Old 04-14-2014, 08:16 PM   #15
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Mine just came in today as well, two days early. Here's some pics and I'll maybe get them put in today.
oldpueblo is offline   Reply With Quote
Old 04-14-2014, 08:48 PM   #16
mush
mush's Avatar
they look good, but ill stick to my OEM clears
Old 04-15-2014, 09:41 PM   #17
oldpueblo
oldpueblo's Avatar
All done, I didn't even peel away the tire well liner. This video shows the guy just putting the screwdriver into the perfect spot and twisting and it popped right out.
[ame="http://www.youtube.com/watch?v=LJJ3y36nvDQ#t=193"]Car Noob Ep. 4 - Aftermarket Turn Signal / Side Marker Install - YouTube[/ame]
Old 04-15-2014, 10:21 PM   #18
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
At cheaper than helix, how are we certain these won't leak too? You just won't notice water as easily since it's not clear (more reflective cover). Best of luck they don't, have to give us an update in a few months.
FiRStsc10n is offline   Reply With Quote
Old 04-15-2014, 10:29 PM   #19
oldpueblo
oldpueblo's Avatar
I did run it through a touchless car wash today as a test (the works wash). I didn't notice any water afterwards, I imagine it's not going to be much of an issue for me in Arizona.
Old 04-15-2014, 11:44 PM   #20
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
do these clear ones have a built in reflector ?
ucsmfu is offline   Reply With Quote
Old 04-16-2014, 12:18 AM   #21
FiRStsc10n
FiRStsc10n's Avatar
Originally Posted by Mooseknuckle44 View Post
Ideally I'd like to just delete the friggin thing but that's probably more labor intensive than it's worth.
Why not paint them?
There was a vendor talking about potentially selling them paint-matched not sure if that panned out.
Old 04-16-2014, 11:07 AM   #22
oldpueblo
oldpueblo's Avatar
More pics of them lit, and a video at night showing some reflectiveness (I hope).
[ame="https://www.youtube.com/watch?v=6-rACfMJAaI"]WP 20140415 21 51 08 Pro - YouTube[/ame]
*Will upload pictures later, for some reason they won't upload.
Old 04-16-2014, 11:46 AM   #23
Mooseknuckle44
Mooseknuckle44's Avatar
Originally Posted by FiRStsc10n View Post
Why not paint them?
I'd do it. Those lights do nothing for me personally.
Mooseknuckle44 is offline   Reply With Quote
Old 04-16-2014, 12:35 PM   #24
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
wow, they look good. No water leaking ?
Thanks
Old 04-16-2014, 02:29 PM   #25
oldpueblo
oldpueblo's Avatar
Okay here are some while lit in my semi-dark garage. I don't know if mine aren't fully flush because I'm bad at installing, or if that's just the way they are. What about you other guys that also installed these, are they perfectly flush?
Old 05-20-2014, 12:20 PM   #26
nekio
Drives: 2014 Black FR-S
Just got around to installing mine and I had a terrible experience. The metal clips used to hold the lights in place are extremely cheap compared to the factory one to the point where some wouldn't even hold in place. This lead to an unacceptable level of movement because the clips would bend or straight out come out of their socket by lightly wiggling the lights. In the end I used the metal clips from my original lights and fitted them (with a lot of work) to the new side markers.
What would have taken at most 15 min turned out to be 2 hours of work and it is still not has good as the OEM lights. If I had to do it again I would order the original Japanese parts. Buy at your own risk!
nekio is offline   Reply With Quote
Old 05-20-2014, 12:42 PM   #27
oldpueblo
oldpueblo's Avatar
Huh my experience was the exact opposite, having never done it before it was pretty quick and easy and they've held in fine now for over a month. Just out of curiosity what method did you use to remove the previous ones, maybe something got loosened/damaged? I used the method in the video I linked earlier.
Old 05-20-2014, 03:34 PM   #28
nekio
I used the same video, I must have had a shit set.
**JDM Style Clear and Smoked Side Markers** genometuning Exterior Parts - Lighting 156 08-04-2015 11:45 PM
*** JDM Style Clear/Smoke Side Markers -- Group Buy #2 *** 86_ZN6 Groupbuys 94 09-01-2013 05:32 AM
FS: Clear side markers (jdm style) with white LED built in Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 0 08-31-2013 02:44 PM
Help -Group buy for *** JDM Style Clear/Smoke Side Markers dlidkea Exterior Parts (Aero, Lighting, Etc.) 1 06-11-2013 09:29 PM
*** JDM Style Clear/Smoke Side Markers -- Group Buy! *** 86_ZN6 Groupbuys 193 06-04-2013 10:39 PM
