Old 05-26-2014, 12:23 AM   #15
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Yes I saw dem pics ...but no info if they are even working.
fooddude is offline   Reply With Quote
Old 05-26-2014, 12:37 AM   #16
eighty666
Originally Posted by Malt View Post
You sure about that?
This post seems to disagree with you. http://www.ft86club.com/forums/showt...973#post508973
EDIT: How ironic... This one disagrees with you too... Oh wait.. recognize the username?!
yea check your link you posted hes measuring the inner diameter. only problem is he didnt realize that it steps down in size at the butterfly... duhhhhhh. so now u can stop acting like a ______
keep that hateraid flowin. good night
eighty666 is offline   Reply With Quote
Old 05-26-2014, 12:40 AM   #17
eighty666
Isn't the stock throttle body 76mm?
meanwhile.... your asking what size it is. hahahhaha
Old 05-26-2014, 05:07 AM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by eighty666 View Post
your
your =/= you're
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
20valvewynn83 (05-30-2014), Guillaume (05-26-2014)
Old 05-26-2014, 05:11 AM   #19
Captain Snooze
Drives: Red Herring
Old 05-26-2014, 05:13 AM   #20
s2d4
s2d4's Avatar
No.
Old 05-26-2014, 06:17 AM   #21
Malt
Drives: 2015 WRX
Thanks for the info, I guess the over one dozen sources I checked on here were wrong. I should of figured that if there was one person on this forum that knew anything about a large throttle body it would be you...
Malt is offline   Reply With Quote
Old 05-26-2014, 06:26 AM   #22
s2d4
s2d4's Avatar
Why are you ridiculing someone for simply giving you the right info?
Sure he is special but this is a pretty low act.
Old 05-26-2014, 06:31 AM   #23
Malt
Drives: 2015 WRX
I didn't realize I was with this reply, mearly conceding to the fact that he's one of a few people that actually have a large TB. But since we're on the topic, why is this the third time he's made a new account to circumvent a forum ban?
Old 05-26-2014, 08:04 AM   #24
michael336
Drives: gt86
I did install it on my 5gr Toyota mark x, because I ordered another one, which is 2ur throttle body for 86
我從使用 Tapatalk 的 HTC Desire 700 dual sim 發送
michael336 is offline   Reply With Quote
Old 05-26-2014, 02:06 PM   #25
eighty666
oh wow. so i was right? and you and the other internet mechanics were wrong? go figure. i guess those sources were wrong buddy.
Old 05-26-2014, 02:25 PM   #26
fooddude
@michael336: Nice!
Why not try getting needle nose pliers and pull the pins out gently and re-pin the plug, or even splice the wires right before the plug, and keep trying different combinations, until it works? There's only a few wires, so I am sure you can find the correct pin-out easily.
Or, try to find the original car the TB came from, look at the harnesses' plug, and take note at the wire colors...then, compare it to the frs'/brz's harnesses' plug and switch any wires around that doesn't match the two cars. (ie: black, black with white stripe, yellow, yellow with white stripe, or any other colors...a lot of times, colors correspond to the same thing in the same manufacturer or in electrical, in the engine harnesses).
I've done wire harness repairs and mods a couple times before in the 90s, and I remember it was relatively easy to find which wires did exactly what from only it's color (and just a confirmation with a multimeter to make sure it was true). Maybe the twin has a manufacturer's color code for electrical/engine harness work, repair manual maybe?
Another possibility...if the TB's sensor's plug and pin out is actually the exactly same b/n the twin and the car the TB came from, then the ECU's actual plug harness could be the one that is pinned a little different..obviously a little harder since there's hundreds of pins..but actually easy to re-pin - use micro needle nose pliers, gently push the male/female pin out of the ecu plug, then re-pin. (do at your own risk, and after a lot of research and multimeter use to make sure though, lol)
Old 05-26-2014, 03:59 PM   #27
wootwoot
Drives: FRS
From a throttle body project to a monkey f*^+ing a football. This must be the internet...
wootwoot is offline   Reply With Quote
The Following 3 Users Say Thank You to wootwoot For This Useful Post:
Captain Snooze (05-26-2014), Superhatch (05-26-2014), zooki (05-26-2014)
Old 05-26-2014, 07:22 PM   #28
michael336
Drives: gt86
Size:  38.4 KBName:  uploadfromtaptalk1401146392791.jpg
Thanks for your advice fooddude, the bigger one is here. I am planning to swap the electric part of the throttle body. But need to wait for marking the adaptor.
Toyota Service Bulletin: Body Panel Fitting Issues ahausheer Issues | Warranty | Recalls / TSB 99 03-07-2017 12:21 PM
Recommendations for Toyota MR2 Spyder (2002) Body Kit Vendor? flameSniper Other Vehicles & General Automotive Discussions 8 09-19-2013 02:11 PM
Body Shop or Scion/Toyota paint specialists in Long Island NY mikeg7827 NY / NJ / CT / PA 7 02-27-2013 12:15 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
