#15 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
I'm doing a 2jz swap
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
| The Following User Says Thank You to OmarGC For This Useful Post: | gymratter (06-09-2014) |
#17 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
In general terms:
Custom "2JZ" engine Custom oil pan Custom engine mounts Custom intake manifold Custom exhaust manifold Custom exhaust system Custom ECU Custom cooling solution Custom transmission Custom transmission tunnel Custom firewall Custom dashboard Custom center console Custom drive shaft Custom rear subframe Custom rear diff Custom rear axles Custom fuel system And then there's all the other stuff you'll have to fabricate that you'll discover along the way.
| The Following 2 Users Say Thank You to Draco-REX For This Useful Post: | Basket Case (06-08-2014), Jrryjms07 (06-08-2014) |
#18 |
Drives: TRD Ultramarine '13
This is really all you need. Slap it on your FA20 and you're good to go!
| The Following 3 Users Say Thank You to kALMIGHTY For This Useful Post: |
#19 | |
![]() humfrz |
#20 |
Drives: 2014 BRZ MT (Sold); 2006 V70R
LOL
You would need to re-do pretty much the entire drivetrain, modify the firewall, tunnel, etc. Basically, since there doesn't appear to be enough room for the length of a 2jz, you'll be stripping the entire car down, cutting nearly the entire firewall and driveshaft tunnel up, fabricating a new enclosure... You know what? it'll be cheaper to buy a supra and put a GT86 "body kit" on it... |
#21 |
Drives: 08 WRB WRX STi / NA Miata
Get in contact with Ken Gushi's guys or these guys:
http://www.speedhunters.com/2012/07/...t-oil-the-86x/ |
#22 |
Drives: 2012 WRX, 2003 RSX Type S
I would seriously look into swapping the 20 valve 4AGE big port engine into your car
Sent from my GT-N5110 using Tapatalk |
#23 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
You'll get the torque and the power, but you'll also get the weight of the cast iron block effectively messing up the balance that makes this car special.
#24 | |
#25 |
I think Wise was referring to the 2jz... Actually, why stop at a 2jz when you can swap in a big block Hemi? To offset the weight balance, put lead weights in the trunk!
Sent from my D6503 using Tapatalk
'14 BRZ LTD MT DGM
#26 |
#27 |
#28 |
Drives: Scion FR-S 13
2jz the dream
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| 2JZ swap? | jordydiaz | Engine Swaps | 44 | 05-21-2015 10:19 PM |
| Ej Swap | koyv90 | Engine Swaps | 50 | 11-14-2013 07:59 PM |
| 2UR-GSE Swap | czar07 | Engine Swaps | 9 | 08-29-2012 01:43 PM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) — General Topics | 8 | 06-12-2012 07:32 PM |
