Old 05-12-2012, 03:22 PM   #15
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by frs_gt86 View Post
my FRS has JF1Z **** as well
Originally Posted by dori. View Post
I guess that's just a mistake.
yours shoud start as JF1ZN, correct? Since it is FR-S/86.
BRZ will be JF1ZC.
Originally Posted by Phaedrus29 View Post
Do you mean JF1N? According to the OP, "Z" stands for BRZ line...that'd be wrong if the FRS has a Z too...the digit after the Z doesn't seem to be the issue frs_gt86 was pointing out.
Just an uneducated guess on that digit. It could stand for the platform. Since the platforms are identical, ergo "Z" works for both.
My FRS is JF1ZN. Perhaps the N is what designates between the BRZ and the FRS?
From the VIN's I've seen so far, it's looking like "N" does stand for FR-S.
Decoder works for my vin.
Originally Posted by Laika View Post
Works for mine too. What does the check digit mean?
Originally Posted by ajay View Post
works for mine
Originally Posted by taosracer View Post
I got #307 Thanks for the decoder
Thanks for the feedback fellas
Originally Posted by Enemies View Post
http://auto.howstuffworks.com/buying-selling/vin.htm
Explains the Check Digit and some other things that people might find interesting.
Interesting read. Now to find out what the weight of each digit is...or is that even possible
MannyO is offline   Reply With Quote
Old 05-12-2012, 04:39 PM   #16
dori.
Seρor Member
dori.'s Avatar
Drives: white BRZ 6MT
just so you guys know, pretty much every car's VIN includes the chassis code in some form.
BRZ is ZC6.
86/FR-S is ZN6.
dori. is offline   Reply With Quote
Old 05-12-2012, 06:39 PM   #17
Phaedrus29
Phaedrus29's Avatar
BRZ is ZC6.
86/FR-S is ZN6.
Do you mean ZCA and ZNA?...or do you mean the "6" in the 12th digit?
Phaedrus29 is offline   Reply With Quote
Old 05-12-2012, 06:54 PM   #18
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I think he meant short Chassis code. Not the VIN chassis code
iirc
Z - Boxer
C/N - BRZ/FRS
6 - Engine type
Old 05-12-2012, 11:07 PM   #19
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
I think I can chime in on some info about the VIN. Here are some samples of the VINs for BRZ and FRS:
BRZ VINs
JF1ZCAC16D1600049 - Limited 6 Speed Manual Galaxy Blue Silica (Pre-production demo shown in NE)
FRS VINs
JF1ZNAA14D1700129 - MD Firestorm
JF1ZNAA12D2700446 - NC Firestorm AT
So as you can see these:
1. The manufacturing company is JF1 (FHI. There are JF1 and JF2 for FHI so JF1 *may* means factory 1 - main).
2. ZCA is for BRZ where as ZNA is fore FRS
3. C1 is for BRZ limited, B1 is for BRZ premium, and A1 is for FRS. The 1 in this word is for restraint type.
4. the next digit is for check number. Algorithm follows later.
5. D for model year 2013
6. the next digit (11th) is for plant/transmission code. In this case, 1 for manual and 2 for automatic transmission. For some other brand, this could means the plant number.
7. digit 12-17 are the sequence code. Here is something strange between FRS and BRZ. The pre-production of BRZ starts with 6. I wonder if the regular BRZ also starts with 6 or do you have a different number. Furthermore, all the FRS I found so far all starts with a 7. I am not sure if this is true for all the cases.
Now the check-digit algorithm: (copied from WIKI http://en.wikipedia.org/wiki/Vehicle...ication_Number)
Code:
If trying to validate a VIN with a check digit, first either:
(a) remove the check digit for the purpose of calculation; or
(b) utilize the multiplicative property of zero in the weight to cancel it out.
The original value of the check digit is then compared with the calculated
value. If the two values do not match (and there was no error in the
calculation), then there is a mistake in the VIN. However, a match does not
prove the VIN is correct because there is still a 1 in 11 chance of any two
distinct VINs having a matching check digit: an example of this would be the
valid VINs 5GZCZ43D13S812715 (correct with leading five) and SGZCZ43D13S812715
(incorrect with leading character 'S').
Transliterating the numbers
Transliteration consists of removing all of the letters, and substituting them
with their appropriate numerical counterparts. These numerical alternatives
(based on IBM's EBCDIC) can be found in the following chart. I, O and Q are not
allowed, and can not exist in a valid VIN; for the purpose of this chart, they
have been filled in with N/A (not applicable). Numerical digits use their own
values.
