Old 05-22-2014, 09:55 PM   #15
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Yes, that's the one I got.
Sent from my D6503 using Tapatalk
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 05-22-2014, 10:09 PM   #16
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
http://pages.ebay.com/motors/link/?n...866061&alt=web
Old 05-22-2014, 10:43 PM   #17
aznatama
aznatama's Avatar
Don't forget to also get the correctly sized hole saw to place it in the correct side of the plastic trim. The camera goes on the driver side, since the HU lines are offset to account for the factory placement.
The kit I got includes everything, has sufficiently long wires, 99% plug and play (with the exception of tapping a 5vdc wire on the HU w/ an in line splice.
You could go piece a kit together yourself, but I have no idea about camera quality or any of the other harnesses required.
Old 07-17-2014, 10:56 PM   #18
btoast
I'm bringing this thread back from the dead.
Could you be a bit more specific on what wire you were supposed to splice? I can't really tell from the pics, but it looks like the camera had a small connector and four wires (not inserted into the connector) on it. You mention that one pair of the wires was for reversing the image and the other pair for removing the lines. Where was the power line? Was it in the connector?
Thanks.
btoast is offline   Reply With Quote
Old 07-19-2014, 01:00 AM   #19
aznatama
aznatama's Avatar
The 4 small wires are near the tail end of the harness, and the instructions detail that they are for 180 rotate and the lines.
The ACC PWR wire on the back of the stock radio unit on MY BRZ is red/pink, as circled in the center of the yellow circle in pic above.
[CAMERA]----[4wires]---------------------------------------------------[RCA/pwer splice]
Old 08-16-2014, 01:48 AM   #20
notout86
Drives: GTS 86 auto
here's a way to add a front cam to work with the rear
http://www.ft86club.com/forums/showt...t=57644&page=3
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 08-27-2014, 08:40 AM   #21
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
does this work with the bespoke radio in monograms?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 02-13-2015, 04:54 PM   #22
No1der
No1der
No1der's Avatar
Drives: BRZ Limited Satin White
is this the same camera kit you used?
http://www.ebay.com/itm/PLUGandGO-In...25.m3641.l6393
No1der is offline   Reply With Quote
Old 02-13-2015, 04:56 PM   #23
aznatama
aznatama's Avatar
That looks like basically the same thing.
'14 BRZ LTD MT DGM
Old 02-13-2015, 06:59 PM   #24
notout86
Drives: GTS 86 auto
Our cars are not listed as compatible but if those connectors are suitable then it seems like an ok deal. Check with the seller.
Old 02-13-2015, 09:57 PM   #25
No1der
No1der
No1der's Avatar
Found the same camera under different title. Which it says compatible with brz. It looks the same though.
http://pages.ebay.com/link/?nav=item...d=271684162258
Old 02-14-2015, 12:54 AM   #26
notout86
Drives: GTS 86 auto
I am intrigued by the instruction in one pic which says remove the a/c outlet. I would be asking the seller to send the instructions as I did not need to do that for my camera install, but I have a GTS86 & the BRZ may be different.
Old 02-17-2015, 01:58 PM   #27
No1der
No1der
No1der's Avatar
Did you need RCA w\pins from SVXdc adapter when you installing your Toyota Fit cam?
Old 02-17-2015, 07:02 PM   #28
notout86
Drives: GTS 86 auto
My method did not involve an adapter. Do an advanced search on the forum under notout86.
Stock Rear View Camera for Fujitsu Ten? Foobar Electronics | Audio | NAV | Infotainment 151 08-19-2021 11:24 AM
stock brz jdm rear view camera SuperDave Electronics | Audio | NAV | Infotainment 0 04-03-2014 09:53 AM
Rear-view camera/reverse cam. What do you have? joergasm Audio/Visual, Electronics, Infotainment, NAV 0 05-24-2013 12:25 PM
be spoke with rear view camera harness fs xpicer Audio/Visual, Electronics, Infotainment, NAV 1 11-25-2012 02:35 PM
be spoke w rear view camera xpicer Electronics | Audio | NAV | Infotainment 17 10-14-2012 09:26 AM
