Old 02-04-2014, 04:26 PM   #15
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Originally Posted by BaeK View Post
Np! Now that I've read your post, I'm going to try and remove the cotter pin to further investigate where the sound may be originating. (Does the clutch move back up when you have the pin removed? I guessing you moved it with your hands back and forth??)
What I'm also planning on doing is to revert back to the original clutch height and rotate the U-bracket instead of the small rod that goes into the master cylinder. I used my fingers to rotate the rod for adjustment, but now I am questioning myself if I should have rotated the U-bracket.
So, remove the cotter pin, and then you'll need vice grips or pliers to squeze the white cap to pull the pin itself out. At that point, the clutch will probably pop, either forward or backwards. It's on a huge spring, and is binary in nature - either fully engaged or fully not engaged. You can play with it a bit to see if you still hear the noise
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
BaeK (02-04-2014)
Old 02-04-2014, 04:38 PM   #16
BaeK
BaeK's Avatar
Drives: 2013 Whiteout FRS
Originally Posted by JB86'd View Post
I remember in the clutch adjustment thread someone saying they rotated the U bracket instead and that was the proper way to do it. I have this popping noise as well so maybe that was our mistake. Keep us updated!
I hope the solution is as simple as that. Once I get home at 5PM EST, I will try it out and let you know.
Sounds good. My clicking sound only occurs ~60% of the time I use the clutch, so I will play around with it for a good amount of time to see if I can replicate the sound between the pedal and the pin.
BaeK is offline   Reply With Quote
Old 02-04-2014, 05:13 PM   #17
1Cor10:23
1Cor10:23's Avatar
Great investigation going on here guys...does anyone have the link to this specific post in the thread / rationale behind it? I went through 10+ pages and I didn't find it...maybe I'm filtering for the wrong key words.
Cheers
Old 02-04-2014, 05:28 PM   #18
BaeK
BaeK's Avatar
Cheers
I can't remember if this is the same information I read a couple of months ago, but here's one I found:
http://www.ft86club.com/forums/showt...t=8040&page=14
post #290 by s0sl0w
The Following User Says Thank You to BaeK For This Useful Post:
1Cor10:23 (02-04-2014)
Old 02-04-2014, 05:50 PM   #19
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I just started getting the clicking too. I just assumed it was the helper spring (I'm at 8k miles. did adjustment at 7.5k
The Following User Says Thank You to Target70 For This Useful Post:
86-tundra (02-04-2014)
Old 02-04-2014, 09:10 PM   #20
86-tundra
Troll Hunter
86-tundra's Avatar
I genuinely think it has something to do with the rod going back and forth, instead of the bracket
Old 02-04-2014, 09:26 PM   #21
whiskerbox
Drives: Scion FRS
OMG! I am not crazy. I have been hearing the clicking ever since I went over 7k on the odometer. I just thought I was clutching bad or something and have been trying all sorts of different levels to no luck. Really interested to see what you guys find out.
whiskerbox is offline   Reply With Quote
The Following User Says Thank You to whiskerbox For This Useful Post:
Old 02-04-2014, 11:49 PM   #22
Target70
Target70's Avatar
mine only clicks/pops at about about half an inch from the top, just after I begin to press the clutch. I can push it to the floor and pull almost all the way back then press it again and never hear it again till I let it out past that same point.
Old 02-05-2014, 09:46 AM   #23
BaeK
BaeK's Avatar
I did some additional troubleshooting last night and have found that my clutch does the same thing. It clicks when I press the clutch (about half-inch down) and it clicks again once I'm almost at the top (again, about half-inch down from resting point); I can't replicate the clicking noise as long as it's within that point.
trevorovert,
So I played around with the parts once I pulled out the pin (where the cotter pin is), and the noise is definitely coming from the master cylinder area/rod area. I played around with the clutch pedal (detached from the master cylinder rod) for a good few minutes, but I couldn't replicate the noise.
I spent 2 hours adjusting the rod and the U-bracket, and the clicking sound still exists (took me freaking 15 minutes to realize I can pull down on the rod to adjust the U-bracket... lol. I ended up rotating the rod at least 30+ revolutions after removing the speed sensor before I figured that out)
It's a bit softer when I drove it this morning, but that may be due to the cold temperature. (I remember last Wednesday, when Charlotte had snow, I didn't hear the clicking noise. That's when I wondered if ambient temperature had anything to do with the noise)
86-tundra (02-05-2014)
Old 02-05-2014, 01:05 PM   #24
86-tundra
Troll Hunter
86-tundra's Avatar
trevorovert,
Man. I think tonight I may play with the clutch line.... see if I can isolate the issue as being between the master and slave cylinder, or as being in the master cylinder
Old 02-05-2014, 04:39 PM   #25
BaeK
BaeK's Avatar
Cool cool. Let us know how that goes.
Old 02-06-2014, 10:10 PM   #26
1Cor10:23
1Cor10:23's Avatar
Curious, doss the noise persist to the same degree of you clutch in and out very, very, very slowly?
Sent from my SGH-I317M using Tapatalk
Old 02-06-2014, 10:10 PM   #27
1Cor10:23
1Cor10:23's Avatar
Curious, does the noise persist to the same degree if you clutch in and out very, very, very slowly?
Old 02-07-2014, 12:29 PM   #28
BaeK
BaeK's Avatar
If I'm understanding your question correctly, then yes. Whenever the clicking noise is made during clutch in, the same clicking noise will occur during clutch out.
However, there has been instances (for me at least), where the noise is made during clutch out when there was no noise during clutch in.
86-tundra (02-08-2014)
Clutch pedal springy sound pdreams Issues | Warranty | Recalls / TSB 16 06-01-2015 03:33 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 02:10 AM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 06:35 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 10:52 AM
Popping/Clicking Dead Pedal BRaZinDave BRZ First-Gen (2012+) — General Topics 6 12-08-2012 05:14 AM
