Old 03-13-2014, 12:44 AM   #15
Sniper2606
Sniper2606's Avatar
Originally Posted by diss7 View Post
I won't retract nor apologise, YOU are wrong.
You then link to a smaller supercharger pulley. For a supercharger the OP doesn't have.
But i do have the Vortech SC kit
Sniper2606 is offline   Reply With Quote
Old 03-13-2014, 12:58 AM   #16
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Sniper2606 View Post
I see, well the acceleration is not the greatest sometimes, anything else i can do besides E85?
Downshift
You will realize that when you need power, downshifting is the way to do it with a centrifugal.
A 3.125" supercharger pulley will also help the midrange
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
SmsAlSuwaidi (03-13-2014)
Old 03-13-2014, 01:06 AM   #17
msile
msile's Avatar
Drives: ISF
I have the Vortech with a Perrin pulley and a CF driveshaft. The engine / drive-train feels peppier specially on the track.
You say that with the Vortech, the car is not fast?? My car feels pretty damn quick. I guess it is relative.
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
Old 03-13-2014, 01:11 AM   #18
Cal3000
Drives: Panda FR-S
I don't understand why people always state that a lighter crank pulley will do nothing for a supercharger. By placing a smaller pulley, you are reducing the mass moment of inertia at the crank and the crank is the main component that drives the supercharger.
It may be negligible at high RPMs, but when you don't see that much boost at low RPMs, I believe it can help increase the angular acceleration at the crank. It works similar to a flywheel.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 03-13-2014, 06:32 AM   #19
NickFRS
Drives: 2013 Asphalt FRS
I have a light weight flywheel and crank pulley.... but on a innovate.... Now to get a 70mm charger pulley.... P.s You WILL see a increase in torque n some slight hp with a flywheel.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 03-13-2014, 07:30 AM   #20
diss7
Drives: AE86, 2x GT86, TE27
Sigh
diss7 is offline   Reply With Quote
Old 03-13-2014, 10:17 AM   #21
mswhong
A pulley for a supercharger, a supercharger the OP doesn't have.
OP is talking about a crank pulley.
You said a smaller crank pulley will increase boost, it won't, it will drive all accessories including a supercharger slower.
A smaller supercharger pulley will increase supercharger drive. But a smaller crank pulley will have the opposite effect.
Again, refer my signature.
Umm???? I was talking about a smaller super charger pulley this WHOLE time mate - please learn to read before spouting your shit towards me - why the hell would you get a smaller crank pulley whilst on a super-charged application? That's fkn ridiculous as you said in your argument it will under-drive the supercharger.
Where in my two posts did i mention anything about a CRANK pulley? I just stated to OP to get a smaller diameter pulley (FOR THE SUPERCHARGER). Jesus, I thought you would've taken that as a given mate considering how long you've been on this forum and the number of posts you've made.
mswhong is offline   Reply With Quote
Old 03-13-2014, 11:23 AM   #22
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by mswhong View Post
I think what OP is looking for is a smaller diameter pulley, rather than one that is lighter. A smaller diameter pulley will make the "night and day difference" you were looking for as it allows you to run more boost.
You did not specify what type of pulley you were talking about. OP asked about a crank pulley. Without specifying that you are referring to a supercharger pulley, one can only assume since you are replying to the OP and that you are referring to the pulley he is asking about.
Your initial post is not clear enough.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
diss7 (03-13-2014)
Old 03-13-2014, 12:03 PM   #23
djdnz
1337
" it's more important to sound like you know what your on about rather than actually have that knowledge" - Willie "box slam" Nicholls
You keep referring to your signature, which I believe makes you think you sound smart, however it doesn't work that well when you incorrectly spell "you're
diss7 (03-13-2014)
Old 03-13-2014, 12:06 PM   #24
djdnz
1337
OP, changing your crank pulley is not going to make an appreciable difference. Some people might disagree, but when we're talking forced induction, any sort of gain to be had from changing the crank pulley is completely insignificant to what can be gained by changing your supercharger pulley.
By decreasing the diameter of the supercharger pulley, and making sure that your tune is either compatible or updated is going to increase the amount of boost the supercharger will create. More boost can equal a lot more power, if it's tuned correctly of course.
Old 03-13-2014, 03:55 PM   #25
DJCarbine
Thupercharged
DJCarbine's Avatar
IMO with the added rotating mass of a centrifugal, shaving a small amount of weight off the crank pulley will not be cost effective... the money is better spent on a smaller SC pulley which is less than $100.... another 20-30 for the belt
Just my opinion though
2013 FRS
Vortech V3 11psi
Old 03-13-2014, 04:20 PM   #26
diss7
That's actually an inside joke. Willie is a friend with a lot of knowledge that is easily wound up. One thing that sets him off is when you point out that he's used your/you're incorrectly.
Old 03-13-2014, 04:25 PM   #27
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
If you want to make the Vortech faster then Wastegate it
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 07:45 PM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 11:12 AM
F/S Perrin Crank Pulley ShoNUFF Engine, Exhaust, Bolt-Ons 6 06-25-2013 07:49 AM
F/S Perrin Crank Pulley ShoNUFF NY / NJ / CT / PA 0 06-21-2013 08:52 PM
FS: New Perrin BRZ / FR-S Crank Pulley - Red JPxM0Dz Canada Classifieds 6 05-07-2013 11:23 AM
