Old 02-22-2014, 01:06 PM   #15
Hotrodheart
Hotrodheart's Avatar
I can squeeze out 400 miles on a tank. I live in the Laughlin NV/Bullheard City AZ area, so it's not really city nor is it highway driving.
I use every gas saving technique I can think of. I start in 2nd gear snow mode (I have the automatic). I use manual shifting, upshifting at 2000-2100 RPM. And featherfoot the throttle as much as possible. I maintain higher gears as long as possible. Not much fun, but I traded in a Prius, so I got used to good gas mileage.
Doing this, I can get 33-34 MPG on the dashboard; maximum speed 45 MPH. This is opposed to 35-36 on the highway; maximum speed 75-77 MPH.
I have less than 2000 miles on the car, so maybe it'll get better when the engine loosens up a bit.
I still blast it to redline when I am in the mood. I just have to pick my spots. And not too often. Needless to say, I didn't buy a sports car for fuel economy runs. But my gas budget has pretty much doubled, what with the reduced MPG and premium gas.
BUT I LOVE THIS FRIGGING CAR!!!
Hotrodheart is offline   Reply With Quote
Old 02-22-2014, 01:53 PM   #16
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
400+ average.
ntron1 is offline   Reply With Quote
Old 02-22-2014, 02:32 PM   #17
humfrz
Originally Posted by dad&sonFRS View Post
I usually drive about 75% local and 25% highway, in Queens, NY. But i think I'm getting poor gas mileage. I have only been get about 180 miles per fill up. I do have some fun driving,shifting around 5000rpm, but I mostly shift at 3000 rpm. Could I really be driving so poorly to only be getting 180 miles per tank? I know there are many mpg threads, which concerns me even more because i see many people are getting 250+miles. Could there possible be something wrong with my car? Or do i really just need to change my driving ways.
Hi dad&sonFRS ......
First off, I feel that trying to measure your gas mileage by figuring on how far a car will go on a tank of gas may be misleading, because of the variables involved.
I would suggest that you fill up your tank to "click off" on the pump re-set the trip meter to "0", drive till the tank is down to about 1/4 and fill up (to click off) at the same pump then claculate d your gas mileage (miles driven divided by gallons consumed).
Repeat this cycle maybe three times, then average all three values. This should give you a good idea of your average gas mileage.
humfrz
Porsche (02-22-2014)
Old 02-22-2014, 02:57 PM   #18
congee
congee's Avatar
Drives: SSM BRZ
I get around 420KM before red light comes on with 60% highway, 40% city.
I'm guessing it could get 450km sh til its fully empty.
Depends on weather conditions too. If its snow/cold, that average goes way down. Fall, I was averaging about 8.7L/100km and now during the winter, about 9.8L/100km. I usually follow speed limit during the city and 7000 rpm it when im on the on ramp.
congee is offline   Reply With Quote
Old 02-22-2014, 03:06 PM   #19
root
Drives: Raven FR-S
I get about 270 miles from first click of full at pump to low light on, give or take. That's usually the high end but its always pretty close to that. Tropical climate, 80's, pretty much sea level, lots of stop and go city.
root is offline   Reply With Quote
Old 02-22-2014, 04:12 PM   #20
dad&sonFRS
Drives: Firestorm FR-S
Originally Posted by Aaron.H View Post
@dad&sonFRS, in first post you say you do approx 75% local and noticed your location says Queens,NY. How much of that local portion is in snail pace heavy congestion traffic? If you are than that would be one factor why the bad mileage.
I drive in mostly local roads, not in the usual rush hour traffic, just the normal stoplight at every other block or so.
dad&sonFRS is offline   Reply With Quote
Old 02-22-2014, 04:13 PM   #21
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
I usually always fiil at 300-ish. If I let it go dry i'd prolly be nippin at 400.
Beyer Subaru is offline   Reply With Quote
Old 02-22-2014, 04:15 PM   #22
dad&sonFRS
humfrz
Thank you, I will be trying this method for the next few times i have to fill up.
The Following User Says Thank You to dad&sonFRS For This Useful Post:
humfrz (02-22-2014)
Old 02-22-2014, 04:17 PM   #23
dad&sonFRS
Thank you all for your inputs, I will continue to monitor the car , and start grandma driving it to see how my mileage improves. Half of me wants it to be the cars fault for the poor mileage, the other half wants it to be my fault so this way nothing is wrong with the car lol
Old 02-22-2014, 06:21 PM   #24
strat61caster
strat61caster's Avatar
When do you fill up? There's at least 50 miles difference between the 1/4 fill line and when the light comes on.
When the light comes on is generally about 10 gallons, worst case 200 miles isn't unusual with all city driving, EPA estimates 22 mpg with the manual transmission. I usually get 250-320 miles on a tank depending on how and where I'm driving.
ineedyourdiddly
Old 02-22-2014, 08:37 PM   #25
...and start grandma driving it to see how my mileage improves. Half of me wants it to be the cars fault for the poor mileage...
You do not have to "grandma drive" the car to get good gas mileage. Over 103 tanks, I've averaged 334 miles to the tank and 32.5MPG (including a few where I filled before my normal just before the light comes on). Most of it is closer to highway speed than in city speed.
See my owner's journal first post for the full breakdown by tank. http://www.ft86club.com/forums/showthread.php?t=6178
I do not, under any stretch of the imagination grandma drive. I'm usually full throttle at launch and my goal is to make the traction control light blink at me around curves.
Like others suggest, you should check the mileage by calculating it, and maybe even take a couple of highway speed road trips to see if you get better. My guess is you spend a lot of time not moving too fast.
Old 02-22-2014, 08:40 PM   #26
ntron1
Sarcastic Bastard
The light in mine come on @ 11.2 gallons like clockwork. 500 miles per tank is doable with the right highway trip.
The Following User Says Thank You to ntron1 For This Useful Post:
strat61caster (02-22-2014)
Old 02-23-2014, 08:07 AM   #27
dad&sonFRS
Thanks everyone, yeah i think my poor mileage is probably due both to driving on lock roads, hitting traffic lights constantly, and by hooning around. But I am going to continue monitoring my mileage and try and come up a more accurate mileage.
Old 02-23-2014, 03:41 PM   #28
DMDominator
Drives: Genesis 3.8 Track, Firestorm FR-S
Mine gets about 26-27mpg. Lots of uphill in my daily commute and the negative degree weather here doesn't help. During the summer it jumps up to 30-31mpg.
DMDominator is offline   Reply With Quote
Gas tank laley81 Issues | Warranty | Recalls / TSB 1 07-31-2013 01:45 AM
TANK Vs. FRS chae FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 06-05-2013 04:23 PM
gas tank lid htdonato Issues | Warranty | Recalls / TSB 1 11-30-2012 02:43 AM
340 miles and one full tank later... gunmetal5 Scion FR-S / Toyota 86 GT86 General Forum 28 11-14-2012 09:32 PM
How many miles per tank on E85 Innova Engine, Exhaust, Transmission 2 09-21-2012 10:02 PM
