Old 01-23-2014, 08:14 PM   #15
CoupedUpSubie
Drives: 2013 BRZ Limited
Originally Posted by DR 86 View Post
I have a question for you: what kind of harness do you have, and what is 1.8L of furry?
My harness is a Megan Racing 4 point. Came with Simpson straps with the end to bolt onto the car. This harness was in a fully caged log booked car. Here is the link to it on their website: http://www.meganracing.com/product_d...d=620&catid=98
It will be for rallyx only.
The 1.8L of furry is a joke. Anyone who knows the ej18 engine put into mid 90s subarus should get it.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 01-23-2014, 08:55 PM   #16
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I think he's confused about your spelling of the word "fury".
"Furry" is...just...something else.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 01-23-2014, 08:58 PM   #17
2point0
2point0's Avatar
Hang on a sec, Megan Racing sells harnesses? I mean, a cheap exhaust is one thing but I don't think I would trust my life with any of their products.
Old 01-23-2014, 09:10 PM   #18
CoupedUpSubie
It is labeled Megan Racing. From looking it over I don't see where anything was cheaply done. Nothing is fraying or lacking proper stitching. I work with harnesses for doing work aloft on ships so I know what proper harness design is. Only part that could be better is the buckle but it is probably stronger then the factory one. Also like I said, just for rallyx in my impreza. It won't see speeds over 35(on the speedo as wheels spin a lot at times). I like the feel of being held in a seat as compared to on it, which is part of the reason I bought a BRZ and not a WRX or STi. Those seats are wider.
Old 01-23-2014, 10:12 PM   #19
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Props to the OP for taking the criticism so well. Agreed with all the other folks that it looked a tad sketchy.
Thorpedo is offline   Reply With Quote
Old 01-23-2014, 11:13 PM   #20
kuhlka
Drives: 2013 BRZ Limited AT
Originally Posted by ScorpionOzzy View Post
a shoulder harness should always be mounted directly behind you, never to the floor. When you crash, those harnesses are just going to compress your back, rather than just hold your body in the seat.
A simple harness bar would do the job just fine
Hmmm... Just got a new Miller Multimatic 200 for the garage. I could probably make one of those and build more after setting up a jig this spring. Just need a tubing bender.
kuhlka is offline   Reply With Quote
Old 04-04-2014, 03:18 AM   #21
JS86JS
JS86JS's Avatar
Drives: 2013 Toyota 86 GTS, Marine Blue
This isn't such a bad thing; I needed this as i want to do what some of the guys in the 86/brz car club here in aus have done. All it does is (once tightened up) holds you in the seat for every corner so it makes driving easier instead of sliding in the seat. BUT wear your stock seat belt with it in case of a crash because bolting it like this is not a good idea if you crash
check out my on-going build here: My blue 86
JS86JS is offline   Reply With Quote
Old 04-04-2014, 09:51 AM   #22
mx555
Don't use harness like this. Ever.
FIA guide for harness set up
mx555 is offline   Reply With Quote
Old 04-04-2014, 09:53 AM   #23
Thorpedo
The SquadWhisperer
Noooo no no no no. Did you not read the thread? This is the WORST setup possible and waaaaaay more dangerous than the stock seatbelt. If you wear your stock belt it isn't going to help you at all with this thing on. This setup has the potential to SERIOUSLY injure you. DO NOT bolt it up this way and use it.
As stated earlier, for show is one thing, but the belts should not be used like this.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Old 04-04-2014, 11:43 AM   #24
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
So if other people drove their cars off a cliff, would you do it too?
Tell me exactly how wearing both a stock seat belt AND a 4 point harness is a good thing?
-alex
Old 04-04-2014, 12:53 PM   #25
mx555
http://www.cg-lock.com/
Old 04-10-2014, 03:46 PM   #26
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
I dont know anything about harness safety but has anyone looked at mounting the top belts of a harness to the child seat top mount above the back seats?
Sypher is offline   Reply With Quote
Old 04-10-2014, 04:20 PM   #27
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I'd be curious to know about this, too. Or are those too high up?
I'd also like to know the viability of mounting a schroth auto control to the same mounting point as the rear shoulder belts. If I were to have a harness in a street-driven car, the auto control 3 pt harness is what I'd want, to keep use of the backseats.
^GT5 Replay Photo Mode^
Old 04-10-2014, 05:43 PM   #28
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Originally Posted by F1point4 View Post
That setup is unsafe. I talked to reps at Schroth and Takeda and both of them said the car's geometry is not fit to mount shoulder belts to the rear seatbelt points so they will not be making quick fit style harnesses for our cars. They strongly urge wrapping harnesses around rollcages are properly made harness bars.
The lap belt should pointed outward, and the outside lapbelt should really be mounted to where the factory seatbelt is located.
I second everyone who says its really important to pay attention to manufacturers recommendations regarding harness angles, etc.
This. When I was shopping my for harness setup, the guys at HMS Motorsport, who are a Schroth importer, confirmed the shoulder belt geometry is too steep to be mounted to the rear seat area on our cars, and I needed a proper harness bar.
I ended up going with the Schroth Profi II ASM 4 point with the Agency Power harness bar.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
GoPro Mounting Locations Jericon Electronics | Audio | NAV | Infotainment 10 02-05-2014 12:24 PM
FS: Sparco Shoulder Pads and Tuner Style 4-point Harness Aznsky Interior Parts (Incl. Lighting) 7 07-21-2013 08:57 PM
Bucket seat store locations? CyberFormula Cosmetic Modification (Interior/Exterior/Lighting) 0 02-21-2013 09:16 PM
FS: Sparco 4-Point Racing Harness JPxM0Dz Canada Classifieds 2 01-12-2013 12:10 PM
Video/Go Pro Camera Mounting and locations diirk FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 10-02-2012 08:33 PM
