Old 05-19-2014, 07:28 PM   #15
White64Goat
Always had good experience with Adam's Polishes clay.
This sheds some light on the clay 'patents'.
Why do we call it Adam's MADE IN THE USA Detail Clay?For the better part of the past 7 years clay in the US was under the control of a patent which limited the production, sourcing, and sales of all detail clay. With the expiration of this patent earlier this year Adam's was once again able to formulate our own clay bars and make sure that not only the components, but the packaging, and even the label were made right here in the USA.
PRO-TIP: Adam's Detailing Clay Bars should be stored at moderate temperatures. If the clay will be stored for an extended period of time without use place into a sealable plastic bag. Add a light spray of Adam's Detail Spray in the bag to keep clay moist until the next use.
Contents: (2) 100gram Adam's Made in the USA Detailing Clay Bars with storage container
The Following User Says Thank You to White64Goat For This Useful Post:
Paul_S (05-19-2014)
Old 05-19-2014, 08:09 PM   #16
Paul_S
Drives: red
I knew they were close to being near the end of their patent protection. Now the other companies will play catch-up with other countries not covered by those restrictions.
Paul_S is offline   Reply With Quote
Old 05-19-2014, 10:16 PM   #17
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Thanks for all the advice and information of personal experience. I plan to lightly go over sections of my car with clay with a lubricant called Infinite Use Detail Juice by Garry Dean. Of course after washing it thoroughly and keeping it cool inside a garage. Followed by use of PC DA on Hexlogic pad (orange) using Meguiar's 105 followed by 205 polish by Meguiar's using a Hexlogic white pad. Then a wax followed by sealant. I will probably just get a Meguiar's or Mother's clay bar.
AVodka14 is offline   Reply With Quote
Old 05-19-2014, 10:22 PM   #18
Paul_S
Drives: red
Start with a test section 2'x2' and try what you have posted. If you have dialed it in and are happy with the results then do the whole car. If not adjust accordingly. if you have any further questions please feel free to contact me or if you call Garry , tell him Paul from Indy said hi.
The Following User Says Thank You to Paul_S For This Useful Post:
AVodka14 (05-19-2014)
Old 05-19-2014, 10:34 PM   #19
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
I'm gonna give nanoskin autoscrub speedy prep sponge a try
sprintertrueno86 is offline   Reply With Quote
Old 05-20-2014, 09:09 AM   #20
Diode Dynamics
Diode Dynamics's Avatar
I've heard good things about that, don't forget to post up some pictures of the results
Nick C.
John C.
Diode Dynamics
Old 05-20-2014, 10:00 AM   #21
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
ive started using nanoskin recently and i love it.
supramkivtt2jz is offline   Reply With Quote
Old 05-20-2014, 10:16 AM   #22
Namuna
Namuna's Avatar
Clay Magic are the originators and they've got the patent...Sounds like a solid bet to try their product (which I have and works great):
[ame="http://www.amazon.com/Simoniz-S57-Perfect-Finish-Detailing/dp/B0081OSRQQ"]Amazon.com: Simoniz S57 Perfect Finish Detailing Clay Bar: Automotive[/ame]
Namuna is offline   Reply With Quote
The Following User Says Thank You to Namuna For This Useful Post:
Paul_S (05-20-2014)
Old 05-20-2014, 11:24 AM   #23
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
When I clayed my car I used lots of clay lube and almost no pressure. I used about 1/3 of the bar in my hand pressed out to cover my fingers. In other words I tried to be as gentle as possible. If anything I left behind some stuff but it was still a night and day difference. Like I said had I checked using the ziplock bag feel test or even your fingers I could have hit some of the bad spots again. I used this clay - Pinnacle’s Ultra Poly Clay because it said it could be used often.
Work in small sections and take your time. It did not take that long for me. Most of the grit was on the upper surfaces like roof, hood, rear deck lid.
TStafford is offline   Reply With Quote
Old 05-22-2014, 01:45 PM   #24
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Keep in mind that clay barring will most likely cause marring to the paint. Always follow up with polish and wax.
Old 05-22-2014, 02:03 PM   #25
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
Can anyone recommend an aggressive clay? I'm looking for something with a bit more "bite" than the regular OTC mothers and meguiars.
Thanks!
Kotu100 is offline   Reply With Quote
Old 05-22-2014, 02:40 PM   #26
mx5 2nr
Drives: FRS/NA1/'12 Mustang/'97 4Runner
You guys are way more expereinced in this than I. On my previous cars, I've always used Meguire's or Mothers clay bar. What's wrong with doing this? Sorry for the noob'ish question, just trying to learn something new...
'90 Miata - weekends
'13 FRS - weekdays
'97 4-Runner - grunt work
'12 Mustang - wife's
mx5 2nr is offline   Reply With Quote
Old 05-31-2014, 08:43 PM   #27
sprintertrueno86
Drives: 2018 BMW M2
Nick C.
Just used the nanoskin autoscrub sponge this morning. My BRZ is opticoated and never been clayed before.
Washed with ONR and used 30-35ml of ONR in to 32oz spray bottle as lubricant. Super easy to use and you can feel it pick up the contaminants. Didn't notice any marring and I waxed with Optimum car wax afterwards. Finished in less than 1.5hrs.
Sorry no pics as my car was covered in pollen afterwards.
Old 06-01-2014, 12:37 AM   #28
Paul_S
Drives: red
You are aware that your OC can be abraded off with a autoscrub sponge ? Tread lightly. You mentioned your ride had never been clayed. Why would anyone not decontaminate before applying OC 2.0 or OCP ? Once Optimum coatings are applied then only deep cleaning is needed to maintain along with either ONR or a proper power wash.
Clay bar new car subiestyle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 02-27-2014 10:31 PM
Clay Barred. (If you want, post yours, too.) AirborneDeth FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 08-31-2013 10:15 PM
Your clay bar of choice? bdanisi Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 05-09-2013 01:38 PM
First time clay bar user... wow! chandz05 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 50 04-23-2013 07:05 AM
Clay bar really works! 6-Shift Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 12-28-2012 09:37 AM
