Old 07-22-2014, 02:12 AM   #15
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
what elevation are you at when doing this?
Kuros is offline   Reply With Quote
Old 07-22-2014, 12:41 PM   #16
slofrs
slofrs's Avatar
Drives: Hot Lava FR-S
Sea level
slofrs is offline   Reply With Quote
Old 07-22-2014, 01:13 PM   #17
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
FWIW, we don't make any changes to speed limits in our OTS maps. But I don't see why anything should be intervening at 110mph.
Old 07-22-2014, 03:02 PM   #18
ML
ML's Avatar
Drives: 13 White MT FR-S
Originally Posted by MstrSHAKE View Post
Dont mean to bump an old thread, but I just ran into this issue as well on my stage 1 flash. was at 6th Gear 99mph and then just hit a wall like fuel cut? Odd. Would not happen in 5th or 4th gear like the OP.
exact same happened to me. Pulled back on the throttle, and tried again and it didn't do it the second time. weird.
Old 07-22-2014, 03:59 PM   #19
slofrs
slofrs's Avatar
i will see if i can get a log of it tonight
Old 07-28-2014, 06:36 AM   #20
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
same thing happened to me last night got up to 120 but it felt like a fuel cut. before i could go past 120 with ease. anymore info on this? im on stg2 el e85 tune if that helps.
Old 07-28-2014, 07:06 AM   #21
steve99
If you guys could log the problem it might help to work out what the issue is suggest
throttle
load
ignition advance
speed
fuel pressure
injection volume ml
AFR
FLKC
IAM
knock correction
Old 08-10-2014, 12:32 PM   #22
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Just want to chime in too. I had the same issue as above at 100mph around 4k. yesterday. running Stg 1 93 2.0 tune. Sorry no logging done yet.
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 08-10-2014, 01:52 PM   #23
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I'm going to take a wild guess and say this happens between 3500 RPMs and 4000 RPMs?
EDIT: from at least two reports on here, 4000 RPMs is indeed the magic spot.
Over and above the SI mode throttle speed cut tables, there are two tables that are RPM based - hysteresis between 3500 and 4000. I don't think I've heard of anybody hitting these limit before (at least on the Subarus), but then again, not many people cruising at those speeds.
If you want, I can add these to the definitions, and you can test the theory out.
Td-d is offline   Reply With Quote
Old 08-10-2014, 07:35 PM   #24
JB86'd
JB86'd's Avatar
Drives: JAWS
I'm on the 91 oct. Stage 2 maps...got up to 106mph with no hesitation today..think I was in 5th gear though.
Old 08-10-2014, 09:49 PM   #25
Chimera
Drives: FRS
Not sure I'd personally call this an issue as much as observed behavior. personally at least.
The Following User Says Thank You to Chimera For This Useful Post:
JB86'd (08-10-2014)
CEL issue after dyno tune reyruiz191 Software Tuning 10 07-29-2016 08:50 PM
Hood lift at high speeds Basti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 97 02-15-2016 03:50 PM
Koni Rear Ride Height Too High; Install Issue rene0023 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-06-2014 05:01 PM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 05:25 AM
High RPM Shifting Issue? Rinzler Issues | Warranty | Recalls / TSB 5 05-17-2013 12:30 AM
