#15 | |
Drives: 2016 Cadillac CTS
I have Apple CarPlay now and I'd never try something like this again except for funsies. I just enjoy having something that works, is responsive, and automatically updates. |
| The Following User Says Thank You to Prog For This Useful Post: | CxG (04-20-2017) |
#16 |
Drives: Pearl White '13 ZN6
I'm and android fan so I'll be rooting my nexus this weekend, getting ready to install soon. I figure this with the little 3D printed plastic pieces for the edges should be clean enough (hopefully). I wouldn't mind learning how to make a custom dash but I want it to look good and don't know how long that'd take
#17 | |
Drives: Scion FR-S Ultramarine
#18 |
Drives: BRZ 2013 MT
I just removed the battery on my tablet and wired it into a constant 5V and it recieves power for timurs on/off function from my usb hub which is wired to accessory. Zip tied it to my bezel so no ghettoness on the outside.
| The Following User Says Thank You to kt45 For This Useful Post: | CxG (05-03-2017) |
#19 |
#20 | |
#21 |
Drives: BRZ 2013 MT
Ill probably put together a build thread in a bit. But basically you wire in a usb car phone charger to your 12v constant. Then you take a usb cable and solder the v+ and GND to the wires and pcb of the nexus 7 battery after you separate the connector/pcb from the battery. Theres a video on youtube somewhere.
Heres how it looks mounted.
| The Following User Says Thank You to kt45 For This Useful Post: | CxG (05-11-2017) |
#22 |
Removable Nexus 7 install
Why don't people just use the tablet mount instead? It's a lot easier to install and you can take it out whenever u want and be able to keep your volume knob
Also, anyone using nexus 7 2nd gen? Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to allowe For This Useful Post: | CxG (05-11-2017) |
#23 | |
Drives: Neptune GR86
I had a 2nd gen in dash with my WRX with working steering wheel controls, auto power on/sleep etc...
| The Following User Says Thank You to Andrew025 For This Useful Post: | CxG (05-11-2017) |
#24 |
Drives: BRZ 2013 MT
Yep actually looks like it belongs there instead of hanging off of your dash. I feel like it can be mistaken as a oem unit this way. Integrated SWC working as well. Only issues I have with my 2nd gen are with Timurs kernel not turning off and has to be unplugged to suspend. His blog says its likely a cranking issue. Anyone come across this?
| Nexus 7 Install and Customization | gdrider77 | Electronics | Audio | NAV | Infotainment | 18 | 06-07-2016 11:35 AM |
| Nexus 7 DIY dash install | Casper | Electronics | Audio | NAV | Infotainment | 16 | 01-17-2016 12:28 PM |
| Another Nexus 7 install: Clean and Easy | Sojhinn | Electronics | Audio | NAV | Infotainment | 264 | 10-30-2015 08:26 AM |
| Problems with NEXUS 7 Install | Rhamzy | Electronics | Audio | NAV | Infotainment | 6 | 01-03-2014 03:43 AM |
