Old 05-06-2012, 12:23 PM   #15
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
He said
"Center of engine block below engine throttle."
ok ty
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 05-06-2012, 02:11 PM   #16
Calum
That Guy
Drives: 2013 asphalt FRS MT
ok, how much variation are we talking about here?
I've machined parts to plus or minus 0.001 inch on a 40 year old lathe using a high speed steel bit I hand ground on a bench grinder. Surely Subaru's engine manufacturing plant can do good enough to keep things well within tolerance so this isn't required.
Old 05-06-2012, 02:53 PM   #17
Dimman
Kuruma Otaku
Dimman's Avatar
So have I.
But I've also honed connecting rods. Tolerance on rods is in tenths. Tightest I worked on is +.0003/-.0002. Some Mitsubishi rods are +/- .0001
Because titanium.
Old 05-06-2012, 03:10 PM   #18
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
It varies depending on the engine and tolerances, etc. Here's a somewhat typical crankshaft journal marking to diameter reference chart from a Toyota engine:
Mark 0 - 54.999 to 55.000 mm (2.1653 to 2.1654 in.)
Mark 1 - 54.997 to 54.998 mm (2.1652 to 2.1653 in.)
Mark 2 - 54.995 to 54.996 mm (2.1652 to 2.1652 in.)
Mark 3 - 54.993 to 54.994 mm (2.1651 to 2.1651 in.)
Mark 4 - 54.991 to 54.992 mm (2.1650 to 2.1650 in.)
Mark 5 - 54.988 to 54.990 mm (2.1649 to 2.1650 in.)
The important thing to remember is that these are high production engines, not something that is precision made by hand, etc. Bits wear, etc., this allows the engines to be made with a slightly wider tolerance range for machining, but with precise measurement, the oil clearances are always extremely tight and within a much tighter spec. Engines can be made in volume and at high capacity with exacting clearances without the need to check and recheck and replace tooling as frequently.
Also from what I've seen in most production engines on tear down, they're almost always within the middle of the range. Seeing something like a mark 0 or 5 on an engine is usually very unlikely. On some engines (like the 2JZ), they only have 1 piston size, and the block is more precise for machining, while older engines just had larger tolerances, etc.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
Calum (05-06-2012)
Old 05-06-2012, 03:29 PM   #19
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Jeff
Is this the reason why a lot of modern engines suffer from piston slap?
Subie is offline   Reply With Quote
Old 05-06-2012, 03:34 PM   #20
Calum
That Guy
That has more to do with the length of the piston skirt, the rod/stroke ratio and in some cases the wrist pin offset.
Old 05-06-2012, 03:39 PM   #21
Calum
That Guy
Jeff
I was having images of huge differences, but 5 thou total range that most likely doesn't get used, but could be compensated for seems very reasonable.
Thanks for the detailed post.
Old 05-06-2012, 04:10 PM   #22
xwd
The A and B on the Subaru engines does indeed identify the cylinder bore size and also the stock piston diameter size. Traditionally the B pistons are smaller than the A pistons. In some of the older engines the difference in size is around .007" total where the top .004 are the As and the bottom .003 are the Bs.
The BRZ factory repair manual will have exact specs on what they mean.
Old 05-06-2012, 05:37 PM   #23
Dimman
Kuruma Otaku
Dimman's Avatar
That's 5 tenth's btw. Half a thou.
Because titanium.
Old 05-06-2012, 06:33 PM   #24
Calum
That Guy
yeah, Doh.
Open Deck Block nrclptcnsmniak Engine, Exhaust, Transmission 36 01-27-2012 02:00 PM
STI engine Aldo the Apache Engine, Exhaust, Transmission 49 11-03-2011 10:36 PM
Ken Block Gymkhana 3 Midship Runabout Other Vehicles & General Automotive Discussions 24 09-15-2010 12:55 AM
