Old 02-13-2014, 03:52 PM   #15
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by brn12345 View Post
BRZedit can load any of the open source maps out there. Shiv has put out numerous Stage 1 and Stage 2 maps that are free. Those can be flashed with BRZedit. Also the logger software in BRZedit is lightyears ahead of EcuTek. That alone justifies the cost of getting BRZedit.
A more reasonable example on price would be:
Ecutek : $850 hardware and tune (can only be used to flash and limited logging)
BRZedit : $420 hardware and tune (logger is amazing and the hardware can be used for many other things)
Let alone that if you want the good features of Ecutek you have to pay $399 extra for the Racerom.
To put it simply, I bought my Tactrix, Shivs OFT tablet, and my BRZedit software for less than a Ecutek package....
$850??
I got my ecutek cable, deskey, and license for right around $600.
^GT5 Replay Photo Mode^
Old 02-13-2014, 03:58 PM   #16
jamesm
Originally Posted by fenton View Post
Question for you guys that are much more versed with the different types of software. First i had Ecutek and Visconti tune. Visconti said that if i wanted to completely remove ecutek from the car i had to flash a Rom-nilpir file to completely get rid of it so dealer couldnt see. I asked him if there was a way to do it differently so that the license stayed.....he then told me to flash the same file but just to remove the nilpir from the file name.
I did that and then i got tuned uzing BRZedit at my local tuner. I can still use my Ecutek for logging because i didnt buy BRzEdit.
Main question is what state is my car at interms of licenses and whatnot? I plan to get one of Shiv's Phantom SC tunes and a OFT this spring, not sure if i will have to do something before he can flash?
Is there anyway that i can salvage the money i put into ecutek so that it would be useful to someone else?
Thanks for the help.
you should still have a license, right? if not i'm sure you could get ahold of ecutek and have them issue you a new one or something, you paid for it. i don't see why you'd want to use OFT if you already have ecutek or brzedit though, and the you already have two other things that do the exact same thing lol. you don't have to have an oft to use the OTS maps (once they're released in bin format).
Old 02-13-2014, 04:02 PM   #17
fenton
I dont have BRZedit, just used the tuners cable and ability to create a map for me.
I use ecutek for logging currently. I think i still have a license because i can log?
Honestly i just want to sell the ecutek if i can and buy more goodies for my car.
My tuner wasnt able to get a really good torque curve like shiv could get when tuning the ECS....it was running pretty pig rich down low.
fenton is offline   Reply With Quote
Old 02-13-2014, 04:04 PM   #18
jamesm
um.... ok. you realize that the OTS maps work with ecutek too, right? there's literally no difference at all if all you're doing is flashing an OTS map.
The Following User Says Thank You to jamesm For This Useful Post:
SirBrass (02-13-2014)
Old 02-13-2014, 04:18 PM   #19
mad_sb
Drives: 2013 Asphalt FR-S
Wait, so ecutek can now open and flash un encrypted real roms? Meaning not a rom with ecutek custom code in it, but a generic file created with romraider or ecuflash?
Or are you saying you can copy paste maps into ecutek and then flash?
Old 02-13-2014, 04:19 PM   #20
mad_sb
Your ecutek software should be able to query the ecu and tell you if you have a valid license file in the ecu. Don't ask me how to do that though as i have never used ecutek on this platform.
Old 02-13-2014, 04:22 PM   #21
fenton
Ya im not sure either but I think that shiv said the new maps will only flash from a oft.
I don't think he has any bin files for the tq300
Sent from my HTC One using Tapatalk
Old 02-13-2014, 04:22 PM   #22
jamesm
i'm pretty sure you can open unencrypted roms... i'll try later to confirm. and they'll have to make bin files eventually. that's the only open part of the oft lol.
edit: just confirmed.. yes they do open as normal. only caveat being that you can't add racerom feature files. everything else works just as expected.
Old 02-13-2014, 04:22 PM   #23
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
At this time, are only releasing the ESC maps in proprietary .dev file format. After that, the new generation of OTF ROMs will still be fully viewable and editable, just not upload-able through Ecutek or BRZ edit.
Old 02-13-2014, 04:24 PM   #24
Shiv@Openflash
Drives: 2013 FRS
Same map for TQ250 and TW300. The dyno comparing the two compressors had the same tune.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
fenton (02-13-2014)
Old 02-13-2014, 04:30 PM   #25
fenton
So am I able to get that file and flash via ecutek?
Only reason I ask is my brzedit tune is a little rough around the edges. I thought you had to do something different on the 300 because of the MAF reading down low?
Is there any risk flashing a car that already has a tune on it from different software?
Sorry for all the questions I'm still learning.
Still planning on getting the oft and header in spring.
Old 02-13-2014, 04:34 PM   #26
Ross
Drives: 85 corolla gts
before swapping to another brand of software always flash back to stock. Then Flash the new software.
Ross is offline   Reply With Quote
The Following 2 Users Say Thank You to Ross For This Useful Post:
SirBrass (02-13-2014), vynervt (02-14-2014)
Old 02-13-2014, 05:08 PM   #27
Shiv@Openflash
Drives: 2013 FRS
Hi Fenton,
The ESC map (and upcoming Vortech maps) are only available in .dev format so it's only compatible with OFT. The adjustments I made to the map were for the TQ300 but they worked just fine with the TQ250. I definitely recommend flashing back to stock before changing flashing platforms.
fenton (02-13-2014)
Old 02-13-2014, 05:18 PM   #28
fenton
Hi Fenton,
OKay thanks. Does anyone know anything about the nlpir ecutek files? the nlpir precedes the ROM....for example:
"nlpir ZA1J700C-enc.BIN"
"ZA1J700C-enc.BIN"
Thanks again!
BRZedit E85 How-To mad_sb Engine, Exhaust, Transmission 9 04-24-2020 09:30 PM
BRZEdit (ECUEdit) illmatic Software Tuning 246 06-02-2016 01:15 PM
BRZedit Help Sojhinn Software Tuning 2 10-29-2013 11:40 AM
BRZEdit MAP scaling jamesm Software Tuning 13 10-02-2013 12:43 PM
