Old 03-21-2014, 03:31 PM   #15
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by teamturbo View Post
Anyone brave enough to use that Sea Foam cleaner? Supposedly works, but looks kinda scary...not sure I'd want to put that in my baby's engine!
...... what is scary about it?
supramkivtt2jz is offline   Reply With Quote
Old 03-21-2014, 03:39 PM   #16
stugray
Drives: 2013 GBS BRZ Limited
Whoa! wait. I dont see dual springs in that pic above.
These engines dont have dual springs?
I thought valve float was an issue above ~6k unless you had dual springs....
Old 03-21-2014, 03:46 PM   #17
w00t692
Drives: 2008 Civic Si
shit works fine lol.
w00t692 is offline   Reply With Quote
Old 03-21-2014, 03:47 PM   #18
w00t692
my si revs to 8600 rpms safely with 55 lb single springs...
Now i rev to 9000 rpms with 88lb dual springs.
Old 03-21-2014, 03:49 PM   #19
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
55k on my odometer and I don't think there has been any loss. I also don't notice any hesitation, or idle issues. I've been running 93/E10 pretty much the whole time aside from a couple tanks of 91 when in Iowa.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 03-21-2014, 03:50 PM   #20
w00t692
Basically my post was to say, single springs aren't really the limiting factor on revving high. It's more dependent on your camshafts and the springs ability not to coil bind and hold the seat firm.
Old 03-21-2014, 05:18 PM   #21
teamturbo
teamturbo's Avatar
All that fog! I've read the stuff can damage O2 sensors, etc. Maybe I'm just talking out of my ass...
teamturbo is offline   Reply With Quote
Old 03-21-2014, 05:28 PM   #22
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
negative. it wont hurt anything.
Old 03-21-2014, 10:26 PM   #23
mike the snake
On intakes that are REALLY clogged up with carbon buildup, I wondered whether Seafoam might break large chunks of carbon loose that then find themselves stuck in, or clogging up the catalytic converters.
I did read that the stuff works. On DI-only cars, it can't be added to the fuel because no fuel touches the intake ports or valves, so it needs to be sprayed into the intake, upstream of the valves.
Old 03-22-2014, 12:34 AM   #24
mrk1
Drives: Sterling BRZ Ltd
Run a catch can and drive it like its meant to be, let it warm up. I'm not a fan of any of those sea foam cleaners.
Even with the port injectors I believe we will see problems with these motors and build up when they are older and higher miles.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-22-2014, 01:14 AM   #25
Poodles
Drives: 2015 Series.Blue
Read the MSDS on Seafoam and you'll know why it's in a steel bottle instead of aluminum...
(hint: I'll NEVER use the stuff)
Old 03-23-2014, 12:43 AM   #26
mike the snake
With all the "snake oil" products on the market, Seafoam is one of the only products I've seen old-timers and knowledgeable people say actually works.
It has many uses, as a gas and oil stabilizer for storage, engine and trans cleaner (I read about people adding it just before rebuilding or working on stuff because it cleans everything so well). It also works to soften and remove carbon on valves and combustion chambers.
It does work.
That said, I wouldn't use it on my new car personally.
Old 03-23-2014, 02:55 AM   #27
Poodles
Has a million uses...uses that destroy engines, transmissions, catalytic converters...
Old 03-23-2014, 10:33 AM   #28
Mikem53
Drives: FR-S 6MT
It's Dependent on the weight of the valve.
Mikem53 is offline   Reply With Quote
eguerin's SSM/Carbon BRZ Build eguerin Member's Car Journals 9 07-08-2014 04:53 AM
JUN carbon intake box Kakawate Engine, Exhaust, Transmission 2 11-20-2013 12:53 AM
AIRAID u-build-it intake system swift996 Engine, Exhaust, Transmission 9 03-19-2013 01:33 PM
Carbon fiber intake Hawk77FT Engine, Exhaust, Transmission 17 01-17-2013 04:58 PM
dual injection is just a long overdue solution to carbon build up? Hasjwandje Engine, Exhaust, Transmission 19 11-08-2011 06:53 PM
