Says Thank You to Tye300 For This Useful Post:
draggin_az (06-11-2014)
Old 06-11-2014, 04:59 PM   #21
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Man I would love to have that sound on my Kraftwerks SC.
zoth is offline   Reply With Quote
Old 06-24-2014, 05:01 PM   #22
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
So i just ordered mine. @Tye300 do you think if I get one of these bad boys it would solve the clearance problem?
1in 90deg silicone coupler
marcoaferrer is offline   Reply With Quote
Old 06-24-2014, 05:50 PM   #23
Tye300
Tye300's Avatar
It could. I was thinking if I should get a longer hose when I was currently working out the problem. Using that 90 degree coupler is a better idea, if you could angle the valve away from the block. It's just things are pretty cramped in there that I can't tell you clearly if it would work or not. Worth a shot though. I'd gladly follow suit if you make it work.
Old 06-24-2014, 05:51 PM   #24
marcoaferrer
Cool. I'll give it a shot. Can't hurt to try lol. My bpv should be here in a couple of days so I'll snap some picks
The Following User Says Thank You to marcoaferrer For This Useful Post:
Tye300 (06-24-2014)
Old 06-27-2014, 11:23 AM   #25
marcoaferrer
So I got mine in the mail yesterday. The stall was pretty quick but I thought it was odd that I didnt have any clearance issues. I was able to have the adjustment spring either completely tight or loose and it would not rub 0_o
I dont know if it has to do with how much I trimmed off the hose. What I did notice, thats been bothering me, is when the valve is venting at partial throttle I can here a low pitched wind noise that sounds like air blowing against something hollow. (This is aside from the whoosh of the bov) I know its hard to describe. My guess was the air venting and blowing against the outside charge pipe or the airbox. I need to mess around with it more and find the exact cause of the noise.
If you blow air into an empty water bottle it kinda sounds like that.
Old 06-27-2014, 11:37 AM   #26
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Are you running the dual port setup with the breather filter on one port and the horn on the other? I had the same low-pitched wind noise when I was running dual port with the horn facing the chassis rail or whatever it's called. I'm guessing that the sound is prodced by the air from the horn blowing onto the chassis.
Right now I've been running either the filter or horn (depending on my mood) facing the center of the car and the other port (facing the chassis rail) blocked off with the blanking plug. Haven't heard the low-pitched sound with this setup
Old 06-27-2014, 11:41 AM   #27
marcoaferrer
Thats exactly what I wanted to hear.
Maybe if I end up getting that 90deg coupler I can point the horn away from the chassis and still keep both ports functioning. Whats the difference in sound between running horn only or filter only?
Old 06-27-2014, 12:11 PM   #28
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Filter only is as quiet as the stock bypass valve. Horn only is just about the same, or maybe a tad louder than dual port, when it goes "whoosh"
F/S: TurboSmart Blowoff Valve for Vortech Amalgamo Engine, Exhaust, Bolt-Ons 5 05-30-2014 03:02 PM
Turbosmart E-boost controller Fl4t fun Engine, Exhaust, Bolt-Ons 0 01-29-2014 11:29 PM
Drift-Office : Vortech / HKS EL / Perrin / Greddy Installed & Tuned! Drift-Office Forced Induction 8 09-03-2013 06:20 PM
Drift-Office : Vortech / Perrin Combo Installed & Tuned! Drift-Office Forced Induction 44 08-06-2013 06:37 PM
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned congiiee Forced Induction 131 05-30-2013 12:28 AM
