Old 01-21-2014, 03:58 PM   #15
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
"How to make this car look good without a drop?"
IMHO, you can't.
OP - obviously you're wanting to improve the ascetics of your car, and aren't happy with the stock wheel gap. Larger wheels or spacers won't fix this. If you want less wheel gap, you need to lower the car. As other people have pointed out, you can install springs or coilovers to address this, with springs being the less expensive option.
mwjcyber is offline   Reply With Quote
Old 01-21-2014, 04:08 PM   #16
wparsons
wparsons's Avatar
Originally Posted by FR-S89 View Post
i heard springs kill your struts.
You heard wrong... good quality lowering springs with some R&D behind them (not too low, not too high of a spring rate) are totally safe on our stock struts.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
OICU812 (01-24-2014)
Old 01-21-2014, 05:09 PM   #17
Byebye
Byebye's Avatar
Don't get a low offset. Get +40 or higher.
Byebye is offline   Reply With Quote
Old 01-23-2014, 12:33 PM   #18
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Call up Touge Tuning and get them to order and install Swift springs for ya.
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
wparsons (01-25-2014)
Old 01-24-2014, 08:03 PM   #19
86KEEBS
DRIFT
Drives: Raven FRS 6mt
bigger tires help close the gap. Ive tried alot of different sizes on my 17X7.5s and I found 235/45 front, 245/45 rears to LOOK the best imo. I had ppl asking when I upsized to 18s when they were still 17s hah
86KEEBS is offline   Reply With Quote
Old 01-24-2014, 09:02 PM   #20
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
IMHO, you can't.
This.
Redstar is offline   Reply With Quote
Old 01-24-2014, 09:43 PM   #21
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I don't believe that, people haven't had the car for long. But in two years you'll start seeing the "Stock struts shot" and "THESE SPRINGS SUCK THEY KILLED MY SHOCKS". Any stock strut with enhanced wear will blow out sooner or later, just a matter of time and how much the car is driven...
Most people will be fine however, honestly stock struts wearing out just gives you an excuse to upgrade anyways...
The Following User Says Thank You to dem00n For This Useful Post:
ftc~brz (01-25-2014)
Old 01-24-2014, 09:55 PM   #22
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
There are several folks however almost near that time now and no "blown strut" madness threads? Several for sure well over 30k -50k miles still strong?
But back to OP if you want to play gotta pay as many have said. Just lower it and get look ya want only live once.
Old 01-24-2014, 09:57 PM   #23
dem00n
dem00n's Avatar
Drives: Scion FRS
What time? 9:56pm?
The Following 2 Users Say Thank You to dem00n For This Useful Post:
ftc~brz (01-25-2014), ZionsWrath (01-31-2014)
Old 01-24-2014, 10:50 PM   #24
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by Mach V Dan View Post
How about some Mach V springs? That's what we use.
--Dan
Mach V
How do you fit 17x9 with springs? What tires and alignment?
Old 01-24-2014, 11:03 PM   #25
OICU812
Just a dude
OICU812's Avatar
What time? 9:56pm?
1-2years as per your comment. Sorry but I haven't even seen a single post complaining about a stock strut blowing from a lowering spring? If you have please point to it. Thx
The Following User Says Thank You to OICU812 For This Useful Post:
Old 01-24-2014, 11:05 PM   #26
dem00n
dem00n's Avatar
Drives: Scion FRS
Yes, 2 years. You can come back to this thread in 2016, if i'm wrong which is enitrely possible then you win. Who knows, maybe these stock struts on a $26K are that good, it's possible. But from what I've seen and worked on, stock struts don't last long on aftermarket springs. That's my experience.
Old 01-24-2014, 11:55 PM   #27
OICU812
Just a dude
OICU812's Avatar
No worries I will admit when I was just in springs it bothered me that and the limitation of wheels you can run etc so I went with coils.
Old 01-25-2014, 12:45 AM   #28
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
I bolt them on. How do YOU fit them?
Those are Sumitomo HTR-Z III 255/40R17. Nearly-stock alignment, but more camber up front from Whiteline Com-C upper mounts.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following User Says Thank You to Mach V Dan For This Useful Post:
Good handling at 50-60mm drop? diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 41 01-02-2014 12:52 AM
Drop it Like its Hot! *Lets See Your Drop* VIXEN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 92 09-07-2013 02:53 AM
(GOOD QUESTION) Which Spring make a higher front bumper? Tein H tech, RS-R or Swift? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-14-2013 09:52 PM
Suggestions needed for a good quality coilover + lots of drop HiiiPwrFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-01-2013 06:48 PM
Who is going to buy the FRS DROP DROP Shop? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-18-2012 05:45 PM
