Old 05-13-2014, 02:04 PM   #15
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
If i'm correct, Xpel is mostly cut out...which the Emblem would be already cut out for...
Old 05-13-2014, 08:10 PM   #16
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
This is true. Only the hood is not pre-cut.
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 05-13-2014, 10:39 PM   #17
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by shellslinger View Post
I left the emblems on
What lip or body kit do you have? The black looks good!
So the back end emblem is pre-cut? This does not seem right...
Chad86 is offline   Reply With Quote
The Following User Says Thank You to Chad86 For This Useful Post:
shellslinger (05-14-2014)
Old 05-13-2014, 11:48 PM   #18
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
Originally Posted by Chad86 View Post
Are you joining Club Monogram?
Nah, just a base.
Goin cheap cheap cheap
Kuros is offline   Reply With Quote
Old 05-14-2014, 12:12 AM   #19
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
AFAIK, Xpel Ultimate cut sheets are made to go around the emblems, and they also do not wrap around the edges. So there's no need to remove badges and trim. The hood is also pre-cut (maybe they just came out with the hood outline?
aznatama is offline   Reply With Quote
Old 05-14-2014, 12:49 AM   #20
shellslinger
Drives: Whiteout FRS
Thanks . It's the Downforce carbon fiber lip from Evasive Motorsports. I picked it up locally from them. Great and easy to install once you get the right hardware.
Here's a better view of it.
shellslinger is offline   Reply With Quote
Old 05-14-2014, 02:12 AM   #21
JustBoostin
Drives: Asphalt FR-S 6MT
The Xpel kits for our cars are designed around the front Scion badge. It's very easy to delete out of the pattern though, and it's also easy to wrap any desired edges. My whole car is done and there aren't many edges that weren't wrapped. The doors, full roof, full quarters, trunk will need to be custom. There is a back bumper kit but it's under the BRZ in the program haha. Also, I vote remove all badges prior to installation, it'll make the job much cleaner. Hope this helps!
JustBoostin is offline   Reply With Quote
The Following User Says Thank You to JustBoostin For This Useful Post:
Chad86 (05-14-2014)
Old 05-14-2014, 01:25 PM   #22
Chad86
Chad86's Avatar
Drives: Toyota GT86
Clean is the only way to go. I will definitely remove all badges prior to my appointment.
Thanks @JustBoostin
JustBoostin (05-16-2014)
Old 05-14-2014, 09:13 PM   #23
GhostShield
Drives: 2013 silver FRS
It's all up to you. You want clean as possible, remove the emblems prior to install. Don't care so much then leave um on.
Yes xpels pattern will have the emblem whole in it. But a competent installer will know how to remove that oval from the pattern on the computer prior to cutting your kit out.
GhostShield is offline   Reply With Quote
The Following User Says Thank You to GhostShield For This Useful Post:
Chad86 (05-16-2014)
Old 05-14-2014, 09:14 PM   #24
GhostShield
Doing a vynil wrap then yess you HAVE to remove the emblems because you need that paint under them covered in the need of changing the color of the car.
Old 05-17-2014, 09:29 PM   #25
Chad86
Chad86's Avatar
Drives: Toyota GT86
I plan to have the whole car wrapped including the headlights. Just wondering if the headlights are overkill or unnecessary.
Old 05-18-2014, 04:08 PM   #26
GhostShield
PPF will keep the headlights clear and never let them yellow
Old 05-18-2014, 05:10 PM   #27
Chad86
Chad86's Avatar
Drives: Toyota GT86
Question
Excellent. The local XPEL shop said they can wrap everything including the mirrors and headlights, but the taillights are a pain in the ass. Should I even bother with the tails?
Also, what are your thoughts on using a car cover with the XPEL? Since XPEL PPF is self-healing, there would be no worry about the car cover scratching while adding an extra level of protection when not in use. (Car will also be parked in a garage.)
http://www.nigel-jdmparts.com/Toyota...ame-proof-type
Old 06-18-2014, 10:07 PM   #28
Chad86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
All badges are removed and paint has been touched up. Do I need to remove the mud flaps?
Any consensus on best manual transmission fluid choice? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-01-2014 06:14 AM
xpel ultimate quotes in bay area Hyperian Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 11-20-2013 09:00 PM
Xpel Ultimate (Calgary) Bu-Tang CANADA 9 07-10-2013 05:54 PM
Consensus on TRD exhaust offering for FRS?... OICU812 Engine, Exhaust, Transmission 19 06-19-2013 07:53 AM
Got my Xpel Ultimate clear bumper at.... Wolfkiller Southern California 1 11-20-2012 10:52 PM
