Old 03-19-2014, 07:23 PM   #15
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by solidONE View Post
I cut mine with a box cutter. Exacto would work. I wouldn't recommend using a saw as you'll end up with ragged chewed up cut. Exacto or surgical blade, I'd recommend using.
Thanks, I wasn't sure what kind of durometer rating the oem stops had, this should be fairly easy then.
Gunman is offline   Reply With Quote
Old 03-19-2014, 10:35 PM   #16
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Originally Posted by DAEMANO View Post
No probs and best of luck. If you have to end up ordering from Eibach, I can provide the part numbers. PM me.
I'm pretty sure I may have to order em from Eibach. Sending a PM to you as of now. Going to wait one more day to see if he can find it.
Bach415 is offline   Reply With Quote
Old 06-10-2014, 02:48 AM   #17
Bach415
Bach415's Avatar
By any chance do anyone have the part numbers for the bumpstops used for the sportline springs?
Old 06-12-2014, 02:25 AM   #18
DAEMANO
Time Traveller
Thought I PM'd this. In any case, here you go.
1J0412303 Front Bump Stop $30.00ea
BS770143 Rear Bump Stop $30.00ea
BS770043 Dust Boot $30.00ea
The Following User Says Thank You to DAEMANO For This Useful Post:
Bach415 (06-12-2014)
Old 06-12-2014, 04:04 AM   #19
Bach415
Bach415's Avatar
Do you think the 1J0412303 is the same bumpstops used in the VW? It looks the same imo.
Old 06-12-2014, 09:24 AM   #20
DAEMANO
Time Traveller
Bumpstops can look alike but the durometer can be quite different. I wouldn't try eyeballing it.
Old 06-13-2014, 01:48 AM   #21
Bach415
Bach415's Avatar
For people know needs to know how long the bumpstops are for the sportline, here it is:
Front 54mm (2 1/8 inch)
Rear 35mm (1 3/8 inch)
The Following User Says Thank You to Bach415 For This Useful Post:
DAEMANO (06-13-2014)
Old 07-30-2019, 09:55 AM   #22
Dan Lorenzo
Drives: 2013 scion frs black
Dont
At dealer .my friend said it was ok to put the ones the car came with. He was wrong it squeak all the time dealer open hood look and spot the problem quick iuse the ones that came in box.
Dan Lorenzo is offline   Reply With Quote
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
Ebiach Sportline lower spring bumpstop questions benlaz88 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-16-2014 03:28 AM
STX question JerryMichaels7 Tracking / Autocross / HPDE / Drifting 6 01-22-2014 11:52 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
Almost there.....but question VENOM~ CANADA 25 08-22-2012 05:39 PM
