Old 06-02-2014, 05:02 AM   #15
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
The fa20dit recommends 10w30 and our manual says to run a higher viscosity in extreme driving situations but never states a viscosity. The fa20dit wrx also recommends a 30 weight. @Kronos
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-02-2014, 07:04 AM   #16
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
While this is true, it is not the exact same motor. It could have different bearing clearances to go with the lower compression ratio.
Luckrider is offline   Reply With Quote
Old 06-02-2014, 10:15 AM   #17
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Because turbo problems.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 06-02-2014, 10:27 AM   #18
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I believe it calls for 5w-30 on the 2015 WRX user manual?
Old 06-02-2014, 10:52 AM   #19
Reaper
Reaper's Avatar
Drives: violent
Yes the manual does. And bearing part numbers are the same.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
Luckrider (06-02-2014), Sportsguy83 (06-02-2014)
Old 06-02-2014, 10:59 AM   #20
Luckrider
Luckrider's Avatar
Being the same bearing spec with a thicker oil makes me not feel bad for using 5W20 with the last oil change.
The Following 2 Users Say Thank You to Luckrider For This Useful Post:
Reaper (06-02-2014), Sportsguy83 (06-02-2014)
Old 06-02-2014, 07:24 PM   #21
AL008
Drives: Celica 04
How about Octane 100 fuel?
It contains only 10% added ethanol, would this require any further maintenance?
AL008 is offline   Reply With Quote
Old 06-02-2014, 07:42 PM   #22
steve99
These cars like almost all cars these days are designed for 10% ethanol fuels even says so in manual, in some places 10% or more ethanol fuels is all you can get, will be fine.
I suspect the buildup on injectors when running e85 reported sometimes is likely due additives as pure ethanol is a very clean burning fuel.
Old 06-02-2014, 11:11 PM   #23
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Here is what the Manuel says word for word regarding engine oil if anyone is interested.
Size:  252.2 KBName:  ImageUploadedByTapatalk1401765003.873056.jpg
Kronos is offline   Reply With Quote
The Following 2 Users Say Thank You to Kronos For This Useful Post:
Bkdshadow (03-26-2018), Boofneenee (10-17-2014)
Old 06-02-2014, 11:14 PM   #24
Kronos
Kronos's Avatar
Also @Reaper I would love to hear the results of the UOA you submitted using the amsoil dominator 10w30 when you get them. I'm hoping it's a safe solution for long term e85 users.
Old 06-03-2014, 12:37 AM   #25
steve99
Noticed my brz manual is different and states 5w30 and 5w40 suitable and even shows in chart will post up scan , been using 5w30
Old 06-03-2014, 02:53 AM   #26
s2d4
s2d4's Avatar
It also says to change it back to 0W20 on the next oil change.
Old 06-03-2014, 04:15 AM   #27
steve99
im reasnobly confident they only say that for fuel economy emmisions purposes, i am happy to trade that for long gevity of the engine internals in a hot climate under high load conditions, that htey recomend 5w40 and also in the dit fa20 suggests that the motor is quite capable of using that higher viscosity oil, the 5w will still allow starting in sub zero conditions which i never get
Old 06-03-2014, 04:49 AM   #28
s2d4
s2d4's Avatar
True true.
Weight Reduction (budget diet) for daily/spirited driving 1086 Scion FR-S / Toyota 86 GT86 General Forum 86 03-22-2015 01:18 PM
Car lurching at steady speed batmobilefrs Issues | Warranty | Recalls / TSB 10 04-04-2014 08:33 AM
DRIVETRAIN DIET - CARBON FIBER PST DRIVESHAFTS! // DSG PERFORMANCE Jason@DSG Transmission and Driveline 16 01-14-2014 11:18 AM
The Exhaust Diet: Lightest Header to Exhaust tip combo phastafrican Engine, Exhaust, Transmission 3 12-30-2013 08:44 PM
The Diet Thread Maxim Scion FR-S / Toyota 86 GT86 General Forum 126 06-14-2011 05:47 AM
