Old 04-12-2017, 06:11 PM   #15
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by phanguy View Post
no real clean way to do it unless you are ready to learn(or already know how) to fabricate custom dash pieces. this is what i did when i left the nexus 7 and went to an ipad mini install.
Yeeeupp. I eventually gave up on the magnet thing because it would just randomly fall apart (the glue that held the brackets wouldn't stick...even though it was for gluing plastic, I guess it didn't work well on that type of plastic).
I have Apple CarPlay now and I'd never try something like this again except for funsies. I just enjoy having something that works, is responsive, and automatically updates.
Prog is offline   Reply With Quote
The Following User Says Thank You to Prog For This Useful Post:
CxG (04-20-2017)
Old 04-20-2017, 11:40 AM   #16
CxG
Drives: Pearl White '13 ZN6
I'm and android fan so I'll be rooting my nexus this weekend, getting ready to install soon. I figure this with the little 3D printed plastic pieces for the edges should be clean enough (hopefully). I wouldn't mind learning how to make a custom dash but I want it to look good and don't know how long that'd take
CxG is offline   Reply With Quote
Old 04-21-2017, 01:32 AM   #17
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
if you can use a dremel, bondo, sand paper, and spray paint then you're good to go.
phanguy is offline   Reply With Quote
Old 04-24-2017, 11:40 PM   #18
kt45
Drives: BRZ 2013 MT
I just removed the battery on my tablet and wired it into a constant 5V and it recieves power for timurs on/off function from my usb hub which is wired to accessory. Zip tied it to my bezel so no ghettoness on the outside.
kt45 is offline   Reply With Quote
The Following User Says Thank You to kt45 For This Useful Post:
CxG (05-03-2017)
Old 05-03-2017, 09:50 AM   #19
CxG
Pictures?
Old 05-09-2017, 02:29 PM   #20
allowe
allowe's Avatar
are you still using the nexus 7? did you do anything differently? hows sound quality?
allowe is offline   Reply With Quote
Old 05-09-2017, 04:55 PM   #21
kt45
Drives: BRZ 2013 MT
Pictures?
Ill probably put together a build thread in a bit. But basically you wire in a usb car phone charger to your 12v constant. Then you take a usb cable and solder the v+ and GND to the wires and pcb of the nexus 7 battery after you separate the connector/pcb from the battery. Theres a video on youtube somewhere.
Heres how it looks mounted.
CxG (05-11-2017)
Old 05-09-2017, 04:58 PM   #22
allowe
allowe's Avatar
Removable Nexus 7 install
Why don't people just use the tablet mount instead? It's a lot easier to install and you can take it out whenever u want and be able to keep your volume knob
Also, anyone using nexus 7 2nd gen?
The Following User Says Thank You to allowe For This Useful Post:
CxG (05-11-2017)
Old 05-09-2017, 05:04 PM   #23
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Because it looks a lot better integrated into the dash.
I had a 2nd gen in dash with my WRX with working steering wheel controls, auto power on/sleep etc...
The Following User Says Thank You to Andrew025 For This Useful Post:
CxG (05-11-2017)
Old 05-11-2017, 02:41 PM   #24
kt45
Drives: BRZ 2013 MT
Yep actually looks like it belongs there instead of hanging off of your dash. I feel like it can be mistaken as a oem unit this way. Integrated SWC working as well. Only issues I have with my 2nd gen are with Timurs kernel not turning off and has to be unplugged to suspend. His blog says its likely a cranking issue. Anyone come across this?
Nexus 7 Install and Customization gdrider77 Electronics | Audio | NAV | Infotainment 18 06-07-2016 11:35 AM
Nexus 7 DIY dash install Casper Electronics | Audio | NAV | Infotainment 16 01-17-2016 12:28 PM
Another Nexus 7 install: Clean and Easy Sojhinn Electronics | Audio | NAV | Infotainment 264 10-30-2015 08:26 AM
Problems with NEXUS 7 Install Rhamzy Electronics | Audio | NAV | Infotainment 6 01-03-2014 03:43 AM
