Old 07-09-2014, 07:16 PM   #15
D-VO
Drives: Whiteout FR-S, Evo 8 RS
I made a scaling rpn for the Manifold relative pressure to read boost (psi) if anyone wants to try it against their known good boost guage. This paramid is for the B01C.
paramname = Manifold_Relative_Pressure(PSI test)
paramid = 0xFFF88F78
isfloat = 1
scalingrpn = x,0.0193367747,*
I'm using a KW SC kit and the boost looks about right when compared to what I see on the forums.
D-VO is offline   Reply With Quote
Old 07-10-2014, 03:47 PM   #16
d1ck
Drives: Black 2013 FRS
Originally Posted by Td-d View Post
Try this:
FFF8DBD0 Ram_Fuel_Air_Commanded
This worked using the following scale:
x,14.7,*
d1ck is offline   Reply With Quote
The Following User Says Thank You to d1ck For This Useful Post:
steve99 (07-11-2014)
Old 07-10-2014, 11:15 PM   #17
D-VO
@Td-d: Do you have the paramid for logging AFR commanded on the B01C ROM?
Old 07-11-2014, 04:12 AM   #18
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
RAM:FFF8DBE8 Ram_Fuel_Air_Commanded
Td-d is offline   Reply With Quote
The Following 3 Users Say Thank You to Td-d For This Useful Post:
D-VO (07-11-2014), Joe-G (10-08-2015), steve99 (07-11-2014)
Old 07-12-2014, 01:21 AM   #19
steve99
I have added these additional AFR commanded and boost parameters to the Tactrix info post see files attached to that post
http://www.ft86club.com/forums/showt...10#post1645010
Old 12-28-2014, 09:00 PM   #20
mad_sb
Drives: 2013 Asphalt FR-S
Does anyone have the address for cruise control on / off for ZA1JA00C?
I have logging working without any triggers using some of the configs from: Tactrix EcuFlash Info for BRZ 86 Rom flash and logging
But I'm not having any luck triggering with defog.
Old 12-28-2014, 09:10 PM   #21
steve99
I have found that the triggers are very hit and miss, very often dont work at all, i have given up on them even trying to use coolant temp or rpm was no good.
suspect their is some issue with op2 code..
@Td-d might be able to hel but hes is on holidays, or the taxtrix guys
i think @vgi may have it working
mad_sb (12-29-2014)
Old 12-29-2014, 08:37 AM   #22
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
What are the code differences between logging A01C and B01C?
Toyota John is offline   Reply With Quote
Old 12-29-2014, 11:49 AM   #23
Td-d
The best way to check that would be to look through the two definitions and compare. From what I recall, it was not anything significant (mostly in as yet undefined areas of the rom to do with idling if I'm not mistaken).
Old 12-29-2014, 12:16 PM   #24
mad_sb
Thanks for the info .. I used OP2 stand alone extensively on my evo X and ralliart sportback. Both of those I triggered using cruise control. Sadly I can't find either config file these days to look at the various triggers i used.
I can log the defog param perfectly fine, but it never see's the trigger... Very strange, I may play around with parameter order. In the mean time I can at least log and with a good sample rate.
Old 01-01-2015, 12:58 PM   #25
mad_sb
Update:
I got the defog trigger working. In my case the issue was the encoding type of the logcfg.txt file. At some point I switched the ecoding to plain UTF-8. Using this encoding, none of my files would work. When I switched them back to "UTF-8 without BOM" they worked perfectly. I verified this by taking the working no-trigger file and saving it to UTF-8, which broke logging completely, then saving it back to UTF-8 without BOM and it started working perfectly again.
I'm using notepad++ and can change the encoding at will, i suspect windows notepad and some others might mess with the encoding, In fact I think I remember that from years ago with the ralliart. So... if you any of you are having strange logging issues or can't get triggers working on an otherwise working config, check the encoding type and make sure it us UTF-8 without BOM
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
steve99 (01-01-2015), Td-d (01-02-2015)
Old 01-03-2015, 02:18 PM   #26
mad_sb
I will try ASCII but i'm am 100% certain my issue was UTF8 vs UTF8 without BOM. Of Course that is not to say other formats don't work equally well, just that the OP2 does not read the UTF8 without BOM format correctly and results in parse errors.
Originally Posted by vgi View Post
to be on a safe side i would rather suggest people use plane ASCII (ANSI) mode for their files. I don't know for sure but considering standard C/C++ reads/writes ASCII text file by default I doubt there was an effort made to actually support a full UTF8 character set supported.
ASCII is a subset of UTF8 (UTF8 was designed for backward compatibility with ASCII) so it's possible all the chars in your file were just ASCII. If any true UTF8 characters will be in your file I guess it may or may not work.
Also, many editors have a default encoding, you should check what that is. Many editors make an attempt to auto-detect encoding and if they detect some UTF8 characters they may place BOM in the file (BOM is a sequence of bytes (EF BB BF) that allows the reader to identify the file as an UTF-8 file). Windows notepad should be safe to use as default encoding is ASCII unless it detects UTF8 chars, then it will place BOM in the file. It also puts /r/n for new line instead of just unix /n, but it think it should be safe.
Old 03-27-2015, 03:55 PM   #27
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
I tried using your log config on my A01C ROM, however I seem to be getting invalid values (ie. RPM is logged as "1" the entire drive). I also need to remove the defogger switch condition to get logging working. I've uploaded my datalog here:
http://datazap.me/u/slowbaru/93-octa...5-6-9-16-22-24
I am using the OFT Stage 1 93 octane OTS A10C ROM. If this is based off the B01C ROM, is it possible I have different memory addresses? Does anyone have information on how to verify the correct memory addresses to throw in to the log config file?
@Td-d @d1ck @steve99 Any one of you have ideas? Thank you!
Edit-
I tried using @AdrianG 's log config but I am still getting incorrect values. If someone could provide some info on how to verify the correct memory addresses it would be appreciated.
BRZoomTX is offline   Reply With Quote
Old 03-27-2015, 04:29 PM   #28
steve99
Edit-
you will need to use the B01D_B01C logcfg.txt third file from the end in this post
http://www.ft86club.com/forums/showthread.php?t=62332
their is also the B01C ram addresses if you need other addresses/parameters.
BRZoomTX (03-27-2015)
ecuflash, op2, openport, standalone logging
Data logging for noobs - OFT Shad0ez Software Tuning 18 11-07-2016 07:20 PM
school me on data logging fatoni Tracking / Autocross / HPDE / Drifting 11 01-09-2014 09:54 PM
Toyota Data Logging CAN for GT6 Luckrider Software Tuning 1 11-23-2013 02:03 PM
ECUTEK Logging pdreams Engine, Exhaust, Transmission 5 02-05-2013 10:06 AM
