Old 03-05-2014, 09:07 PM   #15
jflogerzi
jflogerzi's Avatar
Originally Posted by PERRIN_Chris View Post
It will make the car take turns a little better, since the wheels are going to be pushed out a little further. Other than that, it doesn't really make any difference in how the car drives.
Are spacers safe for track use?
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 03-06-2014, 12:16 PM   #16
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Yes spacers are totally safe for track use.
PERRIN_Chris is offline   Reply With Quote
Old 03-06-2014, 12:45 PM   #17
Alain
FRSKEE
Alain's Avatar
Drives: 2014 Monogram Series Whiteout
20 front. 25 rear. ARP extended studs. Wasnt too confident with the dual lugs. Cant wait to track mine.
Alain is offline   Reply With Quote
The Following 2 Users Say Thank You to Alain For This Useful Post:
Husker BRZ (03-06-2014), KalbiCool88 (10-06-2015)
Old 03-06-2014, 01:40 PM   #18
Moe
Moe's Avatar
Drives: Lexus IS250, Toyota 86
+1
Just don't go cheap. Get a good brand hub centric spacer - whether you track your car or not.
Moe is offline   Reply With Quote
The Following User Says Thank You to Moe For This Useful Post:
KkSc (03-06-2014)
Old 03-06-2014, 06:30 PM   #19
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
coilovers, 20mm front, 25mm rear
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
Old 03-06-2014, 06:51 PM   #20
KkSc
KkSc's Avatar
Drives: 86
Originally Posted by Moe View Post
+1
second that..
KkSc is offline   Reply With Quote
Old 03-06-2014, 10:50 PM   #21
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
I ran the 20/25 setup. Loved it.
MPI_Jack is offline   Reply With Quote
Old 03-07-2014, 07:40 PM   #22
Basket Case
Drives: 2013 Raven fr-s
How much of a pain is it to install extended studs?
Basket Case is offline   Reply With Quote
Old 03-07-2014, 08:12 PM   #23
Alain
FRSKEE
Alain's Avatar
If you have the proper tools. Easy. Hardest part for me was the rear. Had to remove the hub from the axle. But the fronts i kept on. I have a specialty tool that has a bearing to help put studs on.
I used to use a socket and open ended lug nut which tool forever.
There is a write up/DIY on this forums on how to do so.
Old 03-07-2014, 08:57 PM   #24
Basket Case
I feel like this is a much better/safer way to do spacers, I am just not sure if I am capable of doing this. I am very mechanically inclined, but I just can't have my car down for more then a few hours.
Old 04-16-2014, 04:32 PM   #25
travisb
travisb's Avatar
Drives: N/A
I'm guessing that it would be ok to put 25mm on all corners with stock wheels while going to 225/45-17 tires, right? I still have stock suspension and will for at least a year.
travisb is offline   Reply With Quote
Old 04-17-2014, 12:45 AM   #26
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
15mm front/20mm rear
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 04-20-2014, 09:48 AM   #27
evostyle
Drives: 2013 BRZ WRB
6speed_Sam Are your 15mm front spacers bolt on? If so, who makes them?
evostyle is offline   Reply With Quote
Old 04-20-2014, 10:03 AM   #28
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
My buddy with 20mm/25mm spacers (don't know the brand) had his FR-S reposted by Scion on their IG and twitter!
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
evostyle (04-20-2014), Juvenile (04-20-2014)
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 09:52 AM
Spacers on all 4 corners / stock wheels (20mm/25mm) zoltiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-14-2015 12:43 PM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 09:55 AM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 12:49 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 02:31 PM
