#15 | |
#16 | |
Drives: 2012 86
#17 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I had the P0351 error after my tune(BRZ Edit). Tuner said it was most probably the coil packs, so I've since changed out my coil packs and also changed out the spark plugs to HKS(since the coil pack had to come out anyway). No problems since.
My car is a JUNE 2012 build though if that's any help to you. I'd see if you can get the coilpacks replaced under warranty, they are a pricey bit of kit. Okada Projects coil pack set me back almost $1k. If you DO change the coil packs, and ALSO get new plugs make sure to get Denso heat rating 8 or 9s. Last edited by stevo_12v; 03-12-2014 at 09:10 AM. Reason: Typo |
#18 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
#19 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Took delivery in July 2012 so its certainly an early build date and I only tracked 3 times with the A00C ROM it shipped with, had no detonation issues with 93 octane gas + Torco Accelerator + shifting intentionally slow.
Have been EcuTek tuned with A01C since August 2013 and B01C since last Friday with the addition of a Flex-Fuel kit. Engine oil cooler equipped September 2013; several track days since. No issues aside from P0351 once a few days ago when doing 2nd-3rd gear WOT pull for a data log. Haven't been able to replicate since with similar inputs. I have a new revised OEM coil on the way. No other issues. |
#20 |
Troll Level: Expert
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Good info on here so far guys. I tracked my car 3 times with no issue as well before I got the P0351 code. It seems that the A01C may be the cure. It sucks that Subaru isn't offering it, but most tuning solutions do. I think OFT tunes are based off of it (what I'm looking at). Preferably, I would rather not tune the car and try to maintain somewhat of a warranty but that seems impossible now.
Nick K.
NASA ST5/TT5 #130 Southeast Region |
#21 |
Was this a TSB / recall? Thanks.
#22 |
Drives: 2013 SWP BRZ
Feb 2013 build date, stock engine, no tune, about 10 total track days on the car, no CEL or issues whatsoever (knock on wood).
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#23 |
#24 |
Troll Level: Expert
Sounds like we should have bought scions. I regret this every day. Sent from my iPhone using Tapatalk
Nick K.
#25 | |
Sent from my SGH-I317M using Tapatalk
#26 |
Lap time enthusiast
Correct me if I'm wrong, but pulls are done in a single gear so it wouldn't be subject to the problem diagnosed by Toyota. The injector problem persists when there's shifting thrown in the mix. Going from 7400rpm to 5200 from WOT-lift-WOT results in knock. At the track most of my time is spent in gears 3-4, with an occasional 5th gear straight. So that's a lot of knock.
#27 | |
#28 |
Reverse Burnouts
Drives: 2013 Argento FRS
mine has a 4/12 build date and ive been running the stock tune without the update and havn't had any problems ?
50k miles, driven hard on the street, some track time( been drifting about 5-6 times at the local drift track, and some back roads rally crossing)
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
| FR-S / BRZ reliability stats | mkaresh | Scion FR-S / Toyota 86 GT86 General Forum | 82 | 03-12-2017 02:40 PM |
| Concerned with reliability... should I be? | hmong337 | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 07-01-2013 07:02 AM |
| ECU Tuning for Reliability | regal | Engine, Exhaust, Transmission | 7 | 06-27-2013 07:07 AM |
| Scion top rated for reliability | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 10-29-2012 04:13 PM |
