Old 02-17-2014, 07:32 PM   #15
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Every wheel on anything aside from a tractor or slow moving implement is balanced and has to be rightfully so. Must be OPs first vehicle perhaps.
As far as where they're located that's all dependent of wheel itself sometimes tire design by where they place the weighted section due to tread design. My Weds with MPSS weight strips right up tight outwards as well.
The Following User Says Thank You to OICU812 For This Useful Post:
eSOLOR (02-17-2014)
Old 02-17-2014, 07:46 PM   #16
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Yep it's the first car I've bought on my own and first car I've modified I figured it was some type of weight by looking at the numbers. I have Michelin PSS as well.
eSOLOR is offline   Reply With Quote
Old 02-17-2014, 08:10 PM   #17
OICU812
Just a dude
OICU812's Avatar
Ok makes perfect sense on their placement then. Have a great day!
Old 02-18-2014, 07:33 PM   #18
rainmonkey
Drives: BRZ - Dark Grey
so the balance, aside from where on a circle (imagine looking at the wheel as it is lying on the ground so as not to roll) is also dependent on how far toward the face of the wheel the weights are placed.
Sometimes they'll place the weights all the way toward the inside of the wheel, sometimes they'll place it closer to the face (the part that you see easily toward the spokes). This is all done for balance based on calculations by the mount n balance machine.
I doubt they can push the weights further toward the inside without messing up the balance of the wheel.
rainmonkey is offline   Reply With Quote
Old 02-18-2014, 07:43 PM   #19
OICU812
Just a dude
OICU812's Avatar
Inward or outward is dependant on the wheel itself in design and tires. So therefore no you would not want to move it from that position either.
rainmonkey (02-18-2014)
Old 02-18-2014, 07:50 PM   #20
rainmonkey
ok your 2 sentences pretty much said what i was trying to say... but sooo much clearer.
my hat's off to you sir.
Old 02-18-2014, 11:04 PM   #21
1stGenBRZ86
1stGenBRZ86's Avatar
they are that close to the wheel because they are dynamic balanced. I'd bet there are hammered on weights on the inside.
To the people saying they belong in the middle, that is another type of balancing, which is less accurate, called static balancing.
1stGenBRZ86 is offline   Reply With Quote
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 03:23 PM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
NRG Rim/Wheel LIP PROTECTOR up to 22" Wheel - Various Colors - FREE SHIPPING!!! YURparts Wheels and Tires 3 12-16-2013 10:07 PM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 02:36 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
