Old 01-18-2014, 08:44 PM   #15
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Originally Posted by Superstar View Post
How safe are these tunes? Do they modify the transient timing table? Just worried about the direct injection issues...
The reason I went oft so early in my build is they have the transient timing table fix in every tune and it was the cheapest way I could get said protection since US dealerships are being kept in the dark and fed shit by Toyota on the issue.
I have not regretted this move at all.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
Keenercarguy (04-27-2016)
Old 01-19-2014, 03:06 AM   #16
Superstar
Drives: Honda
Toyota has updated ECU maps with the transiting timing table fix. What's the difference (if any) between OFT tunes and the updated Toyota maps?
Superstar is offline   Reply With Quote
Old 01-19-2014, 03:23 AM   #17
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
More power, more torque, smoother idle, e85 tunes, endless upgradability...
Anorexic 86 is offline   Reply With Quote
Old 01-19-2014, 03:24 AM   #18
Anorexic 86
+1
Old 01-19-2014, 10:00 AM   #19
FrsDuke
Fanboy
FrsDuke's Avatar
Toyota USA isn't giving the updates to people like me who have the old cals unless there is a problem. I could not get the updates so I took matters into my own hands, before I had a problem.
If your cal has the fix then that's great. You can still improve on the stock tune without giving up the DI protection fixes.
TL;DR:
-Duke
Superstar (01-19-2014)
Old 01-19-2014, 07:27 PM   #20
BRZ_HaVoKx
BRZ_HaVoKx's Avatar
Drives: Satin Pearl White BRZ - Limited
I plan on purchasing the OFT very soon! Im so stoked I love the tablet! I currently have the Borla UEL headers which look near identical to yours do you see there being any difference in power output on the E85 tune or will they both be close and over 200whp. Also have perrin catback and cutsom over/front pipe all 2.5" with and injen SRI. Thanks Shiv
BRZ_HaVoKx is offline   Reply With Quote
Old 01-20-2016, 09:58 AM   #21
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by Shiv@Openflash View Post
Hi guys,
Was going through our dyno database today and I found an interesting comparison that some may find interested. Two separate cars running on E85. Both 6MT. Both custom dyno tuned on the same dyno in similar conditions. Both running on OpenFlash Tablet with very similar tunes.
Car 1 (our shop car)
Modified inlet duct
OpenFlash UEL Header
OpenFlash Tablet
LW wheels/tires
Stock everything else
Car 2 (customer car)
TRD airbox
3rd party UEL header
Over pipe
Front pipe with free-flow cat
Cat-back exhaust
LW pulleys
aluminum driveshaft
clutch w/ LW flywheel
LW wheels/tires
STD corrected:
Uncorrected/Actual:
Conditions:
Rambling Thoughts/Opinions
-Lightweight pulleys/driveshafts/flywheels don't do much (if anything) on a 4th gear dyno pull since the rate of acceleration (dRPM/dT) is so low. It's only in very low gears (and especially when free revving in neutral!) that reductions in rotational mass make a measurable (and noticeable) difference. They are the kinds of mods you feel in certain conditions (rev matching, blipping, etc,). But don't expect it to make your car faster in most conditions. But the improved response you feel under those few conditions feels fantastic.
-Most of the 2-3 whp difference between the two cars can probably be attributed to the cat-back and high flow cat in the customer (blue) car.
-E85 is great. On 91oct, the most we most we would expect to see on our shop car is 190whp. Not only is the extra power everywhere great, running on E85 also miraculously fills in the torque dip with no other changes to the car:
-The FA20 is also pretty darn good. One of the benefits of being very high compression is that there is so much untapped power potential. And that the only thing you need to extract it is better fuel/higher octane. Also, the fact that Subaru/Toyota made so much compromise when it comes to factory header design (closed coupled cat, poor collector, etc,) means that a simple 20 minute header swap can yield such big power on 91 oct (when coupled with a tune). Stock vs OFT tune+Openflash Header on 91oct:
And Stock vs OFT tune+OpenFlash Header on E85 :
I would never have expected to see these kinds of gains with just 2 modifications (tune and headers) and a change in fuel. We are lucky to be enjoying such a great platform. Not many other NA cars are so responsive to tuning
Firstly - thanks for the good info...
Secondly... I'm so glad my headers + flexfuel is being done, and getting it back tomorrow... woot woot! Can't wait to see the kw/hp numbers for fun and feel the butt dyno for the real rewards
I like driving!
86 South Africa is offline   Reply With Quote
oft+ofh=win, shiv 2016
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
Awesome Power run: Jeep climbs out of the dyno GeeTee86 Off-Topic Lounge [WARNING: NO POLITICS] 1 06-16-2013 08:47 PM
My agency power exhaust dyno results clayrush Engine, Exhaust, Transmission 46 09-17-2012 11:41 PM
HKS Hi Power Spec L Dyno Result Ishii Motors Engine, Exhaust, Transmission 4 08-03-2012 03:20 PM
Has anyone run a dyno for HKS Hi Power Spec-L? wollview Engine, Exhaust, Transmission 14 08-01-2012 01:36 AM
