#15 |
Drives: 13 Subaru BRZ Limited
Does anyone use a dashcam to leave on over night? I have to park on the street in Chicago and the car recently got broken into. I'm thinking about a discrete dashcam setup that stays on after the ignition is turned off and holds the last 48 hours of video (or something like that).
Just want to increase the possibilities of catching someone doing whatever to my car, especially a hit and run situation during parking...happens way too often here. |
#16 | |
Elite Recognized Geek
Drives: 2014 DGM BRZ Limited
I believe most dashcam manufacturers offer a similar power rig, and most also will have the ability to only trigger recording when motion is detected.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+ |
| The Following User Says Thank You to codesplice For This Useful Post: | bobaab (04-01-2014) |
#17 |
Hail Magnet
Just purchased an OJO cam, looks like it will be a huge improvement over the clunker I have as a dash cam now. Thanks for the heads up!
#18 | |
Drives: FRS
I saw the roadhawk brand had a power unit it inline filter for voltage drop threshold to prevent battery overdraw..
I think I'll probably go this route myself. Quote:
#19 |
Drives: White '17 86
With any dash can that is kept in the car during hot days. I recommend that you either remove battery or remove the camera when you aren't using the camera. My finevu battery expanded in the Texas heat. Caused some component damage.
#20 |
1337
Drives: 2013 BRZ WRB S/C
The OJO/Mini 0801 is very tempting - I will likely be picking one up!
#21 | |
Drives: 2005 Toyota Camry
But if it's used only as a dash cam, water isn't an issue. The real issue with a GoPro is that it doesn't loop/record over itself. Imagine you went on a 2 hour drive and got in an accident... do you have to know how to edit video files to present evidence? 5 minute clips are a thing of beauty. -alex |
#22 | |
Hail Magnet
#23 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
Does the ojo require a power cable at all times or is it just to recharge an internal battery?
#24 | |
Drives: '14 BRZ
Yeah the action frame would avoid that too. |
| The Following User Says Thank You to Ec1990 For This Useful Post: | mav1178 (04-04-2014) |
#25 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
http://www.aliexpress.com/item/Best-...715941624.html |
#26 |
Drives: FRS
got the powerucc panorama 2
now if only my touchup paint would come in ![]() Thanks for all the recommendations folks!
#27 |
Drives: 2014 FR-S, Asphalt (obviously, lol)
I was thinking of getting something like this more or less..
[ame="http://www.amazon.com/Abeo-HDVR-150-Accident-Camera-Recorder/dp/B005GTKY24/ref=sr_1_10?ie=UTF8&qid=1397121297&sr=8-10&keywords=dash+cam"]http://www.amazon.com/Abeo-HDVR-150-Accident-Camera-Recorder/dp/B005GTKY24/ref=sr_1_10?ie=UTF8&qid=1397121297&sr=8-10&keywords=dash+cam[/ame] But I have a general dash cam question: where do you guys recommend I plug it in so it's neat? The front dashboard only has that usb port, there's a cigarette lighter in the middle console but that just seems too far and awkward, and then there's the cigarette lighter in the glove box but I don't even know if it that's viable option.
#28 | |
Drives: Ultramarine FR-S
Pull out your dome light from your headliner and reach in there towards the back of the car, there's an accessory plug that's for the auto dimming mirror, you can tap into that for accessory switched power. |
| DYI Request, Removing dash board | Stratoside | DIY (Do-It-Yourself) Guides | 11 | 05-15-2014 10:17 AM |
| [Request] Double DIN dash | Mikeez | Electronics | Audio | NAV | Infotainment | 10 | 02-02-2014 02:32 AM |
| Request: Dash Cam install w/ pics of A-Pillar/headliner | 1Cor10:23 | DIY (Do-It-Yourself) Guides | 13 | 01-16-2014 08:31 PM |
| Non LED recommendation for DRL | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-11-2013 06:34 PM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 11:06 PM |
