Old 05-16-2012, 10:18 AM   #15
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
I have never been one to race in stock class... just not in my nature... but If I were to compete in Stock class.. Here would be my take:
-Koni's with stock springs... Depending on what spring rate the FRS has Vs. BRZ I might change the springs out to one or the other.
-17x7 Light as possible wheel... maybe the Kosei with a 50 with a 5mm spacer to bring the tire back out away from the strut.
-not sure if 245 A6's will fit due to them running wide...might go with a Goodyear if that were the case.
-Swaybars are gray area right now on this vehicle.. have to wait and see the data.
-Lightweight Exhaust or my personal favorite is the JW2 Exhaust Turn-down..that completely eliminates the muffler... weight saved = about 40 pounds.
-Lightweight battery
-start with a base model FRS for weight savings..since weight is enemy in stock classes.
-crash bolts for front Camber if they become available.
-performance alignment...would definitely have to tinker with that to get optimum balance/turn-in/predictable agility
that would get me started..
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
ESBjiujitsu (05-28-2012)
Old 05-16-2012, 10:43 AM   #16
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The damper rule has a loophole in it the size of a hangar door. You're allowed only two usable adjustments. Adjustments to damper's gas portion are not counted, and any hydraulic adujstments above two just need to be glued in place. So if you want to spend a crap-ton of money on dampers you can. Just put a dollop of a silicone sealer on the least used adjustments before you bring the car to tech.
Old 05-16-2012, 11:34 AM   #17
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Bill
you wont be able to spring-swap in stock class. It has to be available from the manufacturer as an available package for the specific model of car you have.
Also I dont have my hopes up for a TSB from subaru for crash bolts. Its not something they typically do afaik. Technically the lame part of it all, if toyota offers them and releases a tsb and subaru doesnt, you will only be able to use crash bolts on the frs.
Last comment, you will want a smaller offset, positive offset puts the hub outboard of wheel center which drives the wheel more under the car. A +42 total offset will likely be optimal for stock class to get the most tire without rubbing the strut
Sccabrz192 is offline   Reply With Quote
The Following User Says Thank You to Sccabrz192 For This Useful Post:
Scooby South (05-16-2012)
Old 05-16-2012, 11:47 AM   #18
Dark_Angle
Dark_Angle's Avatar
Drives: 91 Turbo Mr2
Bill
So this is all stock legal?
Dark_Angle is offline   Reply With Quote
Old 05-16-2012, 11:48 AM   #19
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Lightweight battery would also technically be protestable because blatant weight reduction is against the stock rules
Old 05-16-2012, 11:48 AM   #20
Dark_Angle
Dark_Angle's Avatar
Does this exclude TRD items? They are specific for these cars from toyota.
Old 05-16-2012, 11:51 AM   #21
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Any performance related accessory, even if it is sold from the dealership which is not original equipment as part of an option or trim package is illegal unless it meets the modification guidelines. This includes TRD accessories.
Examples:
Legal: Trd front swaybar (provided you dont install a trd rear swaybar and vise versa.)
Illegal: dealer installed TRD springs. Unless Scion offers a TRD performance variant of the car as an option code. It that case you would need every piece of that equipment package. If the option package came with different seats and springs, you couldnt install the springs without the seats.
Old 05-16-2012, 11:56 AM   #22
Dark_Angle
Dark_Angle's Avatar
So removing the exhaust and adding the shorty pipe is probably a no no.
Old 05-16-2012, 11:58 AM   #23
EMguy
The rules reads as this:
No more than two separate external shock damping adjustment controls are allowed. This permits the use of shocks which originally came with more than two external adjustments, which have been converted to double-adjustables, only if the additional adjustment controls have been permanently disabled (e.g. via weld-ing, epoxying, grinding off). Gas pressure adjustment is not con-sidered a damping adjustment.
The key is "permanently disabled." I don't think a dab of silicone or glue counts. Moreover, I doubt you'll find many competitors trying to find an excuse to spend more money on triple adjustable, stock class legal shocks. The sipirit of the rule is a cost containment measure.
You're right about the gas pressure adjustment though: tuning gas pressure is one way of working around OEM spring rates.
EMguy is offline   Reply With Quote
Old 05-16-2012, 12:00 PM   #24
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Battery replacement is covered on p71 of the rules - helpfully linked by the OP:
Code:
Alternate components which are normally expendable and considered replacement parts (e.g., engine and wheel bearings, seals, gaskets, filters, belts, bolts, bulbs, batteries, brake rotors, clutch discs, pressure plates, suspension bushings, drivetrain mounts, fenders, trim pieces, etc.) may be used provided they are essentially identical to the standard parts (e.g. have the same type, size, hardness, weight, material etc.),
are used in the same location, and provide no performance benefit.
jdrxb9 is offline   Reply With Quote
Old 05-16-2012, 12:00 PM   #25
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
If its after the cat its legal per the exhaust allowance if it replaces or removes or is in front of the cat, yes it is illegal. I am not aware of the part you are referring to so im not 100% what it does.
Old 05-16-2012, 12:06 PM   #26
EMguy
That depends. You can do anything you want to the exhaust downstream of the catalytic converter. It's common to replace everything from that point on with a turn down pipe. The benefit is not power, but weight.
Since last year, there is an additional rule for national (and some local) events that cars must also pass sound requirements. This is <100 db at 50 ft. It's usually tested at an area of WOT.
In a stock car, with cats in place, I don't think there will be any problem passing sound just a turn down. Personally, I'll be looking for the lightest, single exit cat-back I can find.
The Following User Says Thank You to EMguy For This Useful Post:
Old 05-16-2012, 12:15 PM   #27
Dark_Angle
Dark_Angle's Avatar
I will probably leave it all alone because changing weight will change the handling characteristics of the car.
Old 05-16-2012, 12:41 PM   #28
jdrxb9
jdrxb9's Avatar
I'll be surprised if we see a TSB from Toyota because: AFAIK they've been putting the alignment/crash bolt info in the FSM for a while now; the FR-S manual shows the procedure with only one alternate bolt (which is actually the lower bolt used in the upper position instead of the normal upper bolt); the bolts do not have part numbers anything like the normal Toyota alignment/crash bolts. (link,link)
Since I'm pretty sure I'm getting a BRZ, I'm hoping we 1) don't need much static camber due to low roll, and 2) I'm right about no FR-S TSB
Last edited by jdrxb9; 05-16-2012 at 01:13 PM. Reason: corrected my 'upper lower bolt' error
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FORMULA D Round 1 Long Beach 2012 Discussion Thread Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 0 04-08-2012 02:43 AM
GT5 Stock GT86 Competition - March 2012 Deslock Off-Topic Lounge [WARNING: NO POLITICS] 34 04-01-2012 07:39 AM
2012 Mercedes A-Class Revealed ZetaVI Other Vehicles & General Automotive Discussions 12 03-06-2012 02:15 PM
GT5 Stock GT86 Competition - February 2012 Deslock Scion FR-S / Toyota 86 GT86 General Forum 100 03-01-2012 07:14 AM
