Old 02-26-2014, 10:33 PM   #15
jamesm
Is there scaling in the p3 gauge to display the value properly? It's just a simple 0-100%, 0-5v linear output.
Old 02-27-2014, 10:20 AM   #16
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
When setting up the gauge you set the value the gauge will read at 0v and the value it should read at 5v. The zeitronix specs on the kit shows that the analog out line is a linear plot ethanol content = voltage x 20. The gauge should work fine in this application but I dont think it has the ability to exponentially scale up.
Originally Posted by Sportsguy83 View Post
Took some time tonight to check this out. It seems you are correct, The ECA display unit does play some magic in determining the E%. So yes, there is only one output cable (white/blue wire coming from the ECA display), which is the one that would go to the ECU.
So yes, you would have to splice into it and connect it to the ECU AND the P# gauge analog input. Not a big deal and doable.
Thanks for checking it out Dave!
To simplify things a little more I gave Mike a call like you said. In my kit hes going to send out the ECA2 instead of ECA(1). The ECA 2 has two outputs and doesnt come with a display just the analyzer. I got lucky he had them in stock.
marcoaferrer is offline   Reply With Quote
Old 02-27-2014, 10:29 AM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Awesome! You are good to go then
Pinout for FRS Bespoke head unit - video inputs? ATSAaron Electronics | Audio | NAV | Infotainment 2 12-09-2014 10:59 PM
Any analog gamers out there? buzznasa Northern California 23 04-10-2014 07:51 PM
pt546-00140 Sub Output dgerny Electronics | Audio | NAV | Infotainment 1 01-09-2014 01:56 AM
where is the mic inputs on the fRS radio njccmd2002 Electronics | Audio | NAV | Infotainment 4 12-10-2013 12:59 AM
The New Tanabe Exhaust- Inputs and Thoughts JM Auto Racing Engine, Exhaust, Transmission 28 08-31-2012 03:40 PM