Transliteration key: values for VIN Decoding
A: 1     B: 2     C: 3     D: 4     E: 5     F: 6     G: 7     H: 8     N/A
J: 1     K: 2     L: 3     M: 4     N: 5     N/A     P: 7     N/A     R: 9
        S: 2     T: 3     U: 4     V: 5     W: 6     X: 7     Y: 8     Z: 9
S is 2, and not 1. There is no left-alignment linearity.
Weights used in calculation
The following is the weight factor for each position in the VIN. The 9th
position is that of the check digit. It has been substituted with a 0, which
will cancel it out in the multiplication step.
Position     1     2     3     4     5     6     7     8     9     10     11     12     13     14     15     16     17
Weight         8     7     6     5     4     3     2     10     0     9     8     7     6     5     4     3     2
Worked example
Consider the hypothetical VIN 1M8GDM9A_KP042788, where the underscore will be
the check digit.
VIN         1     M     8     G     D     M     9     A         K     P     0     4     2     7     8     8
Value         1     4     8     7     4     4     9     1     0     2     7     0     4     2     7     8     8
Products     8      28     48     35     16     12     18     10     0      18     56     0      24     10     28     24     16
1. The VINs value is calculated from the above table, this number will be used
   in the rest of the calculation.
2. Copy over the weights from the above table.
3. The products row is a result of the multiplication of the vertical columns:
   Value and Weight.
4. The products (8,28,48,35..24,16) are all added together to yield a sum of 351
5. Find the remainder after dividing by 11
   351 MOD 11 = 10
   351 χ 11 = 31 10/11
6. The remainder is the check digit. If the remainder is 10 then the check digit
   is X. In this example the remainder is 10, so the check digit is
   transliterated into X.
With a check digit of 'X' the VIN: 1M8GDM9A_KP042788 is written as:
1M8GDM9AXKP042788.
Straight-ones (seventeen consecutive '1's) will suffice the check-digit. This
is because a value of one, multiplied against 89 (sum of weights), is still 89.
And 89 divided by 11 is 8 with the remainder being the fraction "1 over 11,"
thus 1 is the check digit. This is an easy way to test a VIN-check algorithm.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
The Following 2 Users Say Thank You to Want.FR-S For This Useful Post:
mo8ius (12-22-2012), SkullWorks (05-22-2012)
Old 06-11-2012, 03:23 PM   #20
Flat Black VW
Flat Black VW's Avatar
got mine right-
6MT SWP BRZ
got number 00911 which is perfect for me since I grew up a Porsche fan.
Flat Black VW is offline   Reply With Quote
The Following User Says Thank You to Flat Black VW For This Useful Post:
MannyO (06-11-2012)
Old 06-11-2012, 03:29 PM   #21
MannyO
Night Owl
MannyO's Avatar
Originally Posted by Flat Black VW View Post
got mine right-
6MT SWP BRZ
Nice! I have #906. Your car was only 5 away from mine on the production line.
Old 06-11-2012, 03:48 PM   #22
sesmls
Drives: DGM BRZ Limited, 05 Baja Turbo
I have 00071...does anyone know how many of the pre-production cars were made -- would those be on the same numbering scheme? I was thinking if there were 25 or 50 of those made, a 71 would actually be more like the 21st or 46th US production vehicle, but wasn't sure if this was the case.
sesmls is offline   Reply With Quote
Old 06-11-2012, 04:12 PM   #23
Jayde
Jayde's Avatar
Thanks for the info! #635 for me.
Jayde is offline   Reply With Quote
Old 06-30-2012, 03:18 PM   #24
kndonlee
We should make out.
JF1 ZNAA1 8 D 2 700306
kndonlee is offline   Reply With Quote
Old 06-30-2012, 03:23 PM   #25
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
oo nice little find. 131 !
Furtive is offline   Reply With Quote
Old 06-30-2012, 04:10 PM   #26
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
971 here!
ShoGun is offline   Reply With Quote
Old 11-17-2012, 12:42 AM   #27
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
sbxjap is offline   Reply With Quote
Old 11-17-2012, 04:07 PM   #28
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
What is USDM?
Admiral Ballsy is offline   Reply With Quote
brz vin, decoder, vin, vin#
List differences between USDM and JDM specs ayau BRZ First-Gen (2012+) — General Topics 28 03-01-2012 03:06 PM
Pics of a USDM Premium interior? Grimlock BRZ First-Gen (2012+) — General Topics 17 02-19-2012 05:28 PM
Why does USDM model get the smaller muffler tips? ayau Scion FR-S / Toyota 86 GT86 General Forum 23 12-26-2011 07:39 AM
Insideline's USDM BRZ test review madfast BRZ First-Gen (2012+) — General Topics 95 12-08-2011 05:52 AM
