#15 |
Senior Addict
Drives: 86 GT
Great work mate!
#16 |
I'm using XP. When I plug in the Tarix for the first time I get: "Cannot install this hardware, there was a problem installing this hardware Open Port 2.0. an error occurred during installation of the device, the parameter is incorrect."
It also won't install the drivers thru ecu flash, asking for licensing information. EDIT: I had to install the driver from the Tatrix wenpage that it said not to use with ecuflash, then ecuflash was able to update the firmware.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib Last edited by regal; 04-18-2014 at 11:41 AM. |
#17 |
Drives: 2013 Asphalt FR-S
Great writeup, thank you for posting.
~Namaste~ |
#18 |
I'm trying to update to ZA1B01C. I've downloaded the rom and xml file from here. However ECUflash doesn't recognize the xml file.
Does anyone have a matched pair for the latest factory Calib for ECU Flash ZA1B01C ?
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib Last edited by regal; 04-18-2014 at 12:06 PM. |
#19 |
I guess using the drivers off the tatrix site was a mistake. ECUflash won't even read the stock rom.
Unfortunately windows doesn't recognize the OpenPort and the EcuFlash program linked above doesn't have the drivers either. I am afraid the Tatrix is not ready for prime time for our cars too many issues.
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#20 | |
AutoX Nut
Drives: 2020 Toyota Supra
#21 | |
I tried that and it works as you see the drivers working with the non-beta, but then when I install the beta it erases the drivers. I'm using XP maybe that's the problem, also the non beta was a fairly older version.
| The Following User Says Thank You to regal For This Useful Post: | steve99 (04-19-2014) |
#22 | |
AutoX Nut
So, you confirmed that your computer did recognize your OP2 with the Non-Beta version, but then it lost recognition when you installed the BRZ-Beta right after? |
#23 |
I got the driver situation figured out. You have to start with the latest ECUFLash 1.44 get that installs the drivers and gets your firmware. Then install the beta posted above over top. Thanks for the suggestion I was close.
Now I was able to read my stock calib ZA1JA00C, no wonder the engine stumbles. I just need help finding a matching pair of rom + def file for the latest calib ZA1JB01C. I believe I've tried everything posted on this site and still get the error that the def file doesn't match the rom. Anyone?
#24 |
OK I got the hex file TD-D to read with the github def file. I'm ready to flash but was wondering if there is a how to flash basics guide somewhere, like ignition on-off etc.
#25 |
Screw it I flashed it. My 2 year old FR-S now has the latest 2014 Factory Calibration. Screw the dealer and thank you GT-86 Forums!
#26 |
Added some note to original post re getting drivers from tactrix site for beta and quick flash guide
#27 |
Drives: .
Just a heads up...you need to use a <=2Gb microSD card with the OP2 logging using the Tactrix. Anything bigger and it wont work.
#28 |
That,s weird mate, I'm using a 4Gb in mine and its fine. My tactrix is only a couple of months old though. did you format card as FAT32 ?
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 01:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 11:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 09:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 11:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 08:27 AM |
