#15 |
Drives: 2013 Brz sport-tech
the only thing is ethanol absorbs water, i belive that pump gas containing ethanol in a wet humid climate in poor quality holding tanks can develop a lesser grade. so adding it yourself is a sure shot to target a certain percentage. i cannot se any danger as long as you dont go past E15 , and doing any kind of fuel mods like this requires logging, if it isnt logged and anylized theres no point because you have no clue what impact its having on your car.
#16 |
Drives: 2022 BRZ
Just thought I'd chime in here as well with my experience between US (blaine) gas vs our 94 chevron.
I tuned my 240sx with Blaine, Chevron 92 gas and maxed out that gas (knock threshhold) @ 425whp @ 21psi. I ran that gas for a bit and decided to put a tank of 94 and hit the dyno again. Well.... on the first pull it was knocking so loud once boost hit that I had to let off. I started pulling timing to the point where the tq curve looked so jagged that it wasn't even worth running that boost (pulled 4 degrees). I brought the boost down in increments to see where I would max out and it liked 18psi but unfortunately it only made 365 @ 18psi. That's a 60whp loss on our mustang dyno! It was pretty heart breaking knowing how bad our gas is. We've also tested every fuel in B.C at our shop (racing greed) and confirmed that chevron 94 is the best, crappy, but the best in terms of knock resistance. Love your idea on the E10, I'm definitely going to look into that! |
#17 | |
At times in the revband mostly midrange i could hit 94 like timing advance but it knocked severly on low rpm high load, and also at high rpm high load, the ethanol has made it so now i can very smoothly run a 94 tune, I even did some testing up in the hills @ about 3000ft and only had one instance of very very mild tip in, not even enough to pull the IAM but i went WOT at 2500rpm up a slight hill, i was testing it i dont usually do that. but im impressed it runs better than with my race gas mix ! that supprised me. Usually those hills will destroy my IAM. Im from out east and our gas was great, everyone ran tunes as advertised and we never had issues running 20+lbs boost on our 93oct. I really dont get this BC gas, i wonder if its not the possibility of being tar sand bitumen . instead of crude from the mid west. |
#18 |
Drives: White 2013 FRS
great thread, looks like an alternate to meth!
#19 |
#20 |
I'm seriously pissed that they false advertise. Chevron's gas has probably been the cause of many engine failures. I wonder if its proven not to be 94 if we could launch a class-action law suit?
#21 | |
Umm i dont know, i think it would be hard to obtain any cash from this, i called chevron and spoke to owners about gas testing, and the owners said that you can contact a goverment agency and file a complaint , and that they will take charge of the testing. but im sure they as allways give notice, to catch them red handed,id do it myself and have legit sealed samples with adhesive break seals with serial numbers and get the on site employee to initial and date the sample , just like a good old piss test |
#22 |
We should do something. It's complete BS. False advertizing is definitely illegal.
#23 |
Drives: Ft86
Lol good luck with that.. Oil companies are right along side the military industrial complex and big pharma... They own the world, you'd be found with a suicide note stucfed in your pocket, hanging in your closet with a belt around your neck before you get chevron to pay for any fa20 engine failure.
#24 | |
#25 |
So tried running the BioFlame with the FB SD Basemap tune to try to get the AFRs above 9.
So far, first impressions have been not so good. I mixed 3.8L with a full tank of Canadian Chev 94 (no ethanol in the gas, says chevron). Made sure to shake up the car to mix it up. Also unhooked the negative battery terminal for a bit to reset the ECU learned settings. Fist impression- When starting in 1st, the car needs quite a bit more throttle not to stall. It's also weaker after the clutch is disengaged. After the car is moving it's sometimes really jerky when accelerating 'smoothly' from a low rpm in a low gear. The AFRs are definitely leaner. I was hoping to lean things out a bit, but this seems like quite a bit more lean throughout the entire drive. If I'm on the gas lightly it's around 15! 15 is unheard of for my car with turbo. Before my AFR would hit 9 when WOT it seems to go around 11ish now, but I didn't want to push it repeatedly for fear of popping the motor. Im going to try some more driving tomorrow and take some logs. Maybe it is ust taking the ECU some time to learn? Not sure what I should be looking for as warning signs in the logs? @FullBlown |
#26 |
It would be cool if you guys figure something out. I already add fluid to my truck every fill up by choice, would hate to have to add fluid to the car because it needs it to run properly on its tune.
To each their own I guess, hope you find something that works! |
#27 |
Day 2: Car was having some pretty bad idle issues when I started it (died once at a red light).. but after driving for 5 or so minutes things started to even out. After that the car drove pretty respectable for the remainder of the day. I'm not sure if the ethanol didn't properly mix yesterday, or the ECU had some big re-learning to do, or what was going on.
Anyways, I'm still not completely satisfied that my car is running safely, but it seems to be running ok atm. My AFRs are still leaner, but much closer than what they were before. The lowest I can get the AFR to go is a 9.6 when WOT, and I had some WOT runs where it stayed at 10! This is a pretty big change from before. Also, when the car is WOT it feels like it has some more kick to it. Jury is still out.. what's going on here. I wonder if chevron adds something else to their 94 than Ethanol to up the octane? Haven't been to Shell in a while, but I think their V-power has no ethanol in it. Maybe will try the next tank with V-Power and a jug of BioFlame. |
#28 | |
So i belive that because ethanol does absorb water, if there water in the fuel maybe it leachs it out and stays seperate from the fuel instead of mixing, then spouches around in the tank and when the cars not moving it settles (idle) and you get more ethanol and water than you do gas, possibly if the reason the gas is bad is due to water and not a actual degradation of it chemical properties it will make the gas WORSE, by reacting to the water, but if the gas is bad because its just weak then it can possibly add some pep . one thing is sure , the VP Octanium , has never let down, and doesnt do weird stuff, that stuff is pricey as hell @40$ for a 32oz can which treats a tank of gas to net 97oct, but ive used like 8-9 tanks of it and its never ever had a hickup like the ethanol, now.. its pricey.. so i did research apparently based on other peoples independent tests 95 percent of the octanium just like tha TORCO is made up of solvents, cheap solvents, such as Xylene and Toulene , the other 5 percent is MMT which is a sort of synthetic lead which lubricates the otherwise dry combustion of the solvent, alot of people allready run this stuff in alot of applications, i just dont know how good it would be on our direct injection system. possibly finding another lubrification agent other than mmt which is the cause of the orange residue buildup we can find something. there is a product call formula 112, its made in calgary from a well know petrochemical company, the owner told me over the phone this stuff only 2oz of it will yeild a massive gain in octane, its very corrosive and should not be poured strait into the gas neck but premixed then poured, he has not seen benefit to using a stronger ratio. it cannot be shipped you have to pick it up directly, found a guy on a corvette forum, he uses this stuff and says it works very well comparable to a full can of torco, yet only 2oz?? torco 32oz! i want to try this stuff, if its good im gonna run it in my sled this winter |
| OFT with 94 Chevron for areas with no E85 | Chad86 | Software Tuning | 6 | 06-11-2014 06:25 PM |
| Chevron 94 or CO-OP 91 (Ethanol Free) | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 05-28-2014 05:21 PM |
| Chevron silenced my crickets | FRSapex | Southern California | 47 | 04-20-2014 03:07 PM |
| Non ethanol gas | reesmicm | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 08-21-2013 02:14 PM |
| Ethanol | Andrew666 | AUSTRALIA | 30 | 08-09-2013 08:13 AM |
