#15 | |
blowhard
Drives: frs, project forester
I thought you were a 50+ year old mature grown ass man that contracts for nasa not a grudge holding child that saves and references quotes from a month back. |
#16 | |
Drives: 2013 GBS BRZ Limited
And I ws NOT "saves and references quotes from a month back". It was on the very page of the link 3 posts above. ![]() AND If I WAS 50+ I would probably threaten to "bend you over my knee".... |
#17 | |
blowhard
Way to go, you're awesome at the internet. |
#18 |
Drives: UM86 - 6MT
^ why don't you both stfu. byeeeeeeeeee
| The Following User Says Thank You to 1086 For This Useful Post: | reardrv (02-18-2014) |
#19 |
blowhard
#20 |
Drives: UM86 - 6MT
hahaha
#21 | |
I thought that if you pulled a ROM that you did not have a definition for, then you couldnt write it back on? Maybe the fact that it saves the file as a *.srf means that it can be restored without a definition... |
| The Following User Says Thank You to stugray For This Useful Post: | steve99 (02-17-2014) |
#22 | |
maybe some of the guys with a tactrix could do some more work on the "how to flash with tactrix guide " started by @stugray and edited by @vgi |
| The Following User Says Thank You to steve99 For This Useful Post: | reardrv (02-18-2014) |
#23 |
Drives: Scion-FRS
Stugray,
Here are my stock ROM from my vehicle both *.srf and *.bin. I have engage Mike from Tactrix on this issue with the logs files. Like I said, all the *.xml are in right path. If you think or know I did something wrong let me know. I followed every steps that I have read from other posts. |
#24 |
FRS-AZ - Thanks
Your stock ROM is ZA1JA00C There IS an ECUFlash definition file: https://github.com/TD-D/SubaruDefs/b...Z/ZA1JA00C.xml Did you have that on the machine when you reflashed the *.srf file? |
#25 |
Drives: Scion-FRS
Yes and here is the copy of the xml file from path:
openecu\ecuflash\rommetadata\subaru\BRZ\2012\ Hopefully its the correct one!! |
#26 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
The difference between the *.bin / *.hex file format and *.srf is that srf can deal with non-contiguous ROM areas, whereas *.bin / *.hex cannot. RR unfortunately cannot read srf files at this stage.
I would use Ecuflash to correct the checksum - there was a discussion on the BRZ thread over on the RR forums how the checksum is calculated (it's significantly bigger than the older roms, and required some code changes). |
#27 |
#28 |
Drives: Scion-FRS
No word from Mike or Tactrix yet.
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| ecu flash? | jybrd | Engine, Exhaust, Transmission | 69 | 07-15-2013 03:36 PM |
| Why no ECU Flash? | ngabdala | Engine, Exhaust, Transmission | 26 | 09-03-2012 07:27 PM |
| FR-S/BRZ Flash News!!! | manny25 | Engine, Exhaust, Transmission | 88 | 09-02-2012 01:45 PM |
| ECU flash | drei | CANADA | 8 | 08-10-2012 01:31 PM |
