Old 05-05-2014, 11:35 AM   #15
tennisfreak
Drives: 2018 BMW M240i
No one "needs" the TC and VSC off all the time.
Lots of people want it off though (myself included).
Its annoying that its on all the time by default and I have to turn it off. I'd rather manually turn it on when I feel I need it.
And I completely agree with OP on turning from a dead stop into hard acceleration. Its jarring and annoying to have the damn TC kick in and kill power.
This happens more often than it should because the damn hard @ss rubber these stock tires have. The tires slip at the slightest hint of acceleration on most of the blacktop roads around here.
The Following User Says Thank You to tennisfreak For This Useful Post:
acro (05-05-2014)
Old 05-05-2014, 11:50 AM   #16
J_kennington
Drives: 2013 asphalt scion FRS
Originally Posted by wparsons View Post
No offense intended to anyone in here, but why does everyone feel like they need to turn TC and VSC off for daily driving?
You can turn very quick laps with both fully on, there's simply no need to have them disabled on the street.
If you find the VSC intervening a lot on the track, you're probably over driving the car unless you're a very competent driver needing a bit more rotation than the VSC is happy with.
Because #racecar and #tokyodrift.
Nah honestly I agree with you. Normal daily driving, I don't bother to turn them off. This past Friday, I turned vsc off while running the tail of dragon, simply because each hairpin was causing tc, granted it's understandable. 90* turns at 40mph I would expect it to correct.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-05-2014, 11:58 AM   #17
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
If you are on public streets/highways/freeways and you get the VSC in sport mode to slap you on the wrist... You are not driving safely.
There are a bunch of people who will chime in "I've been driving for XX Years, and have experience doing XXXX.."
No one is as good as they think they are, and thats not the point at all. On public roads, you have to worry about the other idiots too.
The Following 2 Users Say Thank You to tahdizzle For This Useful Post:
Venator (05-05-2014), wparsons (05-05-2014)
Old 05-05-2014, 12:21 PM   #18
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
This dude (i assume) is kinda giving a
review, and linking a product. Not debating when where to use the system.
Use it or don't.
When you want, where you want.
Live a lil.
Ease up.
Originally Posted by banzairx7 View Post
If you don't like the mod good for you.
For me it's causing more problems then it's solving. Problem is the you are correcting for a problem the TCS has all ready solved and can end up unsettling the car even more.
Word
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
The Following User Says Thank You to Floggin Tires For This Useful Post:
zdr93523 (06-16-2014)
Old 05-05-2014, 02:24 PM   #19
wparsons
wparsons's Avatar
This isn't directed at you, just general commentary...
I still stand by my original point, if it's correcting you like that then you're over driving the car. If there is enough grip to take that corner at 40mph and you're giving it smooth and correct inputs then it wouldn't be intervening.
You should be able to drive the track (or road) in the current conditions without relying on VSC to correct you before ever considering turning it fully off. If VSC steps in before you have taken any corrective measures you don't have the skills to save it without the nannies.
All that said, driving with VSC in sport mode on the street is still very safe, it doesn't give you much room to screw up before it brings you back to a more stable place.
I was at an HDPE over the weekend, and my instructor has a BRZ. We spent some time probing just how much the VSC will let you get away with, and the only time it stepped in was either when doing bad things (erratic inputs, etc) or when trail braking too much to get more rotation. Chances are that if you're working on perfecting trail braking harder, your skills are already very good though.
Some people seem to think that disabling VSC gives the car higher cornering limits, which it doesn't. VSC doesn't limit grip in any way, it just regulates slip angle.
flickr
Old 05-05-2014, 03:45 PM   #20
J_kennington
I hope it's not towards me, because I said I agree with you lol. Under normal conditions you shouldn't have to turn it off(is it technically turning on it? Maybe that's where some confusion comes in. I consider when I push the button it turns it off).
I only gave the example at the dragon because it's not a very forgiving road, and on stock tires you could tell they were wanting to spin in the constant hair pins at ~40-50mph. With all nannies on, I could literally feel less power throttling out of the turns, with vsc off car felt normal. Was I driving faster than I "should", that's a definite yes. But, it's part of "conquering the dragon".
2005 Yamaha yz250f
Old 05-05-2014, 04:20 PM   #21
wparsons
wparsons's Avatar
That sounds more like TC than VSC. You'll know VSC because it will add brake to one (or more) corner to stop a slide. VSC sport mode does give a bit more lenience in wheelspin before TC kicks in too.
For reference, I consider VSC on to be how the car starts up normally, VSC sport if you press the sport button, and off is holding the TC button for a few seconds until TC and VSC are off.
If you're getting wheelspin mid corner, you're probably on the gas either too soon, or too hard before unwinding the steering angle. It can be fun, but it's slower than waiting for grip.
flickr
Old 06-16-2014, 04:16 AM   #22
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I disagree with these comments. You should check out the video of the guy who went off track when the nannies freaked out over curbing.
Also, I track in diagnostic mode and frequently explore the car's limits. Even in sport, the nannies kick in anywhere from parking lots to roundabouts during daily driving. They can really make the car unstable when they intervene when you are expecting a certain amount of rotation, even when driving smoothly.
If you are on track using the nannies, then you aren't learning the nuances of your car yet, and if they aren't kicking in, then you aren't pushing your car, which is fine, not everyone wants to beat on their car or has the skill to push it yet.
They aren't there to save you on the track, they're there for stupid people who do overdrive their car or don't possess the skill to save the car during emergency situations.
Now, I typically leave them on for dd but can see the value of this product, if it did the pedal dance.
Sent from my LG-D800 using Tapatalk
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 06-16-2014, 05:41 AM   #23
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Just ordered thx
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-16-2014, 11:27 AM   #24
wparsons
wparsons's Avatar
Re-read what you quoted... I'll stand by what I said originally.
Until you have the skills to be driving without VSC kicking in, you shouldn't be disabling it. I'm not talking about people with lots of track experience pushing for more rotation, etc. I'm talking about beginners that lack the experience to properly correct without VSC saving them.
flickr
Old 06-16-2014, 11:39 AM   #25
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
On one corner bump of my daily commute, VSC almost always squeezes the left rear brake, which upsets the car more than the bump does, even in sport mode. It's not a perfect system. Still, I usually leave it on.
The Following User Says Thank You to EAGLE5 For This Useful Post:
zdr93523 (06-17-2014)
Old 06-16-2014, 11:42 AM   #26
akyp
Drives: 2012 86
Do USDM cars get different TC/VSC programming than the rest of the world? In the dry I can make the OE Michelins spin loudly and the TC won't do a damn thing about it. On mountain roads I drive with VSC Sport mode, and if I run over a pool of water I MUST correct it myself because VSC won't prevent me from going into a wall.
akyp is offline   Reply With Quote
Old 06-16-2014, 11:44 AM   #27
stugray
Drives: 2013 GBS BRZ Limited
It has been said before: "IF you drive this car on the street in such a way that the nannies are 'interfering with your driving style' then you drive like an asshat".
The Following User Says Thank You to stugray For This Useful Post:
wparsons (06-16-2014)
Old 06-16-2014, 12:21 PM   #28
EAGLE5
Dismember
EAGLE5's Avatar
To my knowledge, nobody has fully or at least publicly explored the VSC/VDC/ABS hardware and software.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 04:28 PM
Electric Power Steering control module? slicktop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-21-2013 09:38 PM
Innovate Motorsports FR-S/BRZ traction control state modifier module... mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-13-2013 02:06 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
